Hello,
I am using the IDE 2.3.2 for my Arduino Nano ESP32. I have installed the Arduino Core 2.0.13. Currently the Core is 2.0.16. I have not received an update until today. Even if I select "Updateable" in the Board Manager myself, nothing is offered. What is the problem?
The problem might be with your internet, IDE settings, compatibility, IDE bugs, or update mechanism. Try fixing these or manually downloading the update from Arduino's website.
The current Espressif ESP32 core is 2.0.16 but I assume that the Arduino ESP32 core includes more functionality, indeed I am sure that it does, so it is perhaps not a surprise that the two cores are not in step
Are you having any problems that you think might need fixing with an update ?
Am I misunderstanding this?
Isn't that the Arduino ESP Core? Or is it not?
arduino-esp32/releases/tag/2.0.16
Even when I install the Espressif Core I only get v2.0.11.
So. you say the Arduino Core 2.0.13 is the current version? And the Espressif Core 2.0.11 is the current version?
The core versions are generally very mixed up. Shouldn't Espressif actually be doing the development together with Arduino.cc? Then why is Espressif lagging behind the Arduino core? If anything, it should be the other way around.
In IDE 2.3.2 I have the Espressif 2.0.16 core installed. It was updated earlier today
I could also install the Arduino ESP32 2.0.13 core but as I don't have a Nano ESP32 board there is no point in me doing it
The Arduino ESP Core is still up to date with 2.0.13?
I have uninstalled the Espressif Core 2.0.11. I do not get a newer version displayed.
I had understood that both cores are always the same. With the difference that the Arduino core only contains its own Nano ESP32 and everything else is missing.
Additional question.
Why is the C++ standard for the Arduino ESP with gcc 8.4.0 set to C++11? It could be set to C++17 for everyone without any problems.
Hi @Doc_Arduino .
Arduino added the 3rd party "esp32 " boards platform to the index that provides the default list of platforms offered by Boards Manager. This is something Arduino has done from time to time as a favor to people they are partnering on in initiatives related to the partner's boards. Unfortunately the system for keeping this updated is manual and the developers who maintain Arduino's Boards Manager backend infrastructure have not remembered to add entries for the new releases. This is the reason why the 2.0.12-2.0.16 releases of the "esp32 " boards platform are not offered in your Boards Manager.
I have submitted a formal report about the situation to the developers.
For now, if you need to use ESP32 boards (with the exception of the Nano ESP32 , which has a dedicated platform), please use the official installation procedure documented by Espressif (the manufacturer of the ESP32 microcontroller):
https://docs.espressif.com/projects/arduino-esp32/en/latest/installing.html#installing-using-arduino-ide
That is correct.
Arduino's "Arduino ESP32 Boards " platform is a fork of Espressif's "esp32 " platform. This means that the "Arduino ESP32 Boards " platform is based on the "esp32 " platform, but with some modifications (as you noted). It is likely that the maintainers of the "Arduino ESP32 Boards " platform will follow the versioning of the "esp32 " platform in their releases, but that doesn't guarantee that there will be a release of the "Arduino ESP32 Boards " platform in tandem with each release of the "esp32 " platform, for the following reasons:
Making a release is a manual process and it might take some time for the people responsible for such a task find time to do it.
The change set shipped by a given release of the "esp32 " platform might be completely irrelevant to the Nano ESP32 board and thus Arduino might decide that there is no point in making a release of "Arduino ESP32 Boards " for that version, since it would only result in the thousands of Nano ESP32 board users to have to perform a platform update that doesn't actually provide any benefit.
So just make sure to install whatever is the latest version of the "Arduino ESP32 Boards " platform offered by Boards Manager and update it whenever Arduino IDE notifies you a new version is available and you'll be set.
They did you one better and jumped straight to C++20:
committed 02:44PM - 17 Jun 22 UTC
Closes https://github.com/espressif/esp-idf/pull/4846
Related to https://github.… com/espressif/esp-idf/issues/5003
Related to https://github.com/espressif/esp-idf/issues/6885
Related to https://github.com/espressif/arduino-esp32/issues/5859
That change was introduced into the "esp32 " boards platform here:
committed 11:54AM - 05 Oct 23 UTC
* Initial changes to compile under ESP-IDF v5.1
* Initial import for ESP-IDF … v5.1 libs
* Update toolchain
* Update esp32-hal-psram.c
* Add missing LDs
* Update platform.txt
* Stop some CI jobs, because they will always fail
* Fix examples
* Update app_httpd.cpp
* Update ResetReason.ino
* Warnings fixes
* Added the example guideline and template (#7665)
* PR review changes with some typos and grammar fixes
* Changes according to the PR review
* Added ESP32-S3 link to the datasheet (#7738)
* Update HiFreq_ADC.ino
* Replace periph_ctrl.h use because of deprecation
* Replace esp_spi_flash.h use because of deprecation
* Add includes to male mDNS::enableWorkstation compile
* Fix ssl_client mbedtls_pk_parse_key callback
* Update temperature sensor driver
* Allow sketch_utils to compile with arduino-cli
* Run CI with arduino-cli
* Fix arduino-cli CI build on Windows
* Refactor platform.txt to not use components installed through the board manager when running from git
* Initial Peripheral Manager Implementation
* Update SigmaDelta driver to use the new ESP-IDF driver API
* Small improvements to peripheral manager and SigmaDelta
* Remove deleted function from SigmaDelta header
* Update DAC driver to use the new ESP-IDF driver API
* Adds softAp(String) to make it compatible with ESP8266 (#7801)
* Fix commentary (#7800)
Minor fix based on observation done in https://github.com/espressif/arduino-esp32/issues/7795#issuecomment-1416868611
* add adafruit new board feather esp32s2 reserve tft (#7794)
* bugfix: add <stdint.h> for uint8_t to avoid compilation failure (GCC 11.2.0) (#7744)
* Adding 3rd party boards for VALTRACK-V4-VTS-ESP32-C3 & VALTRACK-V4-MFW-ESP32-C3 (#7735)
* Added VALTRACK-V4-VTS-ESP32-C3 board definition
Created pins_arduino.h & made changes to boards.txt with necessary changes
* Modified the URL
* Renamed json
* renamed all auRL
* Adding VALTRACK-V4 series board definitions
Added VALTRACK-V4-VTS-ESP32C3 & VALTRACK-V4-MFW-ESP32-C3 board variants
* Reverted package_esp32_index.template.json
restored package_esp32_index.template.json from edits
Added new line to package_esp32_index.template.json
* Update Platformio CI (#7725)
* WiFiClient example fix (#7711)
* Modified WiFiClient example to use thingspeak instead of non-functionig sparkfun
* Moved instructions to README
* Fixed spelling
* Added link to S3 datasheet
Co-authored-by: Jan Procházka <90197375+P-R-O-C-H-Y@users.noreply.github.com>
* Mirror update from Heltec repository (#7709)
Heltec updated the I2C pins in https://github.com/Heltec-Aaron-Lee/WiFi_Kit_series/commit/b10f4bf85d13fd01be80dcdb0eb59e6a8c8ba19a
* Fixes BLE data printing (#7699)
BLE data has no '\0' terminator, therefore it can't be printed as a regular C string.
This fix just prints the BLE data based on its length.
* Simplify printing to a single call
* split menu options + lora_32_V3 fix (#7697)
* Change header gaurd name (#7696)
* Fix Name (#7691)
Wrong name in definitions.
* Fix error in WiFiClient.cpp where the connect function fails for timeouts below 1 second (#7686)
* Update WiFiClient.cpp
This change will allow specifying connect timeouts below 1 second. Without this change, if connect timeouts under 1 second are given, the connect defaults to 0ms and fails.
This will also allow timeouts in fractions of seconds, e.g. 1500ms. Without this change, connect timeouts are truncated to full second increments.
* Make parameter timeout_ms clear
* Change connection timeout_ms name for clarity
Co-authored-by: Rodrigo Garcia <rodrigo.garcia@espressif.com>
* fixed the function header (#7674)
* fixed function name and paramaters
* Ticker fix solving #6155 (#7664)
* Wrapped Ticker functions with #pragma disabling -Wcast-function-type
* Revert "Wrapped Ticker functions with #pragma disabling -Wcast-function-type"
This reverts commit 160be7e67a10d01b6e44c4bf2521c0ccd6348976.
* Fixed Ticker example
* Modified Ticker example
* Fixed LED_BUILTIN err for ESP32
* setPins fix ESP32 "specified pins are not supported by this chip." (#7646)
[ESP32: SDMMCFS::begin hardcodes the usage of slot 1, only check if the pins match slot 1 pins.]
setPins() was testing pins D1, D2 and D3 all against D1 ... fine in 1 pin mode when all are -1 not so much if you're trying to get 4 pin mode working.
I now see this function doesn't really do anything on the ESP32...accept now correctly checks that you are trying to use the slot 1 pins.
* Allow passing IP as connect method parameter in WiFiClientSecure and skip unnecessary host-ip conversions (#7643)
* Add LED_BUILTIN* definitions and initialization for LEDs to stop them floating. (#7636)
* Expand path to tinuf2 image when checking existence in platformio-build.py (#7631)
* More isFiles fixed
* Remove (useless) trailing semicolon from Print.cpp (#7622)
* ADD: New variant Edgebox-ESP-100 (#7771)
* FIX: Edgebox-ESP-100 Board.txt usb mode option change back to default value as ESP32S3
* Add Crabik Slot ESP32-S3 board (#7790)
* Added Crabik Slot ESP32-S3
* Adding CPU frequency settings and removing excess from partition scheme settings
* new variant LilyGO T-Display-S3 (#7763)
https://github.com/Xinyuan-LilyGO/T-Display-S3
* Add boards.txt definition
Co-authored-by: Me No Dev <me-no-dev@users.noreply.github.com>
* Update get.py to support Apple ARM64
* Update package_esp32_index.template.json
* WString Return bool (#7774)
* Add Roboheart Hercules development board to the esp32-core (#7672)
* added Roboheart Hercules pin definitions and board.txt entries
* added package_roboheat.json for prototyping
* Roboheart Hercules pins
* Updated the pins
* Delete package_roboheart.json
* Requested changes
Co-authored-by: renebohne <rene.bohne@gmail.com>
* Reword "ESP-IDF as Component" (#7812)
I think "Arduino as an ESP-IDF component" or just "As ESP-IDF component" instead of "ESP-IDF as Component" is more correct way to name the link.
1. "ESP-IDF as Component" would imply that ESP-IDF is some sort of library for Arduino, which is (IMO) misleading, because it's true the other way around.
2. It's written as "Arduino as an ESP-IDF component" on the webpage it points to as well.
- Also I removed the capitalization from "Component" as I have not found a reason why is it capitalized.
* add new board Adafruit Feather ESP32-S3 Reverse TFT (#7811)
* Multi threading examples (tasks, queues, semaphores, mutexes) (#7660)
* Moved and renamed example ESP32/FreeRTOS to MultiThreading/BasicMultiThreading
* Added dummy files
* Modified original example
* Fixed BasicMultiThreading.ino
* Added Example demonstrating use of queues
* Extended info in BasicMultiThreading
* Renamed Queues to singular Queue
* Added Mutex example
* Added Semaphore example
* Moved info from example to README
* Moved doc from Mutex to README
* Added Queue README
* Removed unecesary text
* Fixed grammar
* Increased stack size for Sempahore example
* Added headers into .ino files
* Added word Example at the end of title in README
* removed unused line
* Added forgotten README
* Modified BasicMultiThreading example
* Added missing S3 entry in README
* moved location
* Update ESP-IDF libs
* Update CMakeLists.txt
* Update esptool to v4.4
* Add function timerAttachInterruptFlag (#7809)
* Update esptool to v4.5
* ADC refactoring (#7827)
* Adc refactored + periman implementation
Peripheral manager still needs to be checked if the implementation is right.
* switched to working solution for milivolts read
* Periman detachbus fix
* coding style
* fix CI warnings
* fix FreeRTOS example
* Update ETH.cpp
* Update FunctionalInterruptStruct.ino
* Fixes for the latest IDF v5.1
* update esp-idf libs and toolchain
* Turn OFF auto crystal frequency for ESP32 (needed by TWAI)
* Update examples
* Switch build to mostly use flags from files
Includes can not be done this way
* Reorganize flag files
* Optimize chip build flags further
* Revert defines from file. MBEDTLS_CONFIG_FILE does not properly expand
* Add support for includes and defines from file
* Replace old sdk path references in platform.txt
* use gcc-ar (#8013)
* Makes F_CPU generic for all SoC (#8007)
Based on CONFIG_ESP_DEFAULT_CPU_FREQ_MHZ that is correctly defined in the sdkconfig file for each SoC.
* TIMER refactoring (#7904)
* refactor using GPtimer
* Updated timer HW test
* fix examples
* Add v2.0.7 in issue template (#7871)
* fix examples
* Revert "Add v2.0.7 in issue template (#7871)"
This reverts commit fcc3b17d62ff57861f8913ca1f142fd5163b7457.
* Update upload-artifact to v3 in HW CI
* Revert "Update upload-artifact to v3 in HW CI"
This reverts commit 1ba228071718ba37c4e26d98db22f77b2a7364a6.
* replace resolution with frequency
* remove count_down option
* countup removed from examples + header
* Refactored timer object
* code cleanup + examples and tests fixes
* TimerAlarm fix
Co-authored-by: Vojtěch Bartoška <76958047+VojtechBartoska@users.noreply.github.com>
* [Docs] ADC and Timer API Update (+some docs fixes) (#7906)
* updated docs
* remove hall sensor docs
Removed Hall sensor documentation as its no longer supported in IDF-5
* Fixed ESPNow examples location in docs
* Last timer refactored API + gpio small fix
* AlarmWrite fix
* Fixes APLL/PLL with RTC Frequency (#8025)
log_d() was displaying APLL for any SoC, but S3 and C3 has not such option, causing compilation errors.
* Update IDF libs and fix OPI PSRAM on S3
* Add setMode function HardwareSerial.c to set the esp32 uart mode for use with RS485 auto RTS (#7935)
* Added setMode function to set the esp32 uart mode
Used to set the esp32 uart mode for use with RS485 Half Duplex and the auto RTS pin mode. This will set/clear the RTS pin output to control the RE/DE pin on most RS485 chips.
* Add Success (bool) return in some functions
* Add Success (bool) return code to some functions
* Add Success (bool) return to some functions
* Fix uartSetRxTimeout return type
* Add support for esp-elf-gdb
* WFG Crashfix (#8044)
* Update component libs
* IDF release/v5.1 (#8061)
* IDF release/v5.1 bb9200acec
* Update Esp.cpp
* IDF release/v5.1 420ebd208a
* Switch SDK to be an external package
* fix path (#8096)
* Makes UART work at any APB Frequency (#8097)
Fixes HardwareSerial to work with IDF 5.1 on any CPU/APB Frequency (240MHz to 10MHZ), including user created low power modes.
* Add required callbacks for TinyUSB DFU
* Update version to 3.0.0
* Add ESP.getCoreVersion() and update ESP.getChipModel()
* Update timer hal for the latest 5.1
* Use separate RX and TX buffer sizes in HTTP client
optimizes download by allowing up to 4K packets to be received
* Rename clock tree enum name in latest 5.1
* ESP32-H4 support was removed in ESP-IDF v5.1
* IDF release/v5.1 2004bf4e11 (#8165)
* Deinit previous bus first (#8180)
* TIMER - add timer_started flag, fix timerEnd() + timer HW test (#8135)
* Add timer_started flag and stop before disable
* Fix timer HW test
* TOUCH - Peripheral manager implementation (#8129)
* Touch periman implemented
* LEDC Refactoring - Peripheral manager implemented (#8126)
* LEDC periman implementation
* Fix examples
* Rework tone
* Update ledc docs
* fix missing bracket
* Update analog funtions esp32-hal.h
* Update CameraWebServer example
* Fix HiFreq_ADC example
* minor fixes - typos
* Avoid calling tone/notone when tone already runs on dif. pin
* Remove unused channels_resolution
* GPIO - Peripheral manager implementation (#8179)
* periman-implementation
* fix RGB_BUILTIN and remove space
* Enforces more consistency into Peripheral Manager (#8188)
* Avoid log_i() message the first time a bus is assigned
* Prevent operation with ESP32_BUS_TYPE_INIT
* keeps coding style
* do not print messages on INIT bus type
* [Arduino Core 3.0.0] RMT IDF5.1 Refactoring (#7994)
* RMT IDF5.1 refactoring
* Fixes initial value setting
* removed rmtRead() with user callback
* simplify/remove Read data structure
* Deep API simplification
* fixes the examples
* fix rmt.h
* adds support to APB different frequencies
* fixes CI and not defined RGB_BUILTIN
* new RMT API and examples
* fixing commentaties
* Update esp32-hal-rgb-led.c
* changes Filter API
* Fixes example with Filter API
* Update PlatformIO scripts for the upcoming 3.0 core (#8183)
* Dynamically select proper framework-arduinoespressif32-libs package
With this change the dev-platform will be dynamically configured to
pull the latest .zip package with precompiled libraries from extracted from
* free memory on detach (#8264)
* SPI - Peripheral manager implementation (#8255)
* spi periman implementation
* fix header file
* remove unused struct
* fix missing braces
* Update esp32-hal-rmt.c (#8216)
Optimizing Peripheral Manager Test
* I2C - Peripheral manager implementation (#8220)
* i2c-master periman initial commit
* i2c-master make detachbus static + comment remove
* i2c-slave periman implementation
* SetPinBus to INIT on i2cDeinits
* Fix slave pins deinit
* remove dbg logs
* set ret to ESP_FAIL instead of returning
* Fix warnings in hal-spi caused by pariman transition
* Update esptool.py to version 4.6
* Add platform support for ESP_SR
* Add USB Type and valid pin check to periman
* replace bus with spi->num+1 (#8279)
* Remove default pins from SPI HAL
* Add commented out handlers for esptool.js in TinyUSB CDC
For future use
* Add build defines for host os and fqbn (for debug purposes)
* Provide proper memory caps total size
* Update Esp.cpp
* SDMMC - Peripheral manager implementation (#8289)
* sdmmc periman implemented
* save pins when SOC_SDMMC_USE_IOMUX
* IDF release/v5.1 4bc762621d (#8292)
* Adds missing pinMode (#8312)
The example code lacks a pinMode() to initialize the GPIO 0 (button). In Arduino Core 3.0.0, it prints an error message when trying to read a not initialized GPIO.
* Update KeyboardLogout.ino
Adds <buttonPin> to keep code standard
* Update KeyboardReprogram.ino
* LEDC Fade implementation (#8338)
* fade API + pointer fixes
* Add fade api
* Add fade example
* update ledc docs
* remove unused variables
* fix path to example
* Adds USB to Peripheral Manager - Arduino Core 3.0.0 (#8335)
* ETHERNET - Peripheral manager implementation (#8297)
* Peripheral manager implemented
* Add all RMII pins
* fix typo
* Adds HardwareSerial to Peripheral Manager Arduino 3.0.0 (#8328)
* Do not limit ETHERNET in periman to only ESP32. SPI is also an option
* Initial support for ESP32-C6 (#8337)
* Add checks for SOC defines (#8351)
* Add SoC checks to BLE library
* fix i2c compilation error
* fix wrong placement of include
* add check to SPI library
* add check to USB library
* add checks to Wire library
* Feature/esp32h2 support (#8373)
* Initial support for ESP32H2
* Additional changes for ESP32H2
* Update libs for ESP32H2
* Fix flashing on ESP32-H2
* Fix GPIO Configs for ESP32-C6 and ESP32-H2
* Update Timer test sketch
* Fix upload flash parameters
* Use ets_write_char_uart instead of ets_printf in log_printfv
* Print full chip report when log level is sufficient (#8282)
* ESP32-C3 does not have ets_write_char_uart
* Fix BLE gap event name
* HW Testing - Pytest update (#8389)
* update tests requirements
* remove already handled components
* Update version of pytest
* Add missing ESP32-H2 to hil.yml
* Updated FreeRTOS names (#8418)
* HW Testing - ESP32-C6 + ESP32-H2 fixes (#8404)
* add C6/H2 to tests cfg.json
* remove ,
* workflow runs-on runner by matrix
* Add need for arduino tag to select runner
* Add cryptography to requirements.txt
* Removed duplicate TX1 define for H2 (#8402)
* Fix broken examples
* Fixes RMT filter & idle timing and setup (#8359)
* Fixes Filter and Idle parameter to uint32
* Fixes Filter and Idle setup
* Fixes it to 5.1Libs branch
* fix RMT CLK source and Filter API
* fixes missing ;
* fixes missing ;
* fixes RMT example
* IDF release/v5.1 a7b62bbcaf (#8438)
* Add workflow to build executables from python scripts (#8290)
* Push binary to tools
* Enable executable signing on Windows
* Update get.py
* Try with multiple files
* Try more actions
* Try powershell
* Restore tools so they do not get rebuilt
* Finalize scripts
* App rollback should be after PSRAM is initialized
* Correcting RX1 to GPIO4 and TX1 to GPIO5 to be consistent with documentation. Previous pin use works but is inconsistent with C6 docs.
* Fixes Memory Leak (#8486)
* fixes preprocessor test (#8485)
When using `#define USE_SOFT_AP`
Change
`&& not USE_SOFT_AP` ==> `&& !defined(USE_SOFT_AP)`
* Adds any BLE capable device in WiFiProv.ino
Removing ESP32 restriction for BLE Provisioning.
* fix flash mode read out for C6
* Add option for custom partitions without restrictions
* SD_MMC update (#8298)
* Updated SD_MMC lib and examples
* Removed getter implementation and commented usage in examples
* squashed updates
* IDF release/v5.1 f0437b945f (#8599)
* Fix printf format build error in BTAdvertisedDeviceSet.cpp
Co-authored-by: Pedro Minatel <pedro.minatel@espressif.com>
Co-authored-by: Ha Thach <thach@tinyusb.org>
Co-authored-by: Martin Turski <quiret@vfemail.net>
Co-authored-by: raviypujar <raviypujar@gmail.com>
Co-authored-by: Jason2866 <24528715+Jason2866@users.noreply.github.com>
Co-authored-by: Tomáš Pilný <34927466+PilnyTomas@users.noreply.github.com>
Co-authored-by: Daniel Berlin <dberlin@dberlin.org>
Co-authored-by: Nima Askari (نیما عسکری) <nimaltd@yahoo.com>
Co-authored-by: rtpmsys <106180646+rtpmsys@users.noreply.github.com>
Co-authored-by: bytiful <55647551+bytiful@users.noreply.github.com>
Co-authored-by: tmfarrington <tmfarrington@users.noreply.github.com>
Co-authored-by: Krzysiek S <chris.streh@gmail.com>
Co-authored-by: surt <carl.olsson@gmail.com>
Co-authored-by: Max Scheffler <max.scheffler@pm.me>
Co-authored-by: Clemens Kirchgatterer <clemens@1541.org>
Co-authored-by: Peter Pan's Techland <twinkle-pirate@hotmail.com>
Co-authored-by: Roman <programmeofficemilkyway@gmail.com>
Co-authored-by: Eistee <Eistee82@users.noreply.github.com>
Co-authored-by: David McCurley <44048235+mrengineer7777@users.noreply.github.com>
Co-authored-by: Gaya3N25 <30388176+Gaya3N25@users.noreply.github.com>
Co-authored-by: Olivér Remény <25034625+remenyo@users.noreply.github.com>
Co-authored-by: davidk88 <david.kotar@gmail.com>
Co-authored-by: James Armstrong <jamesarmstrong3@me.com>
Co-authored-by: Valerii Koval <valeros@users.noreply.github.com>
Co-authored-by: Peter G. Jensen <root@petergjoel.dk>
That is not included in the 2.0.16 releases. Despite your "without any problems" assurance this change is indeed potentially disruptive and so the maintainers of the "esp32 " boards platform have decided that it will be released as part of a major version bump 3.0.0. Pre-release versions of "esp32 " platform version 3.0.0 are already available for beta testing, and those versions of the platform do have support for the Nano ESP32 board so you are welcome to give the pre-release a try (keeping in mind that it is only intended to allow the community to contribute to the development effort through beta testing; no for everyday use, and that there is no guarantee of stability or official support from Arduino for pre-release users).
You can get the pre-release version of the "esp32 " boards platform by following the installation instructions I mentioned earlier in this post, but using the "development release link" URL provided in those instructions instead of the "stable release link" URL as we normally use.
Looking further, I see they have actually now moved even further to C++23:
committed 04:01PM - 20 Mar 23 UTC
