Nitrogen Oxide (NO or NO2) Sensor Module
Hi there,
I'd like to measure the nitrogen (mono-)oxide (NO) or nitrogen dioxide (NO2) levels in the air.
Does anybody have any recommendations for a sensor?
Ideally, and I'm very well aware of the fact that the world isn't ideal, I'd like
  1. I don't want to solder, so I'd like to have a module and I'd like to have UART interface or something
  2. no calibration necessary or as simple as possible
  3. cost less than $50
Does anybody have any experiences with such sensors?
I'd appreciate any help.
What concentration levels at what accuracy of each gas do you want to detect?
jremington:
Good question, of course. How could I forget to check?
I'd like to measure air quality of my living room. I double-checked, and I found that
NO
Normal: 0.005–0,1 ppb
Dirty: 0.05–300 ppb
NO2
Normal: 0.01– 0.3 ppb
Dirty: 0.2–200 ppb
I guess I'd need a sensor that has a 10 ppb or 0.01 ppm minimum.
Does that sound reasonable?
It seems like the mics-2714 can do that. But I'd like to have a shield. No SMD soldering, please.
Or if possible, I'd like to use it with a raspberry pi directly.
Edit:
I just checked, limits seem to be at around 10-50 ppb, so having a minimum of 10 ppb is a must.
The MiCS-2714 senses NO2 in the range 50-5000 ppb, but there is nothing useful in the data sheet about detection of NO or selectivity against other gases.
Edit: according to this data sheet, the sensor does not detect NO: https://sgx.cdistore.com/datasheets/e2v/1107-Datasheet-MiCS-2714.pdf
Good luck finding a shield!
