No device found on ttyACM0 - Arduino Nano 33 BLE
Failed to upload a sketch on the Arduino Nano 33 BLE. The compilation works fine.
but this error occurred :
Failed uploading: uploading error: exit status 1
I try to do like that Can not upload to Arduino Nano BLE 33
but it doesn't work.
Not familiar with your board. Do you get the pulsating LED when you double tap the reset?
Yes, the LED was pulsating when I double tapped the reset button.
I solved the problem by downloading the Arduino IDE on Windows, and there everything works.
However, I still have the error when uploading the same code on the Arduino board on Debian.
Did you add yourself to the dialout?
SOLVED
in terminal:
sudo usermod -a -G dialout <user_name>
