Hi
I'm trying to debug some library code on the zero with Serial1. Usually when I do this I declare
HardwareSerial * mySerial; as a private variable in the class definition (usually found in the .h file).
Then I pass a pointer in my sketch, such as myUSBHostObject.init(&Serial1) or some such, then modify the .cpp code like USBHost::init(HardwareSerial * serial){ mySerial = serial}. Then I can print to serial monitor with mySerial->println();
I can't seem to do this with the USBHost class because I can't find a class definition in the .h file.
ref: USB_Host_Library_SAMD/Usb.h at master · gdsports/USB_Host_Library_SAMD · GitHub
ref: USB_Host_Library_SAMD/Usb.cpp at master · gdsports/USB_Host_Library_SAMD · GitHub
This is the entire Usb.h file
#ifndef USB_H_INCLUDED
#define USB_H_INCLUDED
#define _usb_h_
#include <stdint.h>
// Uncomment to enable debug
//#define DEBUG_USB_HOST 1
// MASS STORAGE
// <<<<<<<<<<<<<<<< IMPORTANT >>>>>>>>>>>>>>>
// Set this to 1 to support single LUN devices, and save RAM. -- I.E. thumb drives.
// Each LUN needs ~13 bytes to be able to track the state of each unit.
#ifndef MASS_MAX_SUPPORTED_LUN
#define MASS_MAX_SUPPORTED_LUN 1 ///// 8 WHG
#endif
//#include "Arduino.h"
#include "macros.h"
// None of these should ever be included by a driver, or a user's sketch.
#include "variant.h"
#define USB_HOST_SERIAL SERIAL_PORT_MONITOR
#include "Print.h"
#include "printhex.h"
#include "message.h"
#include "hexdump.h"
#include "sink_parser.h"
#include "address.h"
#include "usb_ch9.h"
//#include "usbhost.h"
#include "UsbCore.h"
#include "parsetools.h"
#include "confdescparser.h"
#endif /* USB_H_INCLUDED */
Here is the the constructor from the .cpp
#include <stdio.h>
#include "Usb.h"
//#ifdef ARDUINO_SAMD_ZERO
static uint32_t usb_error = 0;
static uint32_t usb_task_state = USB_DETACHED_SUBSTATE_INITIALIZE;
/* constructor */
USBHost::USBHost() : bmHubPre(0) {
// Set up state machine
usb_task_state = USB_DETACHED_SUBSTATE_INITIALIZE; //set up state machine
/* Initialize data structures */
uint32_t USBHost::Init() {
//devConfigIndex = 0;
// Init host stack
bmHubPre = 0;
UHD_Init();
return 0;
