No matching for function
I am making a project using ESP32 and I wanna make an output to thingspeak. Since I'm using 2 sensor, I wanna make 2 output in Thingspeak. I've tried make one output by one of the sensor I'm using and fortunately it worked but when I tried to make 2 output I keep getting this error. Btw I'm using HCSR04 sensor and HCSR501 sensor.Idk what function I did not recall in this scope. A little help would be appreciate.
no matching function for call to 'ThingSpeakClass::writeField(long unsigned int&, const char*&)'
#include <ThingSpeak.h>
#include <WiFi.h>
#define SOUND_SPEED 0.034
#define CM_TO_INCH 0.393701
#include <Servo.h>
#define SERVO_PIN 26
Servo servoMotor;
const int trigPin = 4;
const int echoPin = 5;
int Redled = 25;
int Greenled = 21;
int inputPin = 39;
int pinStateCurrent   = LOW;
int pinStatePrevious  = LOW;
int val = 0;
int pirState = LOW;
const char* ssid = "okay";
const char* password = "hannan122";
WiFiClient  client;
unsigned long myChannelNumber = xxxx;
const char * myWriteAPIKey = "xxxxx";
unsigned long lastTime = 0;
unsigned long timerDelay = 30000;
long duration;
float distanceCm;
int sd;
  pinMode(trigPin, OUTPUT);
  pinMode(echoPin, INPUT);
  pinMode(Redled, OUTPUT);
  pinMode(Greenled, OUTPUT);
  WiFi.mode(WIFI_STA);
  ThingSpeak.begin(client);
  servoMotor.attach(SERVO_PIN);
  pinMode(inputPin, INPUT);
void loop(){
  digitalWrite(trigPin, LOW);
  delayMicroseconds(2);
  digitalWrite(trigPin, HIGH);
  delayMicroseconds(10);
  duration = pulseIn(echoPin, HIGH);
  distanceCm = duration * SOUND_SPEED/2;
  Serial.print("Distance (cm): ");
  Serial.println(distanceCm);
  sd = distanceCm;
  if(sd<=7)
    delay(200);
    digitalWrite(Redled, LOW);
    digitalWrite(Greenled, HIGH);
  else if(sd>=8)
    delay(200);
    digitalWrite(Redled, HIGH);
    digitalWrite(Greenled, LOW);
   val = digitalRead(inputPin);
  if (val == HIGH)  // check if the input is HIGH
    for (int pos = 0; pos <= 180; pos += 1) {
    // in steps of 1 degree
    servoMotor.write(pos);
    delay(15);
  for (int pos = 180; pos >= 0; pos -= 1) {
    delay(15);
    if (pirState == LOW)
      Serial.println("Motion detected!");
      pirState = HIGH;
    if (pirState == HIGH)
      Serial.println("Motion ended!");
      pirState = LOW;
  if ((millis() - lastTime) > timerDelay) {
    // Connect or reconnect to WiFi
    if(WiFi.status() != WL_CONNECTED){
      Serial.print("Attempting to connect");
      while(WiFi.status() != WL_CONNECTED){
        WiFi.begin(ssid, password);
      Serial.println("\nConnected.");
    ThingSpeak.setField(1, distanceCm);
    ThingSpeak.setField(2, inputPin);
    int x = ThingSpeak.writeField(myChannelNumber, myWriteAPIKey);
    if(x == 200){
      Serial.println("Channel update successful.");
    else{
      Serial.println("Problem updating channel. HTTP error code " + String(x));
    lastTime = millis();
Check the documentation. writeField takes four parameters, not two.
