So, I want to build a Nixie counter, two switches, one up one down.
Suggestions on which Arduino board to use?
Will I need a nixie diver?
Not sure where to start?
Any should work fine, depending on how many digits you want to drive. the easiest implementation will use 4 digital outputs for each digit, so even an Uno-class arduino should have no problems doing 4 digits.
Will I need a nixie diver? Not sure where to start?
Yes, you'll need a nixie driver. The common one is a 74141 high-voltage bcd-to-decimal driver. 4 inputs (binary number) and 10 outputs (0-9, one for each possible value) capable of connecting to a nixie.
I'd start with the 74141 datasheet, and by looking at the circuits on the net for "nixies clocks" (a clock, after all, is just a specialized counters...)
Or you could get adventurous
http://www.autosportlabs.org/viewtopic.php?t=2705&postdays=0&postorder=asc&highlight=nixie&start=0
I only want to control two digits.
Thanks for your reply.
Yea, I have been thinking of a hall sensor nixie speedometer.
Me too.
