No error in compiling,but program still not working
#include <Servo.h>
#include <PS2X_lib.h>
#define PS2_DAT        13  //14
#define PS2_CMD        11  //15
#define PS2_SEL        10  //16
#define PS2_CLK        12  //17
#define rumble      false
#define pressures   true
PS2X ps2x; // create PS2 Controller Class
int error = 0;
Servo myservo;
int pos = 0;
void setup(){
  Serial.begin(57600);
   error = ps2x.config_gamepad(PS2_CLK, PS2_CMD, PS2_SEL, PS2_DAT, pressures, rumble);
   if(error == 0){
    Serial.print("Found Controller, configured successful ");
   myservo.attach(9);
 if(error == 1) //skip loop if no controller found
    return;
  if(ps2x.Button(PSB_L2)){
    for(pos = 0; pos < 180; pos += 1)  // goes from 0 degrees to 180 degrees
  {                                  // in steps of 1 degree
    myservo.write(pos);              // tell servo to go to position in variable 'pos'
    delay(15);                       // waits 15ms for the servo to reach the position
  if(ps2x.Button(PSB_R2)){
     for(pos = 180; pos>=1; pos-=1)     // goes from 180 degrees to 0 degrees
I want to control servo with a ps2 controller ,but code isn't working though there is no error according to compiler. I've already checked wiring....Any suggestions ?? :confused: :relaxed:
Presumably it returned error 0 and you got "Found Controller, configured successful" in the monitor?
I'd recommend putting serial prints in the "legs" of the ifs, so you can see where the logic is taking you, ie see if it's reading the buttons properly.
Put in some more Serial.println() statements so you you can see if values are what you expect. Then post your revised code and tell us what they say. "Not working" does not convey any useful information.
...R
What does happen when you run the program ?
Which parts of it are running ? Put some Serial.print() messages at key points and print relevant variables.
Did you check the wiring against the pin numbers in the #defines or the ones in the comments ?
Okay i'll try again with some more "serial.print" Thanks for help :smiley:
Did you get this "Found Controller, configured successful" though?
#include <Servo.h>
int error = 0;
Servo myservo;
int pos = 0;
void setup(){
   if(error == 0){
   myservo.attach(9);
 if(error == 1){
    Serial.println("No controller found,check wiring");
    return;                           //Skip loop if no controller found
    Serial.println("L2 pressed");
    Serial.println("R2 pressed");
i made some changes in my code and added some "serial print",and i found that its not reading L2 and R2 as i got no message on serial monitor when i pressed one of these..........But buttons are working properly with other codes(i tried with ps2 library example).and one more thing i get this message "Found Controller, configured successful"every time. :cold_sweat:... (sorry if i did any grammar mistake,English isn't my native language :smiley: )
mayankt28:
If you include code for a working button I might be able to see what is different about it.
...R
#include <PS2X_lib.h>  //for v1.6
 * set pins connected to PS2 controller:
 *   - 1e column: original
 *   - 2e colmun: Stef?
 * replace pin numbers by the ones you use
 * select modes of PS2 controller:
 *   - pressures = analog reading of push-butttons
 *   - rumble    = motor rumbling
 * uncomment 1 of the lines for each mode selection
//#define pressures   true
#define pressures   false
//#define rumble      true
//right now, the library does NOT support hot pluggable controllers, meaning
//you must always either restart your Arduino after you connect the controller,
//or call config_gamepad(pins) again after connecting the controller.
int error = 0;
byte type = 0;
byte vibrate = 0;
void setup(){
  delay(300);  //added delay to give wireless ps2 module some time to startup, before configuring it
  //CHANGES for v1.6 HERE!!! **************PAY ATTENTION*************
  //setup pins and settings: GamePad(clock, command, attention, data, Pressures?, Rumble?) check for error
  if(error == 0){
    Serial.print("pressures = ");
	if (pressures)
	  Serial.println("true ");
	  Serial.println("false");
	Serial.print("rumble = ");
	if (rumble)
	  Serial.println("true)");
    Serial.println("Try out all the buttons, X will vibrate the controller, faster as you press harder;");
    Serial.println("holding L1 or R1 will print out the analog stick values.");
    Serial.println("Note: Go to www.billporter.info for updates and to report bugs.");
  else if(error == 1)
    Serial.println("No controller found, check wiring, see readme.txt to enable debug. visit www.billporter.info for troubleshooting tips");
  else if(error == 2)
    Serial.println("Controller found but not accepting commands. see readme.txt to enable debug. Visit www.billporter.info for troubleshooting tips");
  else if(error == 3)
    Serial.println("Controller refusing to enter Pressures mode, may not support it. ");
//  Serial.print(ps2x.Analog(1), HEX);
  type = ps2x.readType();
  switch(type) {
    case 0:
      Serial.print("Unknown Controller type found ");
    case 1:
      Serial.print("DualShock Controller found ");
    case 2:
      Serial.print("GuitarHero Controller found ");
	case 3:
      Serial.print("Wireless Sony DualShock Controller found ");
  /* You must Read Gamepad to get new values and set vibration values
     ps2x.read_gamepad(small motor on/off, larger motor strenght from 0-255)
     if you don't enable the rumble, use ps2x.read_gamepad(); with no values
     You should call this at least once a second
    return;
  if(type == 2){ //Guitar Hero Controller
    ps2x.read_gamepad();          //read controller
    if(ps2x.ButtonPressed(GREEN_FRET))
      Serial.println("Green Fret Pressed");
    if(ps2x.ButtonPressed(RED_FRET))
      Serial.println("Red Fret Pressed");
    if(ps2x.ButtonPressed(YELLOW_FRET))
      Serial.println("Yellow Fret Pressed");
    if(ps2x.ButtonPressed(BLUE_FRET))
      Serial.println("Blue Fret Pressed");
    if(ps2x.ButtonPressed(ORANGE_FRET))
      Serial.println("Orange Fret Pressed");
    if(ps2x.ButtonPressed(STAR_POWER))
      Serial.println("Star Power Command");
    if(ps2x.Button(UP_STRUM))          //will be TRUE as long as button is pressed
      Serial.println("Up Strum");
    if(ps2x.Button(DOWN_STRUM))
      Serial.println("DOWN Strum");
    if(ps2x.Button(PSB_START))         //will be TRUE as long as button is pressed
      Serial.println("Start is being held");
    if(ps2x.Button(PSB_SELECT))
      Serial.println("Select is being held");
    if(ps2x.Button(ORANGE_FRET)) {     // print stick value IF TRUE
      Serial.print("Wammy Bar Position:");
      Serial.println(ps2x.Analog(WHAMMY_BAR), DEC);
  else { //DualShock Controller
    ps2x.read_gamepad(false, vibrate); //read controller and set large motor to spin at 'vibrate' speed
    if(ps2x.Button(PSB_PAD_UP)) {      //will be TRUE as long as button is pressed
      Serial.print("Up held this hard: ");
      Serial.println(ps2x.Analog(PSAB_PAD_UP), DEC);
    if(ps2x.Button(PSB_PAD_RIGHT)){
      Serial.print("Right held this hard: ");
      Serial.println(ps2x.Analog(PSAB_PAD_RIGHT), DEC);
    if(ps2x.Button(PSB_PAD_LEFT)){
      Serial.print("LEFT held this hard: ");
      Serial.println(ps2x.Analog(PSAB_PAD_LEFT), DEC);
    if(ps2x.Button(PSB_PAD_DOWN)){
      Serial.print("DOWN held this hard: ");
      Serial.println(ps2x.Analog(PSAB_PAD_DOWN), DEC);
    vibrate = ps2x.Analog(PSAB_CROSS);  //this will set the large motor vibrate speed based on how hard you press the blue (X) button
    if (ps2x.NewButtonState()) {        //will be TRUE if any button changes state (on to off, or off to on)
      if(ps2x.Button(PSB_L3))
        Serial.println("L3 pressed");
      if(ps2x.Button(PSB_R3))
        Serial.println("R3 pressed");
      if(ps2x.Button(PSB_TRIANGLE))
        Serial.println("Triangle pressed");
    if(ps2x.ButtonPressed(PSB_CIRCLE))               //will be TRUE if button was JUST pressed
      Serial.println("Circle just pressed");
    if(ps2x.NewButtonState(PSB_CROSS))               //will be TRUE if button was JUST pressed OR released
      Serial.println("X just changed");
    if(ps2x.ButtonReleased(PSB_SQUARE))              //will be TRUE if button was JUST released
      Serial.println("Square just released");
    if(ps2x.Button(PSB_L1) || ps2x.Button(PSB_R1)) { //print stick values if either is TRUE
      Serial.print("Stick Values:");
      Serial.print(ps2x.Analog(PSS_LY), DEC); //Left stick, Y axis. Other options: LX, RY, RX
      Serial.print(",");
      Serial.print(ps2x.Analog(PSS_LX), DEC);
      Serial.print(",");
      Serial.print(ps2x.Analog(PSS_RY), DEC);
      Serial.print(",");
      Serial.println(ps2x.Analog(PSS_RX), DEC);
  delay(50);
Here is the working button code
In some places there is if(ps2x.ButtonPressed( and in other places if(ps2x.Button(
Why that difference?
..R
