No display
i have tried to customize one of the sketch available on internet according to my requirements but the problem is that even when the programme has compiled i’m not getting anything on the display. i have checked all the wiring and has not find any problem with them al the examples are working well. please help me to figureout the problem. thanks
kiwi.ino (18.2 KB)
If the LCD works in the examples does this program use the same pins as the examples ?
/*  The circuit:
 * LCD RS pin to digital pin 13
 * LCD Enable pin to digital pin 12
 * LCD D4 pin to digital pin 11
 * LCD D5 pin to digital pin 10
 * LCD D6 pin to digital pin 5
 * LCD D7 pin to digital pin 4
 * LCD R/W pin to ground
 * 10K resistor:
 * ends to +5V and ground
 * wiper to LCD VO pin (pin 3)*/
Try printing a message to the LCD in setup(). Do you see it ?
Which kind of LCD display are you using...is it an I2C version?
UKHeliBob: If the LCD works in the examples does this program use the same pins as the examples ?
/*  The circuit:
 * 10K resistor:
yes the example uses the same set of pins.
econjack: Which kind of LCD display are you using...is it an I2C version?
it's a 20x4 display,using 6 input pins.
Did you
i did try, but the sketch didn't compiled. was getting the "error: 'lcd' does not name a type:"
I can feel the goalposts moving.
Please post the program you used when you tried to print to the LCD in setup. Don't bother with any code in loop() as this is not relevant at the moment.
