I wonder if there is any button held statement that I can use for my Arduino project? I got two buttons and one LED. I want the LED to start blink when I've held button1 for 5 seconds. And then when I've held button2 for 5 seconds I want it to turn off.
5 seconds after I've tapped the button it starts to blink. But I want it to blink after I've held it down for 5 seconds.
Record the time the switch is pressed, set a flag.
If the switch is released within 5 seconds, reset the flag.
If 5 seconds goes by with the flag set, do your stuff.
#define LEDon LOW
#define LEDoff !LEDon
#define BUTTONpushed LOW
unsigned long lastMillis;
unsigned long heldMillis;
const byte switchButton = 8;
const byte ledPin = 13;
bool flag = false;
byte currentState;
byte lastState;
pinMode(ledPin, OUTPUT);
digitalWrite(ledPin, LEDoff);
pinMode(switchButton, INPUT_PULLUP);
} //END of s e t u p ( )
if (flag == true && millis() - heldMillis > 5000ul)
//reset the flag
flag = false;
//LED on
digitalWrite(ledPin, LEDon);
if (millis() - lastMillis > 50)
//restart the timing
lastMillis = millis();
//go and check the switches
checkSwitches();
} //END of l o o p ( )
void checkSwitches()
currentState = digitalRead(switchButton);
if (lastState != currentState)
//update to the new state
lastState = currentState;
//is the switch now pushed
if (currentState == BUTTONpushed)
//set the flag
flag = true;
//initialize the timer
heldMillis = millis();
//reset the flag
flag = false;
//LED off
} //END of c h e c k S w i t c h e s ( )
arduotto:
You need to post your program so I can see exactly what you are doing.
...R
