Hello,
Following this tutorial, I have tried to get the shift registers + 1 driver to count up from 0-99, but no matter how many times I wire it up and flash code, one tube always has all of the numbers lit up at once, and I have absolutely no clue on how to continue.
I am pretty much a beginner to most of this stuff, and I have succeeded in using just the driver chip to control one tube.
Here is the code:
/* a sketch to drive two nixie tubes using two SN74141 BCD chips and a single SN74HC595N shift register
developed from the tutorials on Adafruit.com and arduino.cc
the sketch will cause two nixie tubes to count from 0 to 99 but you can change it to create any two-digit number and have the nixie tube display it
Jeff Glans 2013
Released into the public domain
//set up the pins for communication with the shift register
int latchPin = 14;
int clockPin = 12;
int dataPin = 27;
int x; //create a counting variable
// create an array that translates decimal numbers into an appropriate byte for sending to the shift register
int charTable[] = {0,128,64,192,32,160,96,224,16,144,8,136,72,200,40,168,104,232,24,152,4,132,68,196,36,164,100,228,20,148,12,140,76,204,44,172,108,236,28,156,2,130,66,194,34,162,98,226,
18,146,10,138,74,202,42,170,106,234,26,154,6,134,70,198,38,166,102,230,22,150,14,142,78,206,46,174,110,238,30,158,1,129,65,193,33,161,97,225,17,145,9,137,73,201,41,169,105,233,25,153};
byte nixies = 255; //initiate the byte to be sent to the shift register and set it to blank the nixies
void setup(){
pinMode(latchPin, OUTPUT);
pinMode(dataPin, OUTPUT);
pinMode(clockPin, OUTPUT);
void loop(){
nixies = 255; // create a blank byte
updateShiftRegister(); // send the blank byte to the shift register
for (x = 0; x<100; x++){ // count from 0 to 99
nixies = charTable[x]; // translate into a byte to send to the shift register
updateShiftRegister(); //send to the shift register
Serial.print("x = ");
Serial.println(x);
Serial.print("nixies = ");
Serial.println(nixies);}
//the process of sending a byte to the shift register
void updateShiftRegister(){
digitalWrite(latchPin, LOW);
shiftOut(dataPin, clockPin, LSBFIRST, nixies);
digitalWrite(latchPin, HIGH);
Any help is appreciated, thank you.
