No errors, just has "Error compiling for Board Arduino/Genuino Uno" exit status1
I am working on a gamebuino project.
The compiler is not reporting any errors, just saying it doesn't want to work.
//imports the SPI library (needed to communicate with Gamebuino's screen)
#include <SPI.h>
//imports the Gamebuino library
#include <Gamebuino.h>
//creates a Gamebuino object named gb
Gamebuino gb;
int character = 0;
int acc;
int dam;
int crit;
int score = 0;
int px = LCDWIDTH/2;
int py = LCDHEIGHT/2;
int randCall;
int rands[] = {1,4,18,12,14,3,16,6,20,17,2,19,5,8,7,11,9,10,13,15};
int enNum = 0;
int enX[] = {0};
int enY[] = {0};
const byte E [] PROGMEM =
8,8,
B11111111,
B10100101,
B10000001,
B11111111,
B00111100,
B01111111,
B00001000,
B00010100,
const byte W [] PROGMEM =
8,8,
B00101000,
B01000100,
B00111000,
B01000100,
B00111000,
B00010000,
B00010000,
B00101000,
const byte A[] PROGMEM =
8,8,
B00100000,
B00111000,
B00111100,
B00011000,
B00010010,
B01111100,
B01010000,
B00101000,
// the setup routine runs once when Gamebuino starts up
void setup(){
// initialize the Gamebuino object
gb.begin();
//display the main menu:
gb.titleScreen(F("Dungeon Fight"));
gb.popup(F("UP[Warrior] DOWN[Assassin]"), 100);
// the loop routine runs over and over again forever
void loop(){
//updates the gamebuino (the display, the sound, the auto backlight... everything)
//returns true when it's time to render a new frame (20 times/second)
if(gb.update()){
randCall++;
if(randCall==19){
randCall-=19;
if(gb.buttons.pressed(BTN_C)){
if(character==0){
if(gb.buttons.repeat(BTN_UP,2)){
character = 1;
acc = 12;
dam = 8;
crit = 0;
} else if(gb.buttons.repeat(BTN_DOWN,2)){
character = 2;
acc = 15;
dam = 4;
crit = 4;
}else{
if(character==1){
if(gb.buttons.repeat(BTN_RIGHT,2)){
px+=1;
} else if(gb.buttons.repeat(BTN_LEFT,2)){
px-=1;
}else if(gb.buttons.repeat(BTN_UP,2)){
py-=1;
}else if(gb.buttons.repeat(BTN_DOWN,2)){
py+=1;
}else if(gb.buttons.repeat(BTN_A,5)){
for(int x=0;x<enNum;x++){
for(int y=0;y<enNum;y++){
if((enX[x]>px-10)&&(enX[x]<px+10)&&(enY[y]>py-10)&&(enY[y]<py+10)){
if(rands[randCall]>=acc){
enX[x]-=(dam10);
score+=1;
if(character==2){
px+=1;
px-=1;
py-=1;
py+=1;
enX[x]-=(dam
10);
score+=1;
if(rands[randCall]<=crit){
enX[x]-=(crit*10);
score+=1;
if(randCall == 18){
enX[enNum] = 0;
enY[enNum] = LCDWIDTH/2;
enNum += 1;
for(int m = 0;m<=enNum;m++){
if(enX[m]<px){
enX[m]+=2;
} else{enX[m]-=2;}
if(enY[m]<py){
enY[m]+=2;
} else{enY[m]-=2;}
gb.display.println(F(score));
gb.display.setColor(INVERT);
if(character==1){
gb.display.drawBitmap(px,py,W);
} else if(character==2){
gb.display.drawBitmap(px,py,A);
gb.display.drawBitmap(enX[m],enY[m],E);
gb.display.setColor(GRAY);
Are you sure there are no errors reported? Enable verbose compiler output, and use the copy error message button to copy the full error. If the problem is with the code, the error output will contain a description of the error. Post the error here. Use code tags (see the "how to use this forum" thread) to post error messages (and code).
What is the gambuino? What microcontroller powers it?
What version of the IDE, and how was it installed? Windows Store version sometimes has issues, and versions from a linux package manager usually have problems.
Drag the top of the window, where the error msg is, upwards..
You need a Gamebuino (A SAMD architecture), seems you are compiling for a UNO...
Read their web site if you have the relevant hardware to find out how to install the right board and libraries. It won’t work on a UNO
Please correct your first post above and add code tags around your code:
[code]`` [color=blue]// your code is here[/color] ``[/code].
It should look like this:// your code is here
(Also press ctrl-T (PC) or cmd-T (Mac) in the IDE before copying to indent your code properly)
Sorry guys, it just didn't tell me in the error messages what was wrong. The part where it said
[gb.display.println(F(script))] should have been [gb.display.println(script)] and that fixed it.
