I have problems with this code.
Everything seems to work perfectly but any word that I post can not be found.
You find code here : http://arduino.cc/en/Tutorial/Twitter-controlledMoodLamp
while(isspace(c = timedRead())); // Scan past whitespace
What is in c, that the server responded with? You need to understand what the server is responding with to begin to understand why parsing isn't working.
Are you sure the Twitter server is returning the response you think it is? Maybe you should send the entire server response to the serial monitor.
Have you noticed that Twitter uses SSL (port 443) for tweets now? All port 80 requests are redirected to port 443. That may be the response you are trying to process.
On 443 give me " Time out"
In port 80 no match.....only this:
Attempting to connect to SSID: Seven-net
SSID: Seven-net
IP Address: 192.168.1.102
signal strength (RSSI):-42 dBm
Connecting to server...OK
Issuing HTTP request...OK
Awaiting results (if any)...OK
Processing results...
Pausing...done
Pausing...done
Pausing...done
Pausing...done
Pausing...done
Pausing...
Pausing...done
Where is the text the server is returning? If it is returning a redirect page, you will never get a match. Print the response you are receiving from the server to the serial monitor, not just "Processing results".
The wifi and ethernet libraries do not support TLS or SSL, so port 443 is not available without using a relay server.
edit: You may be getting a page like this from the server. Do you see the string you are searching for here?
HTTP/1.1 301 Moved Permanently
date: Fri, 30 May 2014 03:01:12 UTC
server: tfe
set-cookie: guest_id=v1%3A137783167277866638; Domain=.twitter.com; Path=/; Expires=Sun, 30-Aug-2015 03:01:12 UTC
Content-Length: 0
Connection: close
"Processing results " does not give me any answer. There aren't match.
This code was written by Massimo Banzi.
I just picked up and copied by changing only the Internet connection.
When in Twitter write "#arduinoRGB" I have no march with this code.
The code continue without find it.....
If you've modified the code to (try to) output some more information, you need to share the code. If you haven't, you need to get busy.
I have not modified the code. Only chanche SSD and my Pass.
This is code ::
You've been told that you need to print the data returned by the server, so you can learn WHY the server is not returning the data you expect. Who do you think should modify your code? If you expect someone else to do it, get ready to pay, and head over to Gigs and Collaboration. Here, we expect you to do something to help yourself.
Ok. I am just only wannabe by Arduino.
I see only data in "MONITOR "
I don't see data server ...I see only the connection ok...then code not find nobody match and go on with a new search.
Forgive me but I'm trying to understand.
Go back an look at reply #1. The Arduino is reading the data from the server, but it is NOT showing you anything in the Serial Monitor. Can you figure out how to remedy that?
Get rid of that attitude, or forget this project.
You are a person encouraging as many think.
When I helped other people for little things I have tried the code and then I helped them by giving suggestions. At least he knew if it worked.
If you do not I could help I would not have even responded.
These responses are not constructive give only judges from who feel superior.
I have a degree on computer security many bases but I arduino is using it about a month. I’m trying to figure out how to proceed. That’s it.
If you want to help me thank you for your time.
