hello all from a newcomer. i am reading an analog input on A0. it comes from a pot and represents direction. the result(0 to 1023) is divided by 2.841 ie. 1023/360 degrees.it works fine but the numbers after the decimal point are meaningless so i dont need them. i have reaaly tried.
Can't see your code.
Hello and welcome
Use function round() to round a float to nearest whole value, then cast to an int.
int intVal = (int)round( floatVal );
Edit: also have a look at the function map()
i am running "analog read serial" which is pre written by others
Can we please at least have a clue as to what that means ?
Better still, let's see the program.
I don't see 2.841 in that sketch.
Please don't make us hunt for your code.
"Always" attach you code using the </> icon in the posting menu.
// read the input on analog pin 0:
// print out the value you read:
Serial.println(sensorValue);/2.8416);
delay(2000); // delay in between reads for stability
} new to the forum too hope this works
BTW I am displaying it on a monitor ( for now)
sorry, i am trying to get used to Arduino and also the forum. here is the complete code
AnalogReadSerial
Reads an analog input on pin 0, prints the result to the serial monitor.
Attach the center pin of a potentiometer to pin A0, and the outside pins to +5V and ground.
This example code is in the public domain.
// the setup routine runs once when you press reset:
// initialize serial communication at 9600 bits per second:
// the loop routine runs over and over again forever:
int sensorValue = analogRead(A0);
Serial.println(sensorValue/2.481);
AnalogReadSerial
Serial.println(sensorValue * 0.3519, 0);
joemurphy:
Sounds like you need the map() function.
This can be rearranged with simple arithmetic.
Instead of dividing by 1023/360, try multiplying by 360/1023.
int angle = (sensorValue * 360L) / 1023;
Just so you know: the "L" after the 360 is because an int cannot hold numbers larger than 32767. If you try to multiply, for example, 200 by 360, you will get a garbage answer (6464 instead of 72000) unless you use a larger datatype such as a long. The "L" after the "360" tells the compiler that you want it treated as a long.
