I am working on a project to add OTA updating to my stuff. The webServer code has a funky syntax for .on() for referencing the functions to call when said request is made. What is the significance of using " { }, {" for an argument? Furthermore, I get compile error that no function matches WebServer::on(String&, HTTPMethod, serverInit()::<lambda()>). What the heck is lambda()’?
void serverInit() {
String s = "/serverIndex";
String u = "/update";
server.on(s, HTTP_GET, []() {
server.sendHeader("Connection", "close");
server.send(200, "text/html", serverIndex);
/*handling uploading firmware file */
server.on(u, HTTP_POST, []() {
server.send(200, "text/plain", (Update.hasError()) ? "FAIL" : "OK");
ESP.restart();
HTTPUpload& upload = server.upload();
if (upload.status == UPLOAD_FILE_START) {
Serial.printf("Update: %s\n", upload.filename.c_str());
if (!Update.begin(UPDATE_SIZE_UNKNOWN)) { //start with max available size
Update.printError(Serial);
} else if (upload.status == UPLOAD_FILE_WRITE) {
/* flashing firmware to ESP*/
if (Update.write(upload.buf, upload.currentSize) != upload.currentSize) {
} else if (upload.status == UPLOAD_FILE_END) {
if (Update.end(true)) { //true to set the size to the current progress
Serial.printf("Update Success: %u\nRebooting...\n", upload.totalSize);
server.begin();
Here is the cpp file of the “dead-simple” webserver:
WebServer.cpp - Dead simple web-server.
Supports only one simultaneous client, knows how to handle GET and POST.
Copyright (c) 2014 Ivan Grokhotkov. All rights reserved.
TRUNCATED
String WebServer::_getRandomHexString() {
char buffer[33]; // buffer to hold 32 Hex Digit + /0
int i;
for(i = 0; i < 4; i++) {
sprintf (buffer + (i*8), "%08x", esp_random());
return String(buffer);
int WebServer::requestAuthentication(HTTPAuthMethod mode, const char* realm, const String& authFailMsg) {
if(realm == NULL) {
_srealm = String(F("Login Required"));
_srealm = String(realm);
if(mode == BASIC_AUTH) {
sendHeader(String(FPSTR(WWW_Authenticate)), String(F("Basic realm=\"")) + _srealm + String(F("\"")));
_snonce=_getRandomHexString();
_sopaque=_getRandomHexString();
sendHeader(String(FPSTR(WWW_Authenticate)), String(F("Digest realm=\"")) +_srealm + String(F("\", qop=\"auth\", nonce=\"")) + _snonce + String(F("\", opaque=\"")) + _sopaque + String(F("\"")));
using namespace mime;
send(401, String(FPSTR(mimeTable[html].mimeType)), authFailMsg);
return 5511;
void WebServer::on(const String &uri, String handler) {
on(uri, HTTP_ANY, handler);
void WebServer::on(const String &uri, HTTPMethod method, String fn) {
on(uri, method, fn, _fileUploadHandler);
void WebServer::on(const String &uri, HTTPMethod method, String fn, String ufn) {
_addRequestHandler(new FunctionRequestHandler(fn, ufn, uri, method));
TRUNCATED//////////////////////
