No data on the serial monitor with ARDUINO LEONARDO
Hello,
I'm new on using Arduino, and I bought at first and Arduino UNO, to make a sim racing wheel, using an incremental optical encoder 600 P/r.
I found the code attached that I used to check if the encoder was sending the right values on the serial monitor and it worked, connecting the encoder +5V and GND to +5v and GND of arduino and signal A to digital pin 2 and signal B to digital pin 4. I added also a button to reset to zero the counter.
I decided then to buy and Arduino Leonardo to use the library Joystick 2.0 and make it work with my PC games, but before start to work on the new code, I wanted to see if the new Arduino was reading same values of Arduino UNO.
I connected the encoder in the same pins and used the same code (no errors in uploading), but I was not able to see any value on the serial monitor.
The PC I'm using is a WIN10.
I tried to find a solution to the problem but I didn't find any clue that helped me. I guess it must be some problem in the comunication on the serial port.
Could you please hlep me?
Thanks!
The code is the following:
//   Programma che utilizza un rotary encoder a quadratura
// ......::  M O D A L I T A'   I N T E R R U P T   ::......
#define encoderCLK 2 // CLK (canale A) connesso al pin D2
#define encoderDT 4  // DT (Canale B) connesso al pin D4
#define encoderSW 3  // SW (bottone) connesso al pin D3
#define interrupt0 0 // Associato al pin 2 di Arduino
#define interrupt1 1 // Associato al pin 3 di Arduino
int encoderCount = 0; // Contatore
int actCLKState;      // Lettura attuale del canale CLK (A)
int prevCLKState;     // Lettura precedente del canale CLK (A)
    // I pin sono impostati come ingresso
    pinMode(encoderCLK, INPUT_PULLUP);    // interrupt 0
    pinMode(encoderDT, INPUT_PULLUP);
    // Setto la resistenza di pull-up - E' equivalente a:
    // pinMode(encoderSW, INPUT);
    // digitalWrite(encoderSW, HIGH);
    pinMode(encoderSW, INPUT_PULLUP); // interrupt 1
    // Attivo l'interrupt 0 quando lo stato del canale CLK "cambia" poiche'
    // questo devo effettuare la lettura di DT ad ogni variazione di CLK
    attachInterrupt(interrupt0, CLKChanged, CHANGE);
    // Imposto l'interrupt 1 sul fronte di discesa poichè quando premo il pomello dell'encoder
    // il segnale (canale SW) da alto diventa basso
    // A) Se metto RISING la routine di interrupt viene eseguita quando rilascio il pomello;
    //    Se provo a ruotare premendo contemporaneamente il pomello osservo che il contatore
    //    visualizzato sul Serial Monitor non si azzera fino a quando non rilascio il pomello
    // B) Se mettessi CHANGE eseguo la routine di interrupt sia quando premo, sia quando rilascio
    //    il pomello. Se imposto l'interrupt su CHANGE e provo a premere il pomello
    //    osservo che il contatore si azzera! Se continuo la rotazione, mantenendo premuto
    //    il pomello dell'albero, noto che il contatore si riazzera solo quando rilascio il pomello
    attachInterrupt(interrupt1, SWPressed, FALLING);
    // inizializza la comunicazione seriale a 9600 bit per secondo:
    // Memorizzo l'ultimo stato del canale CLK
    prevCLKState = digitalRead(encoderCLK);
void loop() {}
// Routine relativa alla rotazione dell'albero associata all'interrupt 0
void CLKChanged()
    int actCLKState = digitalRead(encoderCLK);// Leggo il canale A (CLK)
    // Questo if serve per gestire chiamate multiple alla routine di interrupt
    // causate dal cosiddetto bouncing: ogni volta che si ruota l'albero vengono
    // in realtà generate diverse variazioni (per ognuna viene scatenato
    // l'interrupt!), dovute al funzionamento meccanico del rotore. Si possono
    // determinare effetti indesiderati come ad esempio la ripetizione di numeri
    // ma con questo IF vengono evitati.
    if (prevCLKState != actCLKState)
        * Per determinare il verso della rotazione occorre leggere DT (B)
        * Se i 2 canali CLK e DT sono uguali la rotazione è oraria
        * Se i 2 canali CLK e DT sono diversi la rotazione è antioraria
        encoderCount += (actCLKState == digitalRead(encoderDT) ? 1 : -1);
        Serial.println(encoderCount);
        prevCLKState = actCLKState;
// Routine relativa alla pressione sull'albero associata all'interrupt 1
void SWPressed()
    // causate dal cosiddetto bouncing: ogni volta che si preme un pulsante reale
    // vengono in realtà generate diverse pressioni e rilasci (per ognuno dei quali
    // viene scatenato un interrupt!), dovute al funzionamento meccanico del pulsante.
    // Lo stesso accade anche quando lo si rilascia.
    if (encoderCount != 0)
        encoderCount = 0;
Encoder_ok.ino (4.9 KB)
Compare the interrupt pins used by the Uno and Leonardo and the associated interrupt numbers and note the differences
Could that be your problem ?
See attachInterrupt() - Arduino Reference
Always use digitalPinToInterrupt():
    attachInterrupt(digitalPinToInterrupt(encoderCLK), CLKChanged, CHANGE);
See: attachInterrupt() - Arduino Reference
Thank you
johnwasser and UKHeliBob
It worked! Problem solved!
