Nixie brightness
Hi, I'm trying to build a Nixie Clock but I wanted to add brightness control trough PWM.
I'm not great with elecronics but I thought that connecting 170VDC and the PWM signal to a MPSA42 might do the trick.
Currently, I drive the Nixies with K155ID1 drivers and PCF8574 expanders.
The problem is that I don't know if other components are needed like pull down resistors.
Thanks.
From datasheets I saw on google for K1551D1, no outputs are turned if you put 0b1010 to 0b1111 on the inputs (numbers outside of 0 to 9).
So write your code to send one of those codes briefly every 25mS, how long you send it for will determine how dim the display gets.
CrossRoads:
That's an interesting idea! Will it be fast enough?
Thanks.
Who knows? Depends on what the rest of your code is doing.
I would think it's better than trying to switch 10 170V lines on & off after the Nixie driver chip.
The outputs on the K1551D1 or the 74141 is able to handle approx. 65 volts. By "blanking" the chip the outputs will see a higher voltage and the tube will glow, not turn off as you want.
Simply, you cannot blank using this technique. You need to blank them with an anode-transistor.
// Per.
If you have 170V or whatever on the common pin of the tube, and you stop pulling the individual pins low, then both sides of a digit will be 170V and the digit will be off.
The driver has an open collector output, not a 170V high drive output. Can add pullup resistors (to 170V) if you want to really ensure they are high when not driven. I don't think that is commonly done tho.
Hi, I tried to drive the anode with an MPSA42 at 285Hz but it doesn't reduce the brightness when I change the duty cycle. Do you have any tips?
Generalardj:
Show us a schematic.
// Per.
I tried this one:
Instead of using the ne555 to generate the pwm I use the digital output 9 with modified frequency.
