No code execution after power cycle
Hello,
I'm quite experienced with single PCB linux based systems, but I'm really beginner on Arduino. And even though Arduino is quite popular, I have significant trouble to find basic information for setup. Meanwhile I can compile and upload, I can interface with Processing on my Mac, but every time I do a power cycle, the Arduino seems to have lost the uploaded file. To my understanding it should have a flash, does the IDE only load the code into the RAM? Is there any possibility that the Arduino executes my code on power on? I'm using a MKR1000. I found this issue in the troubleshooting guide, but I don't understand. I suggests that the cause may be serial data coming in. But I just connect the board to a USB power supply. Same if I connect it to the laptop.
Thanks in advance !
Cheers, Christof
There is a dedicated MKR1000 section. You can ask a moderator to move the question there.
What are the symptoms? It might be that the Mac assigns a different port every time that you reset the MKR1000 and if your program uses serial comms it will fail.
Go back to the blink example, change the delay to something that you can easily distinguish from the default and check the behaviour.
Thanks a lot for your answer sterretje ! I tried the basic blink example and you're right. It works after reset. Then I tried my code, it doesn't. Then I commented all serial debugging messages, then it also worked !!! :o
But it's quite inconvenient to comment all messages and if you want to continue, you need to uncomment again. Is there no more elegant way to get around this issue?
Thanks, Christof
When you find strange behaviour of your sketch always think about RAM shortage. The Uno e.g. only has 2k.
If you have a lot of debugging print's with a lot of text then use the F macro. Serial.print(F("long text));
When using the F macro, the content of the string will be stored in Flash memory not in RAM.
SupArdu:
If you have a lot of debugging print’s with a lot of text then use the F macro.
OP is using a MKR1000; not that likely to run out of memory.
Thank you for your answers. I don't think that it's a RAM issue as the code works well after upload.
Just after reset it doesn't. It rather seems to be a general issue with serial communication. No solution for this? This must be a pain for everyone...
Cheers Christof
