no class named .at [SOLVED WITH LOVE]
Getting a UDP msg, i convert the char into a string to search for some specific characters in the msg.
In this example im looking for the "capital letter L" because i need the next piece of information after
that capital L. which is an interger.
So the incoming UDP msg could look like this S0L1E0T1
I want to split them up, OR lookup the letter i need, so i can find the correct number.
  int size = udp.parsePacket();
  if (size > 0) {
    do
        char* msg = (char*)malloc(size+1);
        int len = udp.read(msg,size+1);
        msg[len]=0;
        String inputMsg = String(msg);                            // switching to string mode
        for (unsigned int i=0;i < inputMsg.length(); i++)    // running through the string
          if(inputMsg.at(i) == "L")                                  // looking for L
            Serial.print("Found one : ");                           // Do stuff if L is found
            Serial.println(inputMsg.at(i);
            doStuff();
        Serial.print("received: '");
        Serial.print(msg);
        free(msg);
However, im running into issues using the .at because clearly it's not supported,
but I'm coming from visual studio where i would #include to help me out here.
Not sure if char is able to work in this way, but it's fine anyway running on a mega and
have plenty of memory to spare.
Any ideas, also open for alternative solutions to find the number after a letter like that.
It's rather silly to wrap an array of chars in a String instance, so you can test the individual characters in the array. Shitcan the stupid String class. Access the characters in the array.
PaulS:
Tell me how then... you are not being helpful, at all.
Just looking into that page nick posted a link to..
Are you serious?
        for (unsigned int i=0;i < strlen(msg); i++)    // running through the string
          if(msg[i] == "L")
// looking for L
PaulS:
Are you serious?
Yes, i was. Clearly i was unable to see the logic here.
So i really appreciate the zealous attitude often expressed by the senior members on this board.
PaulS:
          if(msg[i] == "L")
// looking for L
But thank you, yes that is quite clear now.
Strange how i missed this, but it's obvious now that you show me.
Maybe it's the language barrier, but English is certainly not my native language.
thank you.
