NMEA 2000 Shield
Libera-8,
Did you load due_can library from my repository? I have not yet checked changes, what collin80 had made, so I can not say does that work even you would load all missing libraries.
Timo, I am not sure. I tested again now several times and with two different systems. Your due_can lib is working without compiling error, but can does not send.
due_can 2.0.1 from Collin brings compiling error with due, can_common.h: No such file or directory
due_can 2.0.0 from Collin is working completely.
Would you tell Collin?
I have to make comparison to see changes and ensure I have run tests with same version as on my repository.
Hallo Timo,
sorry flooding the topic may with stupid questions...
I got delivered the rudder position sensor. It is a Hall Effect Sensor, Position, 90°, 4.5 V to 5.5 V, Pin, Cylinder Rotatable, 200 mV.
A view pages earlier I have read that you added rudder position to the library. I could not find something in the reference about it.
Do you have an example how to integrate it?
Thank you!
Look at the MessageSender example on line 123 SetN2kRudder(N2kMsg,DegToRad(5),1,N2kRDO_MoveToStarboard,DegToRad(-5)); For the unnecessary vales use defined NA value.
Hi all Due users,
I am extremely sorry about problems with Arduino Due board. I tested own board only by loading due_can from my repository, but did never checked NMEA2000_due library. For some mistake it was not updated to final repository. That was the reason, why it did not send anything to the bus with due_can lbrary under my repo.
Now they are up to date and all should work (as they should have). Under my library posts I read that alo collin80 due_can version works, but for the latest version you have to download also can_common library.
Hei Timo,
I am 100% sure there is no reason at all to apologize.. :-)
A question:
How do I integrate this reading from the hall sensor into this sentence?
rudderValue = map(rudderSens, 40, 980, -5,5);
I don´t get the SetN2kRudder splittet up so I understand what is happening here.
Thank you..
You can read parameter descriptions on N2kMessages.h.
If you get rudder angle in radians:
then just call
SetN2kRudder(N2kMsg,rudderValue);
NMEA2000.SendMsg(N2kMsg);
Note that you can let function to use default values for rest of the parameters.
Note that when you need to do that periodically, you have to do like in TemperatureMonitor example:
#define RudderSendPeriod 100 // ms
void SendRudder() {
  static unsigned long RudderSendTime=millis()+RudderSendPeriod;
  if ( RudderSendTime<millis() ) {
    RudderSendTime+=RudderSendPeriod;
    double rudderValue = map(rudderSens, 40, 980, -5,5);
  NMEA2000.ParseMessages();
  SendRudder();
Never use delay() command in your code!
Sorry Timo,
I don´t get it.. What is ment here?
MessageSender:42: error: expected unqualified-id before ')' token
 void SendRudder() {
exit status 1
Than means you missed some coma or semi column or some other syntax in your code. Post your code or check what you missed in your last edit before it strted failing to compile. Happy new year!
MODIFIED:
I got the code corrected so it don´t drop any error regarding “(){}” or whatever anymore. But still the problem that that value is not calculated and or mapped from the function…
Hey,
Happy new year 2018 to all of you!
I don´t get any further. Compltly stock. :confused:
What is wrong here? It is on an Arduino Mega. A0 is the hall effect sensor with 90 degrees giving values from 40 to 980. The sensor is ok but I can just read a value with serial print (rudderSens) of 54.
Here is the code:
// Demo: NMEA2000 library. Send main wind data to the bus.
#include <Arduino.h>
#include <NMEA2000_CAN.h>  // This will automatically choose right CAN library and create suitable NMEA2000 object
#include <N2kMessages.h>
#define N2k_CAN_INT_PIN 21 // Use interrupt  and it is connected to pin 21
#define USE_MCP_CAN_CLOCK_SET 8
int rudderSens = A12;   // Input from the rudder position hall sensor 90 degrees
float rudderValue;
// List here messages your device will transmit.
const unsigned long TransmitMessages[] PROGMEM = {130306L, 0};
  // Set Product information
  NMEA2000.SetProductInformation("00000002", // Manufacturer's Model serial code
                                 100, // Manufacturer's product code
                                 "Simple wind monitor",  // Manufacturer's Model ID
                                 "1.1.0.22 (2016-12-31)",  // Manufacturer's Software version code
                                 "1.1.0.0 (2016-12-31)" // Manufacturer's Model version
  // Set device information
  NMEA2000.SetDeviceInformation(1, // Unique number. Use e.g. Serial number.
                                130, // Device function=Atmospheric. See codes on http://www.nmea.org/Assets/20120726%20nmea%202000%20class%20&%20function%20codes%20v%202.00.pdf
                                85, // Device class=External Environment. See codes on  http://www.nmea.org/Assets/20120726%20nmea%202000%20class%20&%20function%20codes%20v%202.00.pdf
                                2046 // Just choosen free from code list on http://www.nmea.org/Assets/20121020%20nmea%202000%20registration%20list.pdf
  // Uncomment 2 rows below to see, what device will send to bus. Use e.g. OpenSkipper or Actisense NMEA Reader
  NMEA2000.SetForwardStream(&Serial);
  // If you want to use simple ascii monitor like Arduino Serial Monitor, uncomment next line
  NMEA2000.SetForwardType(tNMEA2000::fwdt_Text); // Show in clear text. Leave uncommented for default Actisense format.
  // If you also want to see all traffic on the bus use N2km_ListenAndNode instead of N2km_NodeOnly below
  NMEA2000.SetMode(tNMEA2000::N2km_NodeOnly, 23);
  // NMEA2000.SetDebugMode(tNMEA2000::dm_Actisense); // Uncomment this, so you can test code without CAN bus chips on Arduino Mega
  NMEA2000.EnableForward(false);
  NMEA2000.ExtendTransmitMessages(TransmitMessages);
  NMEA2000.Open();
  SendRudder();
  Serial.println(rudderSens);
  Serial.println(rudderValue);
double ReadRudderPosition() {
  rudderValue = map(rudderSens, 40, 980, -5, 5);
  return rudderValue; // Read here the true temperature e.g. from analog input
void SendRudder() {
  static unsigned long RudderSendTime = millis() + RudderSendPeriod;
 tN2kMsg N2kMsg;
  if ( RudderSendTime < millis() ) {
    RudderSendTime += RudderSendPeriod;
    double rudderValue = map(rudderSens, 40, 980, -5, 5);
    SetN2kRudder(N2kMsg, rudderValue);
With ActisensListener on the first board and the windmonitor example I get all showing up on the NMEAReader and OpenSkipper. As soon as I flash the rudder nothing is showing up or I just get 66 as value.
I must say that it is a bit hard to understad for me the NMEA2K libray. I just work with arduino now about a month and my programming skills are more in the direction of PLC programming.
Thank you all for the help!
If you have 8 Mhz clock you have to have definition before #include <NMEA2000_CAN.h>. That is shown on examples. So write:
Note that you have also defined above the interrupt pin to be 21. If interrupt pin is not connected from your board to pin 21, you have to define right pin. If you do not know the right pin, leave it undefined, so library runs without interrupt. With wrong pin definition library won’t work at all. It is the same with wrong clock set definition.
Then note that Arduino map uses integer calculations. So define your own:
double dMap(double x, double in_min, double in_max, double out_min, double out_max) {
  return (x - in_min) * (out_max - out_min) / (in_max - in_min) + out_min;
Also remember to use 0x for hex values. So write:
int rudderSens = 0xA0;
Then you should get for your rudderSens=0xA0=160
(160-40)*(5 - -5)/(980-40) + -5 = -3.72
But actually I do not understand your scaling. Why you are scaling to -5 <-> 5 radians?
Hey Timo,
Thank's for the detailed answer.
I skale from -5 to due to the example I saw. Thats all.
If I connect the hall sensor to analog and judt do the 5/1023 I get the value 40 to 980. The sensor is giving 0.5 to 4.5 v by 90 degree rotation.
Of course it would be better to have a higner resulution as I need this value as well for the autopilot later on.
Regards..
But if your sensor is giving values 40..980 on 90 deg rotation, it means it turns from -45° .. 45°. Then you should have do scaling: double rudderValue = map(rudderSens, 40, 980, -pi/4, pi/4); or double rudderValue = DegToRad(map(rudderSens, 40, 980, -45, 45));
I am still learning a lot..
yes, would make of course sens to do so.
Resulution is at the 90 degree version 0.022. Which is 2045 per 45 degrees of turn if I got that right. But this is o much as the resolution is 10 bit (1024 steps at 5v) on the analog input right?
Details from the sensor:
BI TECHNOLOGIES / TT ELECTRONICS 6127V1A90L.5 - Hall Effect Sensor, Position, 90°
Output Voltage 0.2 Vdc (4%) to 4.8 Vdc (96%) Typical (see Feature Codes table) Output Overvoltage Limits 10 Vdc to -0.3 Vdc; output may be shorted to ground or supply without damage Output Current ±8 mA Max. Output Load 1 kΩ Min., 10 kΩ Typical Input Voltage 4.5 to 5.5 Vdc Supply Voltage Absolute Limits 20 Vdc Max., -10 Vdc Min. Independent Linearity1 ±0.5% (0.25% Available) Hysteresis 0.2% Max. Resolution 0.088° for 360° travel, 0.011° for 45° travel Supply Current 8.5 mA Typical, 12 mA Max. Dielectric Strength 750 V rms Insulation Resistance 1,000 MegΩ Min. Electrostatic Discharge (ESD) Passes 2 kV human body model and 15 kV air discharge Bulk Current Injection (BCI) Passes 2-500 MHz at 200 mA Actual Electrical Travel 360° Typical (see Ordering Information)
Is there someone who has examined the can bus in volvo penta engines?
Hello Timo,
I am really sorry to bother you with the rudder position thing… I do try it now for the last 6 days and get stuck every time with something else.
That is killing me soon… Back to analog instruments! :grin:
This code:
void RudderPostion() {
  double dMap(double x, double in_min = 40, double in_max = 1023, double out_min = -45, double out_max = 45){
is producing this error:
RudderPosition_NMEA2K_v2:42: error: a function-definition is not allowed here before '{' token
exit status 1
This is the hole sketch I thought to use:
int rudderSens = 0xA0;        // value read from the pot
double rudderValue = 0;
const unsigned long TransmitMessages[] PROGMEM = {127245L, 0};
                                 "Rudder Position monitor",  // Manufacturer's Model ID
                                155, // Device function=Atmospheric. See codes on http://www.nmea.org/Assets/20120726%20nmea%202000%20class%20&%20function%20codes%20v%202.00.pdf
                                40, // Device class=External Environment. See codes on  http://www.nmea.org/Assets/20120726%20nmea%202000%20class%20&%20function%20codes%20v%202.00.pdf
                                1851 // Just choosen free from code list on http://www.nmea.org/Assets/20121020%20nmea%202000%20registration%20list.pdf
  //NMEA2000.SetForwardType(tNMEA2000::fwdt_Text); // Show in clear text. Leave uncommented for default Actisense format.
  NMEA2000.Open();
void SendRudder() {
  tN2kMsg N2kMsg;
    double dMap(double x, double in_min = 40, double in_max = 1023, double out_min = -45, double out_max = 45) {
  SendRudder();
It took also some time until I have recognized that the usual map function will not work here. I thought your post which showed the userdefiend map function is not mandetorry for this case and I got always wrong values. The strange thing is that I used the standart map function to test the sensor in a simple sketch and it was working just fine like this one:
int rudderSens= A0;  // Analog input pin that the potentiometer is attached to
int sensorValue = 0;        // value read from the pot
int RudderPosition;
  // read the analog in value:
  sensorValue = analogRead(rudderSens);
  // map it to the range of the analog out:
  RudderPosition= map(sensorValue, 54, 1023, -45,45);
  // print the results to the serial monitor:
  Serial.println(sensorValue);
In case I got the sketch running than I always got a constant rudderposition send which had nothing to do with the sensor value.
If I get this one working fine than I think I get almost every other I thought to implement also working.
Would be gorgeous to get this running with the help of you, without I think I have to buy the commercial version of this sensor for rudder position.
Thousends of thanks in advance!
Your questions actually belongs to some basic c/c++ syntax forum. That you should study first.
One problem is that you just copied my code sample inside on other function. The new function dMap should be defined alone as own function: .. double dMap(...) { ... } ... void SendRudder() { ... } ...
That is basic syntax.
Then you have set default values for dMap function parameters: ... double dMap(double x, double in_min = 40...) ... Do not use default values, before you understand the meaning of them. You should then call dMap inside your code: ... void SendRudder() { ... double rudderValue=dMap(sensorValue, 54, 1023, -45,45); ... }
Like you do with map, which is just function as dMap, but defined in some Arduino standard library.
Then note that in your code you defined int RudderPosition. This means that you can have 90 difference values between -45 45. If1 degree accuracy is enough for you, that is fine and then also standard map is fine. If you like to have better accuracy, you have to use double of float.
Then you have defined analog pin as int rudderSens= A0; So on board it says A0..A15 printed, but if you read definition of analogRead:
analogRead(pin) Parameters
pin: the number of the analog input pin to read from (0 to 5 on most boards, 0 to 7 on the Mini and Nano, 0 to 15 on the Mega)
So you should simply have: int rudderSens=0;
Modified:
Hey Timo,
sure you are right that this is basic. The code I posted was ment that I wanted to use that one as base. Not that this was finnished. I worte a lot of versions and I didn´t wanted to post all of the garbage I produced here.
->****** History now
Would be better to have a more accurracy of the rudder angle for sure. As soon as I add dMap to a line I get that it is not declared. Do I declare it I get as double for example I get "dMap can not be used as a function. In other posts I could found exactly the same like you posted it and I compared it to many different sources.
I used the user dMap as a single function and also used double or float (void blabla… analogRead(reudderSens)… , return dmap(…) ) with descriped result. The point is the error appears also
as single function and that was than the point where I didn´t came any further.
<-****** History now
I simply forgot that I create my own map function which I have to call than later in the program. Stupid failure… Sorry
So differences between float double int and other main functions of the reference library I do know about. I saw that analogRead was missing and used it before like I got temp monitor to work like it should. I know not so much, yet. But I know about the simple basics.
I will post thoose questions next time in the forum which belong to this type of questions.
Sorry my a bit rude answer. I meant that you should really study code syntax basics and do some simple trainings. Also play with code by commenting things, moving code to different location or what ever to learn what effects to where and what kind of errors you get. On code below try e.g. comment { at the end of line “double dMap(…” to see how error message leads you totally wrong. Also study to read error messages - it is not sometimes easy with c++.
Below is ready code for rudder, which I may add as example some day. Study it and try to learn.
// Demo: NMEA2000 library. Read rudder angle from the Analog sensor
//#define N2k_CAN_INT_PIN 21 // Use interrupt  and it is connected to pin 21. Use this with with e.g. Mega board. Check where your interrupt has been connected.
//#define USE_MCP_CAN_CLOCK_SET 8 // Uncomment this, if your CAN shield uses 8 MHz clock instead of 16 Mhz like e.g. on seeedstudio can bus shield
                                 "Rudder Position",  // Manufacturer's Model ID
                                 "1.1.0.22 (2018-01-05)",  // Manufacturer's Software version code
                                 "1.1.0.0 (2018-01-05)" // Manufacturer's Model version
                                155, // Device function=Rudder. See codes on http://www.nmea.org/Assets/20120726%20nmea%202000%20class%20&%20function%20codes%20v%202.00.pdf
                                40, // Device class=Steering and Control Surfaces. See codes on  http://www.nmea.org/Assets/20120726%20nmea%202000%20class%20&%20function%20codes%20v%202.00.pdf
  NMEA2000.SetForwardType(tNMEA2000::fwdt_Text); // Show in clear text. Comment for default Actisense format.
  NMEA2000.SetMode(tNMEA2000::N2km_NodeOnly,23);
  NMEA2000.EnableForward(false); // Comment this, if you want to see bus traffic on your serial.
  NMEA2000.Open();
  SendRudder();
// Double replacement for standard map function
// Function reads rudder postion from A0 input and scales it to angle in degrees
  double rudderValue = dMap(analogRead(A0), 40, 980, -45, 45);
  // We actually would need here some filter function to prevent noise on analog.
  return rudderValue;
void SendRudder() {
  tN2kMsg N2kMsg;
    double rudderValue=ReadRudderPosition();
    Serial.print("Rudder value: "); Serial.println(rudderValue);
    SetN2kRudder(N2kMsg, DegToRad(rudderValue));
