No help needed anymore
Hello, I have a few problems.
  1. When I start the code and open the serial monitor, the serial prints don't go on, the serial monitor is asking over and over again the same question, and whether I type yes(oui) or non(no), nothing changes.
  2. In the getInclinometre part, while turning the potentiometer, there will be multiple values showing up. While they are showing up, how do I make the user press enter to select one of them when they are satisfied with the value showing up? Is the
    while (Serial.available() == 0 || Serial.available() == 1) {
    return Serial.parseFloat();
    part good?
Here's my code:
int ANALOGUE_RESISTOR_VARIABLE = A0; //La broche analogique A0 pour le capteur d'angle rotatif
int VALEUR_RESISTOR_VARIABLE = 1023.0;
int ADC_REF = 5; //Tension de référence de l'ADC est de 5v
int VALEUR_TOTALE_ANGLE = 270.0; //Valeur totale de l'angle de rotation est de 270 degrés
int DEL_ROUGE = 9; //Broche DEL rouge
int DEL_BLEUE = 4; //Broche DEL bleue
int LASER = 10; //Broche Laser
int distance  = "";
int heightinclino = "";
String reponse = "";
String reponse2 = "";
int distancehaut = "";
double hauteur;
double degree;
  //Démarrer la connexion série
  //Données des outputs
  pinMode (DEL_ROUGE, OUTPUT);
  pinMode (DEL_BLEUE, OUTPUT);
  pinMode (LASER, OUTPUT);
  Serial.print("INCLINOMÈTRE");
int CalculsDegres()
  //Lecture de la valeur brute de la broche analogique du résistor variable
  analogRead(ANALOGUE_RESISTOR_VARIABLE);
  //Conversion de la lecture du capteur en degrés et renvoie de cette valeur
  double degree = (float)analogRead(ANALOGUE_RESISTOR_VARIABLE) * (VALEUR_TOTALE_ANGLE / VALEUR_RESISTOR_VARIABLE);
  return degree;
int getInclinometre() {
  //Allumer le laser
  digitalWrite (LASER, HIGH);
  //Lecture de la valeur du capteur d'angle de rotation en degrés
  double degree = CalculsDegres();
  //Carte pour les limites de valeurs et l'horizon
  degree = map(analogRead(ANALOGUE_RESISTOR_VARIABLE), 0, 1023, -135, 135);
  //Écriture des données
  if (degree > 0) {
    Serial.print("Angle d'élévation: ");
    Serial.println(degree);
    digitalWrite(DEL_BLEUE, HIGH);
    digitalWrite(DEL_ROUGE, LOW);
  else if (degree < 0) {
    Serial.print("Angle de dépression: ");
    digitalWrite(DEL_ROUGE, HIGH);
    digitalWrite(DEL_BLEUE, LOW);
  else {
    Serial.print("HORIZON = ");
  //Délai entre les lectures
  delay(100);
int getHauteur()
{ double haut =  tan(degree) * distance;
  double hauteur = haut + distancehaut;
    Serial.println("Souhaitez-vous aussi trouver la hauteur du sujet?");
    while (Serial.available() == 0)   {}
    reponse = Serial.readString(); //Reading the Input string from Serial port.
    if (reponse == "Oui") {
      Serial.println("Insérez la distance entre l'inclinomètre et le sujet.");
      distance = Serial.parseInt(); //Reading the Input string from Serial port.
      Serial.println("Angle d'élévation (É) ou de dépression (D)?");
      reponse2 = Serial.readString(); //Reading the Input string from Serial port.
      if (reponse2 == "É") {
        Serial.println("Insérez la distance entre l'inclinomètre et le sol.");
        distancehaut = Serial.parseInt(); //Reading the Input string from Serial port.
        Serial.println("Calculez l'angle.");
        int angle = getInclinometre();
        Serial.println("Voici la hauteur de votre sujet = ");
        double hauteur = getHauteur();
        Serial.println(hauteur);
      if (reponse2 == "D") {
        Serial.println("Insérez la distance entre l'inclinomètre et le haut de votre sujet.");
    if (reponse == "Non") {
      int inclinometre = inclinometre;
Hello midnight9618
Check this line.
Why do use a WHILE instruction instead an IF instruction?
A secondary WHILE loop is not need, the Arduino loop() call is doing this all the time.
This line will also read in whatever line ending you have Serial Monitor set to - Such as newline or CR or both. If you have that set, "Oui" will not equal "Oui\n"
This shows the issue:
String response = "";
  Serial.println("ready");
  while (Serial.available() == 0 ) {
  response = Serial.readString();
  Serial.print("response = '");
  Serial.print(response);
  Serial.println('\'');
@midnight9618 has indicating they will no longer be participating in this thread. Thread locked.
