No date-time information of .csv file creation in SD card folder
I am using arduino Uno for displaying 100g load cell value in .96 OLED display . Communication is through I2C. I am using HX711 as ADC.
I am saving milisecond passed, current date and time, current load cell value and max load cell value in a csv file. Currently, the files are named as 00.csv, 01.csv like this. All the values inside csv files are correct including date and time.
I need to have csv creation date and time information in SD card folder, so that in future whenever I need to find a specific file for a certain date and time, I can find it easily.
I am thinking of having date time information with csv file in either of the two way. /appending timestamp with file name
  1. have date and time with my file name, like 101122_2.35pm.csv
    or
  2. have file creation date and time in SD card folder.
I tried second way using callback function in setup(). But this is not working in my case. I am not seeing any date time information in SD folder after file is being created.
My current code with callback function and SD card screenshot is attached.
Can anyone please help me in this problem? I am really stuck and do not know how to proceed.
//TIME IS RIGHT INSIDE CSV FILE, MAX VALUE RIGHT, DIAPLAY RIGHT WITH THIS PROGRAM AS OF 10/11/2011
//check font here: https://github.com/olikraus/u8g2/wiki/fntlist8x8
#include <Arduino.h>
#include <U8x8lib.h>
#ifdef U8X8_HAVE_HW_SPI
  #include <SPI.h>
#endif
#ifdef U8X8_HAVE_HW_I2C
  #include <Wire.h>
#endif
#include <SD.h>
#include "RTClib.h"
#include "HX711.h"  //You must have this library in your arduino library folder
#define DURATION 0.0133333 //1 minutes in hours                 //Number of minutes, expressed/converted into hours, here 2 hours you want this program to run once the button is pressed
#define LOG_INTERVAL 200            //Milliseconds between entries (reduce to take more/faster data)
#define SYNC_INTERVAL 50          // millis between calls to flush() - to write data to the card
#define ECHO_TO_SERIAL 1            //Echo data to serial port, Easy method to turn serial printing on and off. Set to 0 if you don't want to print to the Serial Monitor
uint32_t syncTime = 0;              // time of last sync()
uint32_t start_time;
RTC_DS1307 RTC;                     //define the Real Time Clock object
const int chipSelect = 10;          //SD chip select;for the data logging shield, we use digital pin 10 for the SD cs line
char timestamp[30];
const int pushbutton = 8;
const int done_light = 9;
float maxi = 0;
/***All the variables for voltage reading function***/
//the logging file
File bhoomiFile;
//-------------------Hx711 pins-----------------------------------------------
#define DOUT  3
#define CLK  2
HX711 scale;
float calibration_factor = 7037.143066;//7311.899902; //7383.399902;//7370.040039; //7370.379882; // for 100g load cell
//--------------------DISPLAY--------------------------------------------------
U8X8_SSD1306_128X64_NONAME_HW_I2C u8x8(/* reset=*/ U8X8_PIN_NONE);
unsigned int year;
byte month, day, hour, minute, second;
//This function returns the date and time for SD card file access and modify time.
void dateTime (uint16_t* date, uint16_t* time){
  *date = FAT_DATE(year, month, day);
  *time = FAT_TIME(hour, minute, second);
   }  // end of dateTime
//------------------------SETUP--------------------------------------------
void setup(){
  scale.begin(DOUT, CLK);
  Serial.begin(9600);                         //Initialize the serial communication
  u8x8.clear();
  u8x8.begin();
  Wire.begin();                              //Wire.begin: Initiate the Wire library and join the I2C bus as a master or slave.
  Serial.println("Press T to tare");
  scale.set_scale(calibration_factor);       //Calibration Factor obtained from first sketch
  scale.tare();                              //Reset the scale to 0
        #if ECHO_TO_SERIAL
          Serial.println("Press button to start");                                //Prompt user to press button
        #endif
  pinMode(pushbutton, INPUT);                 //Set pushbutton as Input
  pinMode(done_light, OUTPUT);                //Set the LED as an output
  digitalWrite(done_light, LOW);              //Make sure the LED is off when we start the program
  while (digitalRead(pushbutton)) {};  //Wait for pushbutton input
        #if ECHO_TO_SERIAL
          Serial.println("(BUTTON PRESSED!)"); //Once pressed, display a message saying so
        #endif
  SD_INIT();
  SdFile::dateTimeCallback(dateTime);
  createFile();
  //-----------------connect to RTC----------------------------------------------------
  if (!RTC.begin()){                    //RTC.begin initializes the internal RTC. It needs to be called before any other RTC library methods
      bhoomiFile.println("RTC failed");
  //if (! RTC.isrunning())
  //     Serial.println("RTC is NOT running, let's set the time!");
  //     // When time needs to be set on a new device, or after a power loss, the following line sets the RTC to the date & time this sketch was compiled
  //     RTC.adjust(DateTime(F(__DATE__), F(__TIME__))); //This line sets the RTC with an explicit date & time, for example to set
                                                         //RTC.adjust(DateTime(2014, 1, 21, 3, 0, 0));  January 21, 2014 at 3am you would call:
   bhoomiFile.println("millisecond,Time (MM/DD/YYYY HH:MM:SS), weight (g), Max weight(g)");        //If RTC initializes successfully...set this as a header in the file
        #if ECHO_TO_SERIAL
          Serial.println("millisecond,Time (MM/DD/YYYY HH:MM:SS), weight (g), Max weight(g)");
        #endif //ECHO_TO_SERIAL
   start_time = millis();              //The very next step after this will be the data recording
//-------------------------------LOOP---------------------------------------------------------------
void loop(){
  for (start_time; (millis() - start_time) < (DURATION * 60 * 60 * 1000L); ) //Below: As long as current time - start time < required duration, keep recording the data
        //To have record time in HOURS: (DURATION * 60 * 60 * 1000L)
  doTheThing();
  u8x8.clear();
  while (1)  {
    #if ECHO_TO_SERIAL
        Serial.println("ALL DONE");           //Once the set amount of time has passed, display message saying so
    digitalWrite(done_light, HIGH);
    //-------DISPLAY MAX VALUE--------
    u8x8.setFont(u8x8_font_8x13B_1x2_f); // big font
    u8x8.setCursor(0, 32);
    u8x8.print("          g Max   ");                  //Unit in gram
    u8x8.print(maxi, 3);  //read upto 4 decimal point
    //-------DISPLAY STORING DONE INFORMATION--------
    u8x8.setCursor(0, 2);
    u8x8.print(" Done storing ");
    u8x8.setCursor(0, 5);
    u8x8.print(" 2 min ");
//------------------------------------FUNCTIONS-------------------------------------------
void error(char *str){
  Serial.print("error: ");
  Serial.println(str);
  while (1);
//-----------------------FUNCTION SD CARD INITIALIZATION---------------------------------------
void SD_INIT(){
  Serial.print("Initializing SD card...");
  pinMode(chipSelect, OUTPUT);
  Serial.println("card initialized.");                            //If SD.begin is successful
  //Check if the card is present and can be initialized:
  if (!SD.begin(chipSelect))  {                                  //SD.begin initializes the SD library and card; Returns 1 on success, 0 on failure
       u8x8.setFont(u8x8_font_courR18_2x3_r);
       u8x8.setCursor(3, 19);
       u8x8.println("No SD");
       return;
//-----------------------FUNCTION FILE CREATION--------------------------------------------------
void createFile(){
      char filename[] = "00.CSV";
      for (uint8_t i = 0; i < 200; i++)  {                               //Make a new file every time the Arduino starts up, Goes from 00 to 199
          filename[0] = i / 10 + '0';
          filename[1] = i % 10 + '0';
          if (!SD.exists(filename)) {                                    //SD.exists() tests whether a file or directory exists on the SD card
              bhoomiFile = SD.open(filename, FILE_WRITE);                //SD.open() opens a file on the SD card. If the file is opened for writing,
        //it will be created if it doesn't already exist (but the directory containing it must already exist).
        //FILE_WRITE enables read and write access to the file
              break;  // leave the loop!
      if (!bhoomiFile){                                                  //If file couldn't be opened/created
              error("couldn't create file");
      //-----------LOG FILE NAME BOTH IN SERIAL PORT AND DISPLAY-----
      Serial.print("  Logging to: ");                                   //Otherwise, display the name of the file generated
      Serial.print(filename);
      u8x8.setCursor(2, 22);
      u8x8.print(filename);
      delay(20);
//-----------------------FUNCTION DO THE THING---------------------------------------
void doTheThing() {  /*uncomment lower IF statement if you want to set up time for your RTC. IF the RTC battery is being removed,
                     it will set the time to 1/1/00 like this. But after uncommenting and compiling,complilation time will be current time and clock will start acting*/
  //   if (! RTC.isrunning())
  //             // following line sets the RTC to the date & time this sketch was compiled
  //             // This line sets the RTC with an explicit date & time, for example to set
  //             // January 21, 2014 at 3am you would call:
  //             // rtc.adjust(DateTime(2014, 1, 21, 3, 0, 0));
    DateTime now = RTC.now();
    //delay((LOG_INTERVAL - 1) - (millis() % LOG_INTERVAL));//delay for the amount of time we want between readings
    //sprintf(timestamp, "%02d:%02d:%02d %2d/%2d/%2d \n", now.hour(), now.minute(), now.second(), now.month(), now.day(), now.year() - 2000);
    //Serial.println(timestamp);
    bhoomiFile.println(); //WITHOUT THIS INSTRUCTION,CSV DATA WILL BE SAVED  ROWWISE,, NOT COLUMNWISE
    //--------LOG ALL MILISECOND IN ONE COLUMN IN CSV FILE--------
    bhoomiFile.print("");
    bhoomiFile.print(millis(), DEC);
    bhoomiFile.print(" , ");
    //--------LOG DATE& TIME IN ANOTHER COLUMN IN CSV FILE--------
    bhoomiFile.print("  ");                  //This space is important. If you remove this, the seconds will not be recorded in the log file
    bhoomiFile.print(now.month(), DEC);
    bhoomiFile.print("/");
    bhoomiFile.print(now.day(), DEC);
    bhoomiFile.print(now.year(), DEC);
    bhoomiFile.print(now.hour(), DEC);
    bhoomiFile.print(":");
    bhoomiFile.print(now.minute(), DEC);
    bhoomiFile.print(now.second(), DEC);
    //---------- Log LOAD CELL MAXIMUM reading---------------------------
    bhoomiFile.print(", ");                           //Unit in gram
    float currentReading = scale.get_units();
    bhoomiFile.print(currentReading * 1, 4);        //read upto 4 decimal
      if (currentReading < maxi)  {
        maxi = maxi;
      else if (currentReading >= maxi)  {
        maxi = currentReading;
    //----LOG LOAD CELL MAX READING IN CSV FILE AND DISPLAY ---------------
    bhoomiFile.print(maxi, 4);      //read upto 4 decimal
    u8x8.setFont(u8x8_font_8x13B_1x2_f);//small font
    u8x8.setCursor(0, 3);
    //----LOG LOAD CELL IN CSV FILE AND DISPLAY LOAD CELL MAX READING---------------
          #if ECHO_TO_SERIAL
            Serial.print(", ");
            Serial.print(scale.get_units() * 1, 4);       //read upto 4 decimal
            Serial.print("g ");                           //Unit in gram
    u8x8.setFont(u8x8_font_courR18_2x3_r); // big font
    u8x8.setCursor(90, 32);
    u8x8.print("         g ");                 //Unit in gram
    u8x8.print(scale.get_units() * 1, 3);  //read upto 4 decimal point
          #if ECHO_TO_SERIAL
            Serial.print(", ");
            Serial.print(maxi, 4);      //read upto 4 decimal
    delay(100);
    //--------------CLOSE CSV FILE BY FLUSHING---------------------------------------
    if ((millis() - syncTime) < SYNC_INTERVAL) return;
    syncTime = millis();
    bhoomiFile.flush();               //flush() ensures that any bytes written to the file are physically saved to the SD card
                                      //When you use file.write(), it doesn't write to the card until you flush() or close().
                                      //Whenever you open a file, be sure to close it to save your data.
csv file.pdf (6.0 KB)
In your callback function dateTime(), you use the global variables year, month, day, hour, minute, second but nowhere in the code do you every assign anything to these variables so they are always 0.
@blh64, You are right. I assigned some year,month...second value. Then I saw that specific date time as file creation time. But I need to have real file creation time.
I changed that portion so that date time is collected from RTC. But somehow after using it, I am not getting anything in my display. I have attached my code for your kind suggestion. What can I do to make it work?
//TIME IS RIGHT INSIDE CSV FILE, MAX VALUE RIGHT, DISPLAY RIGHT WITH THIS PROGRAM AS OF 10/11/2011
//trying to fix sd folder date time
  #include <SPI.h>
#endif
  #include <Wire.h>
#endif
#include <SD.h>
#include "RTClib.h"
char timestamp[30];
float maxi = 0;
//the logging file
File bhoomiFile;
#define DOUT  3
#define CLK  2
HX711 scale;
void dateTime(uint16_t* date, uint16_t* time) {
  // return date using FAT_DATE macro to format fields
  *date = FAT_DATE(now.year(), now.month(), now.day());
  // return time using FAT_TIME macro to format fields
  *time = FAT_TIME(now.hour(), now.minute(), now.second());
void setup(){
  u8x8.clear();
  u8x8.begin();
        #if ECHO_TO_SERIAL
        #endif
        #if ECHO_TO_SERIAL
        #endif
  SD_INIT();
  createFile();
//  if (! RTC.isrunning())      {
//                                                         //RTC.adjust(DateTime(2014, 1, 21, 3, 0, 0));  January 21, 2014 at 3am you would call:
//  RTC.adjust(DateTime(F(__DATE__), F(__TIME__)));        //When time needs to be re-set on a previously configured device, this
                                                         //  sets the RTC to the date & time this sketch was compiled
        #if ECHO_TO_SERIAL
void loop(){
  doTheThing();
  u8x8.clear();
  while (1)  {
    #if ECHO_TO_SERIAL
  while (1);
void SD_INIT(){
       return;
void createFile(){
      delay(20);
      //add an open and close here
      bhoomiFile.close();
        maxi = maxi;
          #if ECHO_TO_SERIAL
            Serial.print(", ");
          #if ECHO_TO_SERIAL
            Serial.print(", ");
    delay(100);
I don't see any changes to any of the display code. Did you try just printing something to the display in setup() after you initialize it?
What does your serial output look like?
@blh64 ,
yes, I tried to print "millisecond,Time (MM/DD/YYYY HH:MM:SS), weight (g), Max weight(g)" in SETUP, but it looks like before reaching to that line, due to SdFile::dateTimeCallback(dateTime) , the code is getting aborted and starting again and it is going on in loop.
Very strange!!!!!!!
Because, I just added DateTime now = RTC.now(); inside void dateTime(uint16_t* date, uint16_t* time) and all that happed. Before that, serial moitor was displaying whatever asked to display, OLED display was displaying everything as asked in code, csv file elements were fine.
That is odd. I would guess it is time to do some debugging....
Try this:
//  DateTime now = RTC.now();
  DateTime now = DateTime(2022, 10, 12, 8, 30, 45);
Does it work? If so, there is something about reading the RTC within that function.
If it still resets the controller, try this:
  *date = FAT_DATE(2022, 10, 12);
  *time = FAT_TIME(8, 30, 45);
If that works, then it is one of the function calls (odd). You could also try it with all 0's for year, month, etc.
I tried first one and it works. That means , when I assign some value, there is no reset. And the folder assigns the value as file creation time in SD card folder.
