No Error while compiling but the program doesn't work
Hi everyone, I'm trying to do a Timegrapher using ESP32 (30 Pins), Nextion Display and the Pmod MIC3 for recording the ''tic tac'' of the watch. You can see the code below, when compiling there's no error, but I've some problems.
1- On the serial plotter and monitor, nothing comes out, I don't know what I've done wrong?
2- With the Button Plus and Minus, I increase or decrease the variable LA. But when using those buttons on the display, there's no reaction. What have I done wrong, or how is the right way to do it?
3- Is my Pmod MIC3 recording code is good?
4- Did I set the Low Pass Filter very well. Does 125 Hz is good enough as cut-off-frequency for the watch range noise?
5- The program has 3 pages (zero, one, two), am I displaying those pages very well?
I need your help to correct the''errors''
//#include <SoftwareSerial.h>
#include <Nextion.h>
#include <filters.h>
#include <SPI.h>
#define SS 5
   Filter Setting, LPF
const float cutoff_freq   = 125.0;                /* Cutoff frequency in Hz */
const float sampling_time = 0.001;                /* Sampling time in seconds. */
IIR::ORDER  order  = IIR::ORDER::OD4;             /* Order (OD1 to OD4) */
Filter f(cutoff_freq, sampling_time, order);
   Variables
int n = 0;
int count = 0;
int time_elapsed;
int lift_time;
int start_time;
int end_time;
int time1;
int time2;
int Rtic;
int Rtac;
float Rate;
float BeatError;
float Amplitude;
float BeatRate;
uint16_t LA; //Lift Angle
const unsigned long event = 5000;
   Nextion Function
void ButtonMinusPopCallBack(void *ptr);
void ButtonPlusPopCallBack(void *ptr);
void ButtonWeiterPopCallBack(void *ptr);
void ButtonEnterPopCallBack(void *ptr);
void ButtonClosePopCallBack(void *ptr);
void LiftAnglePopCallBack(void *ptr);
   Nextion component for page0
NexButton ButtonWeiter = NexButton(0, 2, "ButtonWeiter");
   Nextion component for page1
NexText LiftAngle = NexText(1, 1, "LiftAngle");
NexButton ButtonMinus = NexButton(1, 2, "ButtonMinus");
NexButton ButtonPlus =  NexButton(1, 3, "ButtonPlus");
NexButton ButtonEnter = NexButton(1, 4, "ButtonEnter");
   Nextion component for page2
NexButton ButtonClose = NexButton(2, 5, "ButtonClose");
NexText Rte = NexText(2, 1, "Rte");
NexText Amp = NexText(2, 2, "Amp");
NexText BErr = NexText(2, 3, "BErr");
NexText BRte = NexText(2, 4, "BRte");
   Nextion screens
NexPage zero = NexPage(0, 0, "zero");
NexPage one =  NexPage(1, 0, "one");
NexPage two =  NexPage(2, 0, "two");
   Buffer zone of various variables
char buffer[100] = {0};
char buffer_Rte[10] = {0};
char buffer_Amp[10] = {0};
char buffer_BErr[10] = {0};
char buffer_BRte[10] = {0};
char buffer_LiftAngle[10] = {0};
NexTouch *nex_listen_list[] =
  &ButtonClose,
  &ButtonEnter,
  &ButtonPlus,
  &ButtonMinus,
  &ButtonWeiter,
  &LiftAngle,
  NULL
   Lift Angle Function
  dbSerialPrintln("LiftAnglePopCallBack");
  LiftAngle.setText("52");
   Button Minus Function
  uint16_t len;
  dbSerialPrintln("ButtonMinusPopCallBack");
  memset(buffer, 0, sizeof(buffer));
  LiftAngle.getText(buffer, sizeof(buffer));
  LA = atoi(buffer);
  LA -= 1;
  itoa(LA, buffer, 10);
  LiftAngle.setText(buffer);
   Button Plus Function
  uint16_t len;
  dbSerialPrintln("ButtonPlusPopCallBack");
  LA = atoi(buffer);
  LA += 1;
   Button Weiter Function
  dbSerialPrintln("ButtonWeiterPopCallBack");
  Serial.print("page one");
  Serial.write(0xff);
  Serial.write(0xff);
  Serial.write(0xff);
   Button Enter Function
  dbSerialPrintln("ButtonEnterPopCallBack");
  Serial.print("page two");
  delay (1000);
  Serial.print("Rte.txt=");
  Serial.print(Rate);
  Serial.print("Amp.txt=");
  Serial.print(Amplitude);
  Serial.print("BErr.txt=");
  Serial.print(BeatError);
  Serial.print("BRte.txt=");
  Serial.print(BeatRate);
  Serial.write(0xff);
  Serial.write(0xff);
  Serial.write(0xff);
   Button Close Function
  dbSerialPrintln("ButtonClosePopCallBack");
  Serial.write(0xff);
  Serial.write(0xff);
  Serial.write(0xff);
void setup(void)
  nexInit();
  Serial.begin(9600);                     /* initialization of serial communication */
  SPI.begin();                            /* initialization of SPI port */
  SPI.setDataMode(SPI_MODE0);             /* configuration of SPI communication in mode 0 */
  SPI.setClockDivider(SPI_CLOCK_DIV64);   /* configuration of clock at 1MHz */
  pinMode(SS, OUTPUT);
  Serial.println("Start");
   Register all event callback function of all component.
  LiftAngle.attachPop(LiftAnglePopCallBack);
  ButtonPlus.attachPop(ButtonPlusPopCallBack);
  ButtonMinus.attachPop(ButtonMinusPopCallBack);
  ButtonEnter.attachPop(ButtonEnterPopCallBack);
  ButtonClose.attachPop(ButtonClosePopCallBack);
  ButtonWeiter.attachPop(ButtonWeiterPopCallBack);
  dbSerialPrintln("Setup done");
void loop(void)
  nexLoop(nex_listen_list);     /* When a pop or push event occured every time, the corresponding component[right page id and component id] in touch event list will be asked. */
  int16_t* samples;
  samples = (int16_t*)malloc(sizeof(int16_t)*100);
  if(millis()>event)
    if(samples == NULL)
      Serial.print("insufficient memory");
      float filteredval = f.filterIn(MIC3_getSound());
      samples[n++] = filteredval;
  if(*samples>18000)
    count++;
    start_time = millis();
    if(count==10)
      if(count == 4)
        time1 = millis();
      if(count == 7)
        Rtic = millis();
      end_time = millis();
  time_elapsed = (end_time - start_time) / 1000;                  //Elapsed time for 10 Beats
  lift_time = (time_elapsed / 10000) * 3;                         // Elapsed time for 3 Beats
  Rtac = (end_time - time1) / 1000;
  time2 = (Rtic - time1) / 1000;
  Rate = (Rtic + Rtac) / 2;
  BeatError = (time1 - time2) / 2;
  Amplitude = LA / (2 * sin(180 * lift_time * (Rate / 7200)));
  BeatRate = (count / time_elapsed) * 3600;                   //Beat Per Hour
  Serial.println(*samples);
  free(samples);
  n = 0;
int MIC3_getSound(void) {
  digitalWrite(SS, LOW);                                        //activate chip select
  int sound = SPI.transfer(0) | (SPI.transfer(0) << 8);         //reconstruct 12-bit data
  digitalWrite(SS, HIGH);                                       //deactivate chip select
  return sound;
Can you see the "Start" message?
Nothing DrDettrich
Then it's easy: check your Serial Monitor for COM port and baudrate.
It's set to 9600 as in the program but still nothing
Do you close the Serial Monitor and open it again after the program is loaded?
Yep
Then remove everything except Serial from setup(). If this doesn't work I'm out. Then add the other items until the error reappears.
Did you connect anything to RX/TX?
Still nothing. What about the low pass filter, is it well set ?
We should fix the Serial problem first. I have no idea of what else your code should do.
Is it hardware or software that prevents the Serial communication?
Load some simple sketch like BlinkWithoutDelay and add the "Start" output to it.
I've loaded a LED blink program and it's ok
Can you see the Start message in the Serial Monitor?
With LED program yeah but nothing with the Timegrapher
Then see my #9 for stepwise debugging. Add some output before each statement in setup().
