NMEAParser.h - Wiring Nano
I have written a sketch using this library and I have a very basic question:
To which terminal on the nano do I feed the NMEA0183 stream?
The documentation is silent. The Rx pin seems like a good guess given that the void loop is on:
while (Serial.available()){
parser << Serial.read();
But if this is right, I cannot use Serial Monitor to debug, etc.
What am I missing?
Variants of Software Serial will work to receive serial data for the parser.
If you use hardware serial to receive NMEA data, you can still print debug messages on the serial monitor, or send them to a terminal program.
Thank you. Will try then. I am just sending NMEA to the nano.
