NKC RGB LCD shield causes disconnection
Howdy! I'm using the Duemilanove with an atmega328, and I've recently assembled NKC Electronics' 'RGB LCD Shield for Arduino.' Go Team Phil! But wait! There's more! When I plug the darn thing into my arduino, the arduino suffers a total communication loss with the PC. To the point that it even loses power. I've checked my connections again, and checked my assembly vs. assembly guide. Then I had my brother check everything over (he's better at this than me).
So, basically what I'm wondering is if anyone else has tried using this shield, and if they've had the same problem, or if it worked. And if it didn't work, then whether they found a resolution.
Thanks! -Phil
It is possible that your supply is not able to provide the current. Have you tried using an external power supply?
I guess you are refering to http://www.nkcelectronics.com/rgb-lcd-shield-for-arduino-65k-color-k65.html.
I have not had any problems with mine....
/Henning
I am having the same problem. When I plug the LCD Shield, the arduino powered off.
Edited:
After doing some test, I figure it out that there is a short circuit between the VCC pin and GND pin. But I cant found where is the short circuit. All the solder points are OK. No apparent short circuit on the solder points.
Any help will be apreciate.
TY
@WestNQ: can you send me hi-res pictures of the top and bottom of the board to support at nkcelectronics dot com?
Thanks
I have just send an email to you(NKC suport). Hope the picture can help.
TY
I saw the pictures... the problem is probably below the LCD. The tiny thin PCB that is used to attach the LCD to the board does not tolerate well the huge solder pieces that you have... i am assuming, based on the soldering of the other through hole components. I will reply to your email with some follow-up information. I will also include in the assembly guide page to be careful with the soldering of the LCD to the board, and check for any shorts before continuing the assembly.
I was thinking that this could happen, but before soldering the LCD on the Shield, I checked if there were any short circuit. I will re-weld to see if it resolves.
thanks
I have the same problem, looked over all my connections, even tried the shield without the LCD connected and still have issues with the arduino not showing power. Edit: after doing some more testing, it looks like the problem happens when pin 2 of the icsp header is connected. I'm not good enough with schematics to trace that back to where my problem is, but all my connections seem to be ok.
