no data from one wire temp sensor in complex setup
Hi there,
I have a due with a spi tft screen attached there is also a RTC hooked up and there are als two ds1820 hooked to the board.
When i run a example scetch for the one wire temperature it is fine.
when i run my sketch i don't get any temperature reading.
below is my code:
// UTFT_Demo_320x240
// Copyright (C)2015 Rinky-Dink Electronics, Henning Karlsen. All right reserved
// web: http://www.RinkyDinkElectronics.com/
// This program is a demo of how to use most of the functions
// of the library with a supported display modules.
// This demo was made for modules with a screen resolution
// of 320x240 pixels.
// This program requires the UTFT library.
#include <UTFT.h>
#include <DS3231.h>
#include <OneWire.h>
#include <DallasTemperature.h>
#define TFTcs   PIN_SPI_SS0  //CS - CE            (pin 77)
#define TFTsclk PIN_SPI_SCK  //hw SPI - SCK       (pin 76)
#define TFTmosi PIN_SPI_MOSI //hw SPI - SDA - DIN (pin 75)
#define TFTdc   49           //A0 - DC - RS - D/C
#define TFTrst  48           //RESET
#define ONE_WIRE_BUS A6
#define TEMPERATURE_PRECISION 9
// Init the DS3231 using the hardware interface
DS3231  rtc(SDA, SCL);
// Setup a oneWire instance to communicate with any OneWire devices (not just Maxim/Dallas temperature ICs)
OneWire oneWire(ONE_WIRE_BUS);
// Pass our oneWire reference to Dallas Temperature.
DallasTemperature sensors(&oneWire);
// Init a Time-data structure
Time  t;
String test;
String temp;
// Declare which fonts we will be using
extern uint8_t SmallFont[];
// Set the pins to the correct ones for your development shield
// Arduino Uno / 2009:
// Standard Arduino Uno/2009 shield            : <display model>,A5,A4,A3,A2
// DisplayModule Arduino Uno TFT shield        : <display model>,A5,A4,A3,A2
// Arduino Mega:
// Standard Arduino Mega/Due shield            : <display model>,38,39,40,41
// CTE TFT LCD/SD Shield for Arduino Mega      : <display model>,38,39,40,41
// Remember to change the model parameter to suit your display module!
// UTFT(byte model, int RS, int WR, int CS, int RST, int SER=0);
//UTFT myGLCD(CTE32,25,26,27,28);
UTFT myGLCD(TFT01_18SP,TFTmosi,TFTsclk,TFTcs,TFTrst,TFTdc);
  randomSeed(analogRead(0));
// Initialize the rtc object
  sensors.begin();
  rtc.begin();
// Setup the LCD
  myGLCD.InitLCD();
  myGLCD.setFont(SmallFont);
  // Clear the screen and draw the frame
  myGLCD.clrScr();
  myGLCD.setColor(255, 255, 255);
  myGLCD.print("Tijd   :", LEFT, 1);
  myGLCD.print("Dak    :", LEFT, 20);
  myGLCD.print("Water  :", LEFT, 30);
  myGLCD.print("Inloop :", LEFT, 40);
  t = rtc.getTime();
  test = "  " + String(t.hour) + ":" + String(t.min) + ":" +String(t.sec) ;
  myGLCD.print(test, RIGHT,1);
  sensors.requestTemperatures(); // Send the command to get temperatures
  temp = String(sensors.getTempCByIndex(0));
  myGLCD.print(temp , RIGHT, 20);
  delay (1000);
What have you done differently ? Do you mean that you don't get any temperature readings (check with Serial.print()) or that you don't get them on the TFT ?
My Due does not have 77 pins. I'm betting that yours doesn't either.
My 'what' doesn't have 77 pins?
Doc
Docedison:
Doc
Stupid fat fingers... 8)
.. Mine too more than often..
Doc
You are correct, there isn't a pin 77, that is connected to pin 70.
all parts seperatly work, the tft and the rtc timer are working but not the temperatuur reading.
not even on the serial monitor.
i copyed the sample code over to my application, but some how it doesn't work.
Where or What could be wrong,i tryed a different one wire pin. nothing better happens in that case.
for now i'm pretty stuck.
By themselves, with the TFT securely locked in a drawer, do the temperature sensors/code work?
