}* Serial.write(" "); Serial.writeln(gps.decode()); // HERE !!! } } While writing Serial.write(c, DEC); received GPS sentences, every sentence ends by 1310. (13 and 10 ) Even I add the and it doesn´t works, evem without... wher I write code (HERE !!!), it returns 0 ALWAYS! Why? :-/ any idea? :-?
the problem is you do not read a telegram just from the beginning. You start reading somewhere in the middle. Change the code as follows, this should work.
int decode = 0;
char buffer[..]
decode = 0;
if (GPSload() == true) {
// decode the telegram
// and start new receiving
decode = 0;
bool GPSload()
char c;
static int i;
switch (decode) {
case 0 : // wait for next reading
Serial1.flush(); // discard all characters
if ((millis()-GPStimeout) > 1000) {
decode = 1;
i = 0;
case 1: // wait for Start of sequence
if (Serial1.available()) {
c = Serial1.read();
if (c = '
I can not try if it works, i have no GPS receiver, but the importent things are:
wait until a new GPS telegram starts (character $)
read until the end of the telegram (character LF)
You can add a timeout to the GPSload to restart, if telegram not received within a certain time.
Mike
// start character found, store
buffer[i++] = c;
decode = 2;
case 2: // receive until end of sequence
c = Serial1.read();
buffer[i++] = c;
// unexpected start of new sequence
if (c = '
1. wait until a new GPS telegram starts (character $)
2. read until the end of the telegram (character LF)
Mike
// start from beginning
i = 0;
buffer[i] = c;
// look for end character
if (c == 10) {
// get actual time
GPStimeout = millis();
decode = 3;
case 3: // wait until telegram decoded
if (decode == 3) return true;
else return false;
Not reading from beginning shouldnt be a problem. Only can happen that I read longer or shorter sentence. Shorter sentence is rejected by the library and longer shall be accepted when the "$" come.
And more, I write the sentence from buffer to serial to check it and control. very offten I get whole sentence, but no acceptation...
in my case it isn't accepted. I'll try your proposal, but think the problem is somewhere else...
