No errors but one line wont print
Hello guys,
I am having troubles getting my code to work. It is parsing the data properly, but it does not seem to be using it for the motorLocations section. The printData section is working, printing out "2" if I send it <02>, but it does not print "Moving to Position 2" which leads me to believe it would not run the motors if I had them connected. Apologies for the excessive commenting, it helps me to keep track as I am very new to this.
#include <AccelStepper.h>
#include <MultiStepper.h>
AccelStepper stepper1(1,8,9); // stepper1, Pulse Pin 8, Direction Pin 9
AccelStepper stepper2(1,4,5); // stepper2, Pulse Pin 4, Direction Pin 5
bool newData = false;
bool runallowed = false;
char receivedCommand;
long CoordinateX = 0;
long CoordinateY = 0;
const byte numChars = 32; //number of characters set to 32, constant which means read only basically
char receivedChars[numChars];
char tempChars[numChars]; // temporary array for use when parsing
char messageFromPC[numChars] = {0}; // variables to hold the parsed data
int bottleNum = 0; //defining first input variable for location
 Serial.begin(9600); //baud rate for serial monitor
 Serial.println("Motor Position Testing"); //print this message on open
 Serial.println("Positions available: 1-9"); // ^
 Serial.println("Syntax <01>");
 stepper1.setMaxSpeed(1600); //Max speed steps/second
 stepper1.setAcceleration(800); //Acceleration steps/second/second
 stepper2.setMaxSpeed(1600); //Max speed steps/second
 stepper2.setAcceleration(800); //Acceleration steps/second/second
 stepper1.disableOutputs(); //Keeps outputs disabled when not in use
 stepper2.disableOutputs(); //Keeps outputs disabled when not in use
  recieveData(); //void command defined later
     if (newData == true) {
        strcpy(tempChars, receivedChars); // this temporary copy is necessary to protect the original data because strtok() used in parseData() replaces the commas with \0
        parseData(); //void command defined later
        printData(); //prints parsed bottle location
        newData = false; //setting new data bool back to false at end of loop
  motorLocations(); //tells the motor where to go and returns message
  runMotor(); //enables or disables motor outputs
void recieveData() { //command for recieving data and identifying start and end markers
    static boolean recvInProgress = false; //static is visible to only one function, defining this static bool as false by default
    static byte owo = 0; //static as above, but for number of characters
    char startMarker = '<'; //defining start marker
    char endMarker = '>'; //defining end marker
    char uwu; //defining variable uwu as a character value
    while (Serial.available() > 0 && newData == false) { //while serial monitor is unavailable, i.e getting inputs between markers
        uwu = Serial.read(); //set input to variable uwu
        if (recvInProgress == true) { //if we are currently recieving data
            if (uwu != endMarker) { //if the character is not an end marker
                receivedChars[owo] = uwu; //Set number of characters to static byte
                owo++; //add one character to static byte
                if (owo >= numChars) { //if static byte is the same or greater than contant byte
                    owo = numChars - 1; //static byte becomes constant byte
            else {
                receivedChars[owo] = '\0'; // terminate the string
                recvInProgress = false; //set recieve in progress to false
                owo = 0; //set static byte back to 0
                newData = true; //set new data to true
        else if (uwu == startMarker) { //set character value to start marker
            recvInProgress = true; //set recieve in progress to true
void parseData() {      // split the data into its parts
 char * strtokIndx; // this is used by strtok() as an index
    strtokIndx = strtok(tempChars,","); // get the first part
    bottleNum = atoi(strtokIndx);     // convert it to an integer
void runMotor() //enables or disable motor outputs
    if (runallowed == true)
      stepper1.enableOutputs(); //enable output pins if run is allowed
      stepper1.run();
      stepper2.enableOutputs(); //enable output pins if run is allowed
      stepper2.run();
      stepper1.disableOutputs(); //disable output pins if run is not allowed
      stepper2.disableOutputs(); //disable output pins if run is not allowed
      return;
void motorLocations() //check for recieved commands on the serial
   if (Serial.available() > 0) //if something comes from the computer
        newData = true; //indicate that there is a new data by setting this bool to true
        if (newData == true) //we only enter this long switch-case statement if there is a new command from the computer
            switch (bottleNum) //we check what is the command
              case '1': //Position 1 for the motors
                Serial.println("Moving to Position 1"); //print text before moving
                CoordinateX = 1000;
                CoordinateY = 1000;
                MovePosition(); //run the command for moving to a position
             //deleted identical cases 2-8 for this post
            default:
        newData = false;
void MovePosition()
  runallowed = true; //enable outputs
  stepper1.moveTo(CoordinateX); //move large motor to coordinates defined in the serial cases
  stepper2.moveTo(CoordinateY); //move small motor to coordinates defined in the serial cases
void printData() {
    Serial.print("Recieved Bottle Number: ");
    Serial.println(bottleNum);
I am not getting any errors.
Thanks in advance for your help!
Hello
1 is a number, but '1' is an ascii character equivalent to number 49
I changed '1' into 1 and it still doesn't work. I also added a println for the default case that says "No match" and that never came up either
You have read all the data there is to read with receive Data(). There is no more available so you never enter motorLocations().Read and parse the incoming commands in only one section of code
You have a problem in the logic. recieveData handles the serial communication. In motorLocations, you check if there is data available; it's highly unlikely.
You should not manipulate newData in motorLocations, newData is part of the serial communication.
If you want to change the motor settings every run of loop(), the call to motorLocations is in the right place.
If you want to change the motor settings only if (valid) serial data is received, you will have to move a modified motorLocations; that would be inside the if block in loop().
And the modified motorLocations could look like below
      CoordinateX = 1000;
      CoordinateY = 1000;
    default:
Code not compiled.
I love this forum, your help is much appreciated everyone!
