I was using ESP32 cam..
But it isn't working..
It is showing me this in serial monitor..
And sometimes my ESP32 cam become very warm..
Please help...
The main error is not about core dump, because the booting still going further.
The cause of fail is
Camera init failed with error 0x105
Please do not show the error messages as pictures, copy it and insert in the forum as text
**Below method work for me**
## Soft Access Point
Because the ESP32-CAM doesn’t connect further to a wired network (like your router), it is called soft-AP (soft Access Point).
This means that if you try to load libraries or use firmware from the internet, it will not work (like including JavaScript libraries). It also doesn’t work if you try to make HTTP requests to services on the internet (like sending an email with a photo, for example).
## ESP32-CAM Video Web Server Access Point (AP)
You should be able to modify any of your projects to set the ESP32-CAM as an access point.
In your Arduino IDE, go to File > Examples > ESP32 > Camera > CameraWebServer.
Then, modify the code to act as an access point as we’ll explain.
### Customize the SSID and Password
You need to define an SSID name and a password to access the ESP32-CAM access point. In this example we’re setting the ESP32 SSID name to ESP32-CAM Access Point. You can modify the name to whatever you want. The password is 123456789, but you can and should also modify it.
const char* ssid = "ESP32-CAM Access Point";
const char* password = "123456789";
### Setting the ESP32-CAM as an Access Point
In the setup(), remove the following lines (set the ESP32 as a station):
WiFi.begin(ssid, password);
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected");
And add the following to set the ESP32 as an access point using the softAP() method:
WiFi.softAP(ssid, password);
There are also other optional parameters you can pass to the softAP() method. Here’s all the parameters:
softAP(const char* ssid, const char* password, int channel, int ssid_hidden, int max_connection)
This is what you need to include in your web server sketches to set the ESP32-CAM as an access point.
