No communication between Arduino and Wii Motion Plus.
I’m trying to get my Wii Motion Plus to send data to my Arduino. The code (I retrieved the code and the wiring to the Arduino from http://randomhacksofboredom.blogspot.com) does not give me any errors when uploading to my Arduino but the serial monitor does not display the information from the WM+ all the serial monitor displays is “WM+ tester”. I have tried various I2C speeds from 100 kHz to 400 kHz, I do not know whether the code is wrong or if my WM+ is dead.
Here is the code I’m using.
#include <Wire.h>
byte data[6]; //six data bytes
int yaw, pitch, roll; //three axes
int yaw0, pitch0, roll0; //calibration zeroes
void wmpOn(){
  Wire.beginTransmission(0x53); //WM+ starts out deactivated at address 0x53
  Wire.write(0xfe); //send 0x04 to address 0xFE to activate WM+
  Wire.write(0x04);
  Wire.endTransmission(); //WM+ jumps to address 0x52 and is now active
void wmpSendZero(){
  Wire.beginTransmission(0x52); //now at address 0x52
  Wire.write(0x00); //send zero to signal we want info
void calibrateZeroes(){
  for (int i=0;i<10;i++){
    wmpSendZero();
    Wire.requestFrom(0x52,6);
    for (int i=0;i<6;i++){
      data[i]=Wire.read();
    yaw0+=(((data[3]>>2)<<8)+data[0])/10; //average 10 readings for each zero
    pitch0+=(((data[4]>>2)<<8)+data[1])/10;
    roll0+=(((data[5]>>2)<<8)+data[2])/10;
  Serial.print("Yaw0:");
  Serial.print(yaw0);
  Serial.print(" Pitch0:");
  Serial.print(pitch0);
  Serial.print(" Roll0:");
  Serial.println(roll0);
void receiveData(){
  wmpSendZero(); //send zero before each request (same as nunchuck)
  Wire.requestFrom(0x52,6); //request the six bytes from the WM+
  yaw=((data[3]>>2)<<8)+data[0]-yaw0; //see http://wiibrew.org/wiki/Wiimote/Extension_Controllers#Wii_Motion_Plus
  pitch=((data[4]>>2)<<8)+data[1]-pitch0; //for info on what each byte represents
  roll=((data[5]>>2)<<8)+data[2]-roll0;
void setup(){
  Serial.println("WM+ tester");
  Wire.begin();
  wmpOn(); //turn WM+ on
  calibrateZeroes(); //calibrate zeroes
void loop(){
  receiveData(); //receive data and calculate yaw pitch and roll
  Serial.print("yaw:"); //see diagram on randomhacksofboredom.blogspot.com
  Serial.print(yaw); //for info on which axis is which
  Serial.print(" pitch:");
  Serial.print(pitch);
  Serial.print(" roll:");
  Serial.println(roll);
  delay(100);
Search for I2C Scanner. The first thing to do is maker sure that the device is correctly connected to the Arduino, and has the address that you expect.
Topic Closed: I found out that the connections between the WM+ and the Aduino data wire were loose.
