No connection established IDE 2.3.2 [SOLVED?]
I was trying to compile my code but the No connection established error showed up
It happened after I downloaded the L298N library by Andrea Lombardo
I didn't make changes to the code after i installed the library but i made sure to compile it just in case.
My code:
#define VRX_PIN  A1 // Arduino pin connected to VRX pin
#define VRY_PIN  A2 // Arduino pin connected to VRY pin
#define LEFT_THRESHOLD  500
#define RIGHT_THRESHOLD 530
#define UP_THRESHOLD    500
#define DOWN_THRESHOLD  524
#define COMMAND_NO     0x00
#define COMMAND_LEFT   0x01
#define COMMAND_RIGHT  0x02
#define COMMAND_UP     0x04
#define COMMAND_DOWN   0x08
int xValue = 0 ; // To store value of the X axis
int yValue = 0 ; // To store value of the Y axis
int command = COMMAND_NO;
  Serial.begin(9600) ;
  // read analog X and Y analog values
  xValue = analogRead(VRX_PIN);
  yValue = analogRead(VRY_PIN);
  // converts the analog value to commands
  // reset commands
  // check left/right commands
  if (xValue < LEFT_THRESHOLD)
    command = command | COMMAND_LEFT;
  else if (xValue > RIGHT_THRESHOLD)
    command = command | COMMAND_RIGHT;
  // check up/down commands
  if (yValue < UP_THRESHOLD && yValue > 200)
    command = command | COMMAND_UP;
  else if (yValue > DOWN_THRESHOLD && yValue < 800)
    command = command | COMMAND_DOWN;
  // NOTE: AT A TIME, THERE MAY BE NO COMMAND, ONE COMMAND OR TWO COMMANDS
  // print command to serial and process command
  if (command & COMMAND_LEFT) {
    Serial.println("COMMAND LEFT");
    // TODO: add your task here
  if (command & COMMAND_RIGHT) {
    Serial.println("COMMAND RIGHT");
  if (command & COMMAND_UP) {
    Serial.println("COMMAND UP");
  if (command & COMMAND_DOWN) {
    Serial.println("COMMAND DOWN");
  // print data to Serial Monitor on Arduino IDE
  Serial.print("x = ");
  Serial.print(xValue);
  Serial.print(", y = ");
  Serial.println(yValue);
Im running Arduino IDE 2.3.2 on windows 10
The board is selected as Arduino Uno on COM3 while i compiled
I also couldn't open the example code from the library
What happened when you tried ?
nothing happened, no new window or something, nothing happened, i tried multiple times
i restarted the IDE and it seems to work fine, i guess i fixed it
