No matching function for call to 'BitsAndD
Hi all.
The code below got compiling error, how to fix it?
no matching function for call to
BitsAndDroidsFlightConnector::BitsAndDroidsFlightConnector(bool)'
that is from: ESP32 TFT Touch Screen Display Camera Based Projects
Thanks
Adam
#include "SPI.h"
#include "SD.h"
#include "FS.h"
#include "esp_camera.h"
#define CAMERA_MODEL_MAKERFABS
#include "camera_pins.h"
#include "HTTPClient.h"
#include <LovyanGFX.hpp>
#include "makerfabs_pin.h"
#include <functional>   /// NEW ADD  https://stackoverflow.com/questions/50465070/function-in-namespace-std-does-not-name-a-template-type
//If undefine debug, will be faster
//#define SERIAL_DEBUG
//#define WIFI_MODE
#define ARRAY_LENGTH 320 * 240 * 3
//#define NS2009_TOUCH //Resistive screen driver
#define FT6236_TOUCH //Capacitive screen driver
#define SCRENN_ROTATION 3
#ifdef NS2009_TOUCH
#include "NS2009.h"
const int i2c_touch_addr = NS2009_ADDR;
#endif
#ifdef FT6236_TOUCH
#include "FT6236.h"
const int i2c_touch_addr = TOUCH_I2C_ADD;
#endif
//SPI control
#define SPI_ON_TFT digitalWrite(ESP32_TSC_9488_LCD_CS, LOW)
#define SPI_OFF_TFT digitalWrite(ESP32_TSC_9488_LCD_CS, HIGH)
#define SPI_ON_SD digitalWrite(ESP32_TSC_9488_SD_CS, LOW)
#define SPI_OFF_SD digitalWrite(ESP32_TSC_9488_SD_CS, HIGH)
struct LGFX_Config
    static constexpr spi_host_device_t spi_host = ESP32_TSC_9488_LCD_SPI_HOST;
    static constexpr int dma_channel = 1;
    static constexpr int spi_sclk = ESP32_TSC_9488_LCD_SCK;
    static constexpr int spi_mosi = ESP32_TSC_9488_LCD_MOSI;
    static constexpr int spi_miso = ESP32_TSC_9488_LCD_MISO;
static lgfx::LGFX_SPI<LGFX_Config> tft;
////static LGFX_SPI tft;
static LGFX_Sprite sprite(&tft);
static lgfx::Panel_ILI9488 panel;
const uint8_t img_rgb888_320_240_head[54] = {
    0x42, 0x4d, 0x36, 0x84, 0x3, 0x0, 0x0, 0x0, 0x0, 0x0, 0x36, 0x0, 0x0, 0x0, 0x28, 0x0,
    0x0, 0x0, 0x40, 0x1, 0x0, 0x0, 0xf0, 0x0, 0x0, 0x0, 0x1, 0x0, 0x18, 0x0, 0x0, 0x0,
    0x0, 0x0, 0x0, 0x84, 0x3, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0,
    0x0, 0x0, 0x0, 0x0, 0x0, 0x0};
String imgname = "";
int img_index = 0;
int pos[2] = {0, 0};
int stream_flag = 1;
    esp32_init();
    camera_init();
#ifdef SERIAL_DEBUG
    unsigned long start = micros();
#endif
    camera_fb_t *fb = NULL;
    fb = esp_camera_fb_get();
    if (stream_flag == 1)
#ifdef SERIAL_DEBUG
        Serial.println(micros() - start);
#endif
        //Display rgb565 picture
        drawRGBBitmap(fb->buf, fb->width, fb->height);
#ifdef SERIAL_DEBUG
#endif
#ifdef NS2009_TOUCH
    ns2009_pos(pos);
#endif
#ifdef FT6236_TOUCH
    ft6236_pos(pos);
#endif
#ifdef SERIAL_DEBUG
    String pos_str = (String)pos[0] + "," + (String)pos[1] + "," + (String)ns2009_get_press();
    Serial.println(pos_str);
#endif
    pos_rotation(pos, SCRENN_ROTATION);
    if (320 < pos[0] && pos[0] < 480)
        if (0 < pos[1] && pos[1] < 80)
#ifdef SERIAL_DEBUG
                Serial.println("Take a photo");
#endif
                void *ptrVal = NULL;
                ptrVal = heap_caps_malloc(ARRAY_LENGTH, MALLOC_CAP_SPIRAM);
                uint8_t *rgb = (uint8_t *)ptrVal;
                fmt2rgb888(fb->buf, fb->len, PIXFORMAT_RGB565, rgb);
                if (save_image(SD, rgb) == -1)
                    show_log(5);
                    show_log(0);
                heap_caps_free(ptrVal);
                rgb = NULL;
#ifdef SERIAL_DEBUG
                Serial.println("Please start steam");
#endif
                show_log(3);
        if (pos[1] > 80 && pos[1] < 160)
#ifdef SERIAL_DEBUG
            Serial.println("Last photo:");
            Serial.println(imgname);
#endif
            show_log(1);
            stream_flag = 0;
            tft.fillRect(0, 0, 320, 240, TFT_BLACK);
            print_img(SD, imgname);
#ifdef WIFI_MODE
            TestPostFileStream(imgname);
            show_log(4);
#endif
        if (pos[1] < 240 && pos[1] > 160)
#ifdef SERIAL_DEBUG
            Serial.println("START STREAM");
#endif
            stream_flag = 1;
            show_log(2);
    if (pos[0] < 320 && pos[0] > 220)
        if (pos[1] < 480 && pos[1] > 440)
#ifdef SERIAL_DEBUG
#endif
            stream_flag = 0;
            testFillScreen();
    esp_camera_fb_return(fb);
#ifdef SERIAL_DEBUG
    Serial.println("over a circle");
#endif
//ILI9488 init and SD card init
void esp32_init()
    Serial.println("ILI9488 Test!");
    //I2C init
    Wire.begin(ESP32_TSC_9488_I2C_SDA, ESP32_TSC_9488_I2C_SCL);
    byte error, address;
    Wire.beginTransmission(i2c_touch_addr);
    error = Wire.endTransmission();
    if (error == 0)
        Serial.print("I2C device found at address 0x");
        Serial.print(i2c_touch_addr, HEX);
        Serial.println("  !");
    else if (error == 4)
        Serial.print("Unknown error at address 0x");
        Serial.println(i2c_touch_addr, HEX);
    //SPI init
    pinMode(ESP32_TSC_9488_SD_CS, OUTPUT);
    pinMode(ESP32_TSC_9488_LCD_CS, OUTPUT);
    SPI_OFF_SD;
    SPI_OFF_TFT;
    SPI.begin(ESP32_TSC_9488_HSPI_SCK, ESP32_TSC_9488_HSPI_MISO, ESP32_TSC_9488_HSPI_MOSI);
    //SD(SPI) init
    SPI_ON_SD;
    if (!SD.begin(ESP32_TSC_9488_SD_CS, SPI, 60000000))
        Serial.println("Card Mount Failed");
        while (1)
        Serial.println("Card Mount Successed");
    SPI_OFF_SD;
    Serial.println("SD init over.");
    //TFT(SPI) init
    SPI_ON_TFT;
    set_tft();
    tft.begin();
    tft.setRotation(SCRENN_ROTATION);
    tft.fillScreen(TFT_BLACK);
    draw_button();
    SPI_OFF_TFT;
    Serial.println("TFT init over.");
#ifdef WIFI_MODE
    // Trying to solve pn open, type:2 0 error with this line:
    WiFi.mode(WIFI_OFF);
    for (uint8_t t = 4; t > 0; t--)
        Serial.printf("[SETUP] WAIT %d...\n", t);
        Serial.flush();
        delay(200);
    Serial.println("Connecting to WIFI");
    // wait for WiFi connection
    WiFi.mode(WIFI_STA);
    WiFi.begin("Makerfabs", "20160704");
    while (WiFi.status() != WL_CONNECTED)
        Serial.print(".");
        delay(50);
    Serial.println("\nWIFI CONNECTED");
#endif
//Camera setting
void camera_init()
    //camera config
    camera_config_t config;
    config.ledc_channel = LEDC_CHANNEL_0;
    config.ledc_timer = LEDC_TIMER_0;
    config.pin_d0 = Y2_GPIO_NUM;
    config.pin_d1 = Y3_GPIO_NUM;
    config.pin_d2 = Y4_GPIO_NUM;
    config.pin_d3 = Y5_GPIO_NUM;
    config.pin_d4 = Y6_GPIO_NUM;
    config.pin_d5 = Y7_GPIO_NUM;
    config.pin_d6 = Y8_GPIO_NUM;
    config.pin_d7 = Y9_GPIO_NUM;
    config.pin_xclk = XCLK_GPIO_NUM;
    config.pin_pclk = PCLK_GPIO_NUM;
    config.pin_vsync = VSYNC_GPIO_NUM;
    config.pin_href = HREF_GPIO_NUM;
    config.pin_sscb_sda = SIOD_GPIO_NUM;
    config.pin_sscb_scl = SIOC_GPIO_NUM;
    config.pin_pwdn = PWDN_GPIO_NUM;
    config.pin_reset = RESET_GPIO_NUM;
    config.xclk_freq_hz = 20000000;
    config.pixel_format = PIXFORMAT_RGB565;
    config.frame_size = FRAMESIZE_QVGA;
    config.jpeg_quality = 10;
    config.fb_count = 1;
    // camera init
    esp_err_t err = esp_camera_init(&config);
    if (err != ESP_OK)
        Serial.printf("Camera init failed with error 0x%x", err);
        while (1)
    sensor_t *s = esp_camera_sensor_get();
    //initial sensors are flipped vertically and colors are a bit saturated
    if (s->id.PID == OV2640_PID)
        s->set_vflip(s, 1);      //flip it back
        s->set_brightness(s, 0); //up the blightness just a bit
        s->set_saturation(s, 1); //lower the saturation
    //drop down frame size for higher initial frame rate
    s->set_framesize(s, FRAMESIZE_QVGA);
    show_log(2);
//Save image to SD card
int save_image(fs::FS &fs, uint8_t *rgb)
    SPI_ON_SD;
    imgname = "/" + String(img_index) + "write.bmp";
    img_index++;
    Serial.println("Image name:" + imgname);
    File f = fs.open(imgname, "w");
    if (!f)
        Serial.println("Failed to open file for writing");
        return -1;
    f.write(img_rgb888_320_240_head, 54);
    f.write(rgb, 230400);
    f.close();
    SPI_OFF_SD;
    return 0;
void draw_button()
    SPI_ON_TFT;
    tft.fillRect(330, 0, 150, 70, TFT_BLUE);
    tft.fillRect(330, 80, 150, 70, TFT_BLUE);
    tft.fillRect(330, 160, 150, 70, TFT_BLUE);
    //tft.fillRect(220, 440, 100, 40, TFT_GREEN);
    tft.setTextColor(TFT_WHITE);
    tft.setTextSize(1);
    tft.setCursor(340, 30);
    tft.println("TAKE PHOTO");
    tft.setCursor(340, 110);
    tft.println("LAST PHOTO");
    tft.setCursor(340, 190);
    tft.println("START STREAM");
    //tft.setCursor(230, 450);
    //tft.println("TEST");
    SPI_OFF_TFT;
//Display image from file
int print_img(fs::FS &fs, String filename)
    SPI_ON_SD;
    File f = fs.open(filename, "r");
    if (!f)
        Serial.println("Failed to open file for reading");
        return 0;
    f.seek(54);
    int X = 320;
    int Y = 240;
    uint8_t RGB[3 * X];
    for (int row = 0; row < Y; row++)
        f.seek(54 + 3 * X * row);
        f.read(RGB, 3 * X);
        SPI_OFF_SD;
        SPI_ON_TFT;
        for (int col = 0; col < X; col++)
            tft.drawPixel(col, row, tft.color565(RGB[col * 3 + 2], RGB[col * 3 + 1], RGB[col * 3]));
        SPI_OFF_TFT;
        SPI_ON_SD;
    f.close();
    SPI_OFF_SD;
    return 0;
void show_log(int cmd_type)
    SPI_ON_TFT;
    tft.fillRect(0, 240, 480, 80, TFT_BLACK);
    tft.setTextColor(TFT_RED);
    tft.setTextSize(2);
    tft.setCursor(30, 280);
    switch (cmd_type)
    case 0:
        tft.println(imgname);
    case 1:
        tft.println("Show last photo");
    case 2:
        tft.println("STREAMING");
    case 3:
        tft.println("NEED STREAM");
    case 4:
        tft.println("Upload success");
    case 5:
        tft.println("Write sd card wrong");
    default:
    SPI_OFF_TFT;
void drawRGBBitmap(uint8_t *bitmap, int16_t w, int16_t h)
    SPI_ON_TFT;
    tft.startWrite();
    for (int16_t j = 0; j < h; j++)
        for (int16_t i = 0; i < w; i++)
            uint16_t temp = bitmap[j * w * 2 + 2 * i] * 256 + bitmap[j * w * 2 + 2 * i + 1];
            tft.writePixel(i, j, temp);
    tft.endWrite();
    SPI_OFF_TFT;
unsigned long testFillScreen()
    SPI_ON_TFT;
    tft.fillRect(0, 0, 320, 240, TFT_YELLOW);
    tft.fillRect(0, 0, 320, 240, TFT_RED);
    tft.fillRect(0, 0, 320, 240, TFT_GREEN);
    tft.fillRect(0, 0, 320, 240, TFT_BLUE);
    start = micros() - start;
    tft.fillRect(0, 340, 220, 140, TFT_BLACK);
    tft.setCursor(0, 360);
    tft.println("cost:" + (String)start);
    return micros() - start;
    SPI_OFF_TFT;
#ifdef WIFI_MODE
void TestPostFileStream(String file_name)
    SPI_ON_SD;
    HTTPClient http;
    String filename = String(img_index - 1) + "write.bmp";
    String pathname = file_name;
    String archDomainAddress = "http://192.168.1.128:5002/json";
    http.begin(archDomainAddress);
    http.addHeader("Content-Type", "text/plain");
    File payloadFile = SD.open(pathname, FILE_READ);
    if (payloadFile)
        Serial.println("File exists, starting POST");
        http.addHeader("File-Name", filename);
        int httpCode = http.sendRequest("POST", &payloadFile, payloadFile.size());
        if (httpCode > 0)
            // HTTP header has been send and Server response header has been handled
            Serial.printf("[HTTP] POST... code: %d\n", httpCode);
            // file found at server
            if (httpCode >= 200 && httpCode < 300)
                String payload = http.getString();
                Serial.println("SUCCESS! DATA RECEIVED: ");
                Serial.println(payload);
            Serial.printf("[HTTP] POST... failed, error: %s\n", http.errorToString(httpCode).c_str());
        Serial.println("File does not exist!");
    payloadFile.close();
    http.end();
    SPI_OFF_SD;
    Serial.println("POST over");
#endif
void set_tft()
    panel.freq_write = 60000000;
    panel.freq_fill = 60000000;
    panel.freq_read = 16000000;
    panel.spi_mode = 0;
    panel.spi_mode_read = 0;
    panel.len_dummy_read_pixel = 8;
    panel.spi_read = true;
    panel.spi_3wire = false;
    panel.spi_cs = ESP32_TSC_9488_LCD_CS;
    panel.spi_dc = ESP32_TSC_9488_LCD_DC;
    panel.gpio_rst = ESP32_TSC_9488_LCD_RST;
    panel.gpio_bl = ESP32_TSC_9488_LCD_BL;
    panel.pwm_ch_bl = -1;
    panel.backlight_level = true;
    panel.invert = false;
    panel.rgb_order = false;
    panel.memory_width = ESP32_TSC_9488_LCD_WIDTH;
    panel.memory_height = ESP32_TSC_9488_LCD_HEIGHT;
    panel.panel_width = ESP32_TSC_9488_LCD_WIDTH;
    panel.panel_height = ESP32_TSC_9488_LCD_HEIGHT;
    panel.offset_x = 0;
    panel.offset_y = 0;
    panel.rotation = 0;
    panel.offset_rotation = 0;
    tft.setPanel(&panel);
void pos_rotation(int pos[2], int rotation)
    if (pos[0] == -1)
        return;
    if (rotation == 0)
        return;
    if (rotation == 3)
        int tempx = 480 - pos[1];
        int tempy = pos[0];
        pos[0] = tempx;
        pos[1] = tempy;
ERROR:
Arduino: 1.8.19 (Windows 7), Board: "ESP32 Dev Module, FTDI Adapter, Disabled, Default 4MB with spiffs (1.2MB APP/1.5MB SPIFFS), 240MHz (WiFi/BT), QIO, 40MHz, 4MB (32Mb), 921600, Core 1, Core 1, None, Disabled"
Camera:70:14: error: 'LGFX_SPI' in namespace 'lgfx' does not name a template type
Camera:73:28: error: 'tft' was not declared in this scope
E:\ENGINEERING\DIY\Electronic\ESP32\ESP32 GPS LCD map\ESP32_Touch_Camera\Camera\Camera\Camera.ino:73:28: note: suggested alternative: 'stat'
                            stat
E:\ENGINEERING\DIY\Electronic\ESP32\ESP32 GPS LCD map\ESP32_Touch_Camera\Camera\Camera\Camera.ino: In function 'void loop()':
Camera:172:13: error: 'tft' was not declared in this scope
E:\ENGINEERING\DIY\Electronic\ESP32\ESP32 GPS LCD map\ESP32_Touch_Camera\Camera\Camera\Camera.ino: In function 'void esp32_init()':
Camera:265:5: error: 'tft' was not declared in this scope
     tft.begin();
E:\ENGINEERING\DIY\Electronic\ESP32\ESP32 GPS LCD map\ESP32_Touch_Camera\Camera\Camera\Camera.ino:265:5: note: suggested alternative: 'stat'
     tft.begin();
     stat
E:\ENGINEERING\DIY\Electronic\ESP32\ESP32 GPS LCD map\ESP32_Touch_Camera\Camera\Camera\Camera.ino: In function 'void draw_button()':
Camera:376:5: error: 'tft' was not declared in this scope
E:\ENGINEERING\DIY\Electronic\ESP32\ESP32 GPS LCD map\ESP32_Touch_Camera\Camera\Camera\Camera.ino:376:5: note: suggested alternative: 'stat'
     stat
E:\ENGINEERING\DIY\Electronic\ESP32\ESP32 GPS LCD map\ESP32_Touch_Camera\Camera\Camera\Camera.ino: In function 'int print_img(fs::FS&, String)':
Camera:418:13: error: 'tft' was not declared in this scope
E:\ENGINEERING\DIY\Electronic\ESP32\ESP32 GPS LCD map\ESP32_Touch_Camera\Camera\Camera\Camera.ino: In function 'void show_log(int)':
Camera:432:5: error: 'tft' was not declared in this scope
E:\ENGINEERING\DIY\Electronic\ESP32\ESP32 GPS LCD map\ESP32_Touch_Camera\Camera\Camera\Camera.ino:432:5: note: suggested alternative: 'stat'
     stat
E:\ENGINEERING\DIY\Electronic\ESP32\ESP32 GPS LCD map\ESP32_Touch_Camera\Camera\Camera\Camera.ino: In function 'void drawRGBBitmap(uint8_t*, int16_t, int16_t)':
Camera:476:5: error: 'tft' was not declared in this scope
     tft.startWrite();
E:\ENGINEERING\DIY\Electronic\ESP32\ESP32 GPS LCD map\ESP32_Touch_Camera\Camera\Camera\Camera.ino:476:5: note: suggested alternative: 'stat'
     tft.startWrite();
     stat
E:\ENGINEERING\DIY\Electronic\ESP32\ESP32 GPS LCD map\ESP32_Touch_Camera\Camera\Camera\Camera.ino: In function 'long unsigned int testFillScreen()':
Camera:493:5: error: 'tft' was not declared in this scope
E:\ENGINEERING\DIY\Electronic\ESP32\ESP32 GPS LCD map\ESP32_Touch_Camera\Camera\Camera\Camera.ino:493:5: note: suggested alternative: 'stat'
     stat
E:\ENGINEERING\DIY\Electronic\ESP32\ESP32 GPS LCD map\ESP32_Touch_Camera\Camera\Camera\Camera.ino: In function 'void set_tft()':
Camera:558:11: error: 'struct lgfx::v1::Panel_ILI9488' has no member named 'freq_write'; did you mean 'endWrite'?
           endWrite
Camera:560:11: error: 'struct lgfx::v1::Panel_ILI9488' has no member named 'freq_fill'
Camera:562:11: error: 'struct lgfx::v1::Panel_ILI9488' has no member named 'freq_read'
Camera:564:11: error: 'struct lgfx::v1::Panel_ILI9488' has no member named 'spi_mode'; did you mean '_epd_mode'?
     panel.spi_mode = 0;
           _epd_mode
Camera:566:11: error: 'struct lgfx::v1::Panel_ILI9488' has no member named 'spi_mode_read'
Camera:568:11: error: 'struct lgfx::v1::Panel_ILI9488' has no member named 'len_dummy_read_pixel'
Camera:570:11: error: 'struct lgfx::v1::Panel_ILI9488' has no member named 'spi_read'
Camera:572:11: error: 'struct lgfx::v1::Panel_ILI9488' has no member named 'spi_3wire'
Camera:574:11: error: 'struct lgfx::v1::Panel_ILI9488' has no member named 'spi_cs'; did you mean 'init_cs'?
           init_cs
Camera:576:11: error: 'struct lgfx::v1::Panel_ILI9488' has no member named 'spi_dc'
Camera:578:11: error: 'struct lgfx::v1::Panel_ILI9488' has no member named 'gpio_rst'; did you mean 'init_rst'?
           init_rst
Camera:580:11: error: 'struct lgfx::v1::Panel_ILI9488' has no member named 'gpio_bl'
Camera:582:11: error: 'struct lgfx::v1::Panel_ILI9488' has no member named 'pwm_ch_bl'
Camera:584:11: error: 'struct lgfx::v1::Panel_ILI9488' has no member named 'backlight_level'
Camera:586:11: error: 'struct lgfx::v1::Panel_ILI9488' has no member named 'invert'; did you mean '_invert'?
           _invert
Camera:588:11: error: 'struct lgfx::v1::Panel_ILI9488' has no member named 'rgb_order'
Camera:590:11: error: 'struct lgfx::v1::Panel_ILI9488' has no member named 'memory_width'; did you mean '_width'?
           _width
Camera:591:11: error: 'struct lgfx::v1::Panel_ILI9488' has no member named 'memory_height'; did you mean '_height'?
           _height
Camera:593:11: error: 'struct lgfx::v1::Panel_ILI9488' has no member named 'panel_width'; did you mean '_width'?
           _width
Camera:594:11: error: 'struct lgfx::v1::Panel_ILI9488' has no member named 'panel_height'; did you mean '_height'?
           _height
Camera:596:11: error: 'struct lgfx::v1::Panel_ILI9488' has no member named 'offset_x'
     panel.offset_x = 0;
Camera:597:11: error: 'struct lgfx::v1::Panel_ILI9488' has no member named 'offset_y'
     panel.offset_y = 0;
Camera:599:11: error: 'struct lgfx::v1::Panel_ILI9488' has no member named 'rotation'; did you mean '_rotation'?
     panel.rotation = 0;
           _rotation
Camera:601:11: error: 'struct lgfx::v1::Panel_ILI9488' has no member named 'offset_rotation'; did you mean 'setRotation'?
           setRotation
Camera:603:5: error: 'tft' was not declared in this scope
E:\ENGINEERING\DIY\Electronic\ESP32\ESP32 GPS LCD map\ESP32_Touch_Camera\Camera\Camera\Camera.ino:603:5: note: suggested alternative: 'stat'
     stat
exit status 1
option enabled in File -> Preferences.
I have no idea about the first part of the error, but do you need to declare "tft"?
Thank you.
Sorry abouy my mistake, I copied a wrong code there and have just edited.
let's see this simple code:
#include <LGFX_AUTODETECT.hpp>  //
struct LGFX_Config
  static constexpr spi_host_device_t spi_host = VSPI_HOST;
  static constexpr int spi_miso     = -1; //19;
  static constexpr int spi_sclk     = 18;
  static constexpr int spi_mosi     = 23;
  static constexpr int spi_dlen     = 8;
//// static lgfx::LGFX_SPI<LGFX_Config> lcd;
static LGFX lcd;                 //
static lgfx::Panel_ST7789 panel;
void setup(void)
///  panel.freq_write            = 20000000;
///  panel.freq_fill             = 27000000;
///  panel.freq_read             = 16000000;
  panel.spi_mode              = 0;
  panel.spi_3wire             = true; //false;
  panel.spi_cs                = -1;
  panel.spi_dc                = 4;
  panel.gpio_rst              = 2;
  panel.gpio_bl               = 5;
  panel.pwm_ch_bl             = 7;
  panel.reverse_invert        = false;
  panel.memory_width          = 240;
  panel.memory_height         = 240;
  panel.panel_width           = 240;
  panel.panel_height          = 240;
  panel.offset_x              = 0;
  panel.offset_y              = 0;
  panel.rotation              = 0;
  lcd.setPanel(&panel);
  lcd.init();
uint32_t count = ~0;
void loop(void)
  delay(10);
  lcd.startWrite();
  lcd.setRotation(++count & 7);
  lcd.setColorDepth((count & 8) ? 16 : 24);
  lcd.setTextColor(random(65536));
  lcd.drawNumber(lcd.getRotation(), 16, 0);
  lcd.setTextColor(0xFF0000U);
  lcd.drawString("R", 30, 16);
  lcd.setTextColor(0x00FF00U);
  lcd.drawString("G", 40, 16);
  lcd.setTextColor(0x0000FFU);
  lcd.drawString("B", 50, 16);
  lcd.drawRect(30,30,lcd.width()-60,lcd.height()-60,random(65536));
  lcd.endWrite();
got compiling ERROR:
Arduino: 1.8.19 (Windows 10), Board: "ESP32 Dev Module, Disabled, Default 4MB with spiffs (1.2MB APP/1.5MB SPIFFS), 240MHz (WiFi/BT), QIO, 40MHz, 4MB (32Mb), 921600, Core 1, Core 1, None, Disabled"
C:\Users\Xinzhou\Documents\Arduino\sketch_jun09a\sketch_jun09a.ino: In function 'void setup()':
sketch_jun09a:29:9: error: 'struct lgfx::v1::Panel_ST7789' has no member named 'spi_mode'; did you mean '_epd_mode'?
   panel.spi_mode              = 0;
         _epd_mode
sketch_jun09a:30:9: error: 'struct lgfx::v1::Panel_ST7789' has no member named 'spi_mode_read'
sketch_jun09a:31:9: error: 'struct lgfx::v1::Panel_ST7789' has no member named 'len_dummy_read_pixel'
sketch_jun09a:32:9: error: 'struct lgfx::v1::Panel_ST7789' has no member named 'spi_read'
sketch_jun09a:33:9: error: 'struct lgfx::v1::Panel_ST7789' has no member named 'spi_3wire'
sketch_jun09a:35:9: error: 'struct lgfx::v1::Panel_ST7789' has no member named 'spi_cs'; did you mean 'init_cs'?
   panel.spi_cs                = -1;
         init_cs
sketch_jun09a:36:9: error: 'struct lgfx::v1::Panel_ST7789' has no member named 'spi_dc'
   panel.spi_dc                = 4;
sketch_jun09a:37:9: error: 'struct lgfx::v1::Panel_ST7789' has no member named 'gpio_rst'; did you mean 'init_rst'?
   panel.gpio_rst              = 2;
         init_rst
sketch_jun09a:38:9: error: 'struct lgfx::v1::Panel_ST7789' has no member named 'gpio_bl'
   panel.gpio_bl               = 5;
sketch_jun09a:40:9: error: 'struct lgfx::v1::Panel_ST7789' has no member named 'pwm_ch_bl'
sketch_jun09a:41:9: error: 'struct lgfx::v1::Panel_ST7789' has no member named 'backlight_level'
sketch_jun09a:42:9: error: 'struct lgfx::v1::Panel_ST7789' has no member named 'reverse_invert'; did you mean 'setInvert'?
         setInvert
sketch_jun09a:43:9: error: 'struct lgfx::v1::Panel_ST7789' has no member named 'rgb_order'
sketch_jun09a:45:9: error: 'struct lgfx::v1::Panel_ST7789' has no member named 'memory_width'; did you mean '_width'?
         _width
sketch_jun09a:46:9: error: 'struct lgfx::v1::Panel_ST7789' has no member named 'memory_height'; did you mean '_height'?
         _height
sketch_jun09a:47:9: error: 'struct lgfx::v1::Panel_ST7789' has no member named 'panel_width'; did you mean '_width'?
         _width
sketch_jun09a:48:9: error: 'struct lgfx::v1::Panel_ST7789' has no member named 'panel_height'; did you mean '_height'?
         _height
sketch_jun09a:50:9: error: 'struct lgfx::v1::Panel_ST7789' has no member named 'offset_x'
   panel.offset_x              = 0;
sketch_jun09a:51:9: error: 'struct lgfx::v1::Panel_ST7789' has no member named 'offset_y'
   panel.offset_y              = 0;
sketch_jun09a:53:9: error: 'struct lgfx::v1::Panel_ST7789' has no member named 'rotation'; did you mean '_rotation'?
   panel.rotation              = 0;
         _rotation
sketch_jun09a:54:9: error: 'struct lgfx::v1::Panel_ST7789' has no member named 'offset_rotation'; did you mean 'setRotation'?
         setRotation
exit status 1
the LGFX_PANEL_ST7789_HPP do have: spi_mode
why?
#ifndef LGFX_PANEL_ST7789_HPP_
#define LGFX_PANEL_ST7789_HPP_
#include "PanelIlitekCommon.hpp"
namespace lgfx
 inline namespace v0
  struct Panel_ST7789  : public PanelIlitekCommon
    Panel_ST7789(void)
      panel_height = memory_height = 320;
      freq_write = 40000000;
      freq_read  = 20000000;
      freq_fill  = 40000000;
      spi_mode = 3;
      spi_mode_read = 1;
      len_dummy_read_pixel = 16;
  protected:
    struct CMD : public CommandCommon
      static constexpr uint8_t PORCTRL  = 0xB2;      // Porch control
      static constexpr uint8_t GCTRL    = 0xB7;      // Gate control
      static constexpr uint8_t VCOMS    = 0xBB;      // VCOMS setting
      static constexpr uint8_t LCMCTRL  = 0xC0;      // LCM control
      static constexpr uint8_t VDVVRHEN = 0xC2;      // VDV and VRH command enable
      static constexpr uint8_t VRHS     = 0xC3;      // VRH set
      static constexpr uint8_t VDVSET   = 0xC4;      // VDV setting
      static constexpr uint8_t FRCTR2   = 0xC6;      // FR Control 2
      static constexpr uint8_t PWCTRL1  = 0xD0;      // Power control 1
      static constexpr uint8_t PVGAMCTRL= 0xE0;      // Positive voltage gamma control
      static constexpr uint8_t NVGAMCTRL= 0xE1;      // Negative voltage gamma control
    const uint8_t* getInitCommands(uint8_t listno) const override {
      static constexpr uint8_t list0[] = {
          CMD::SLPOUT , CMD_INIT_DELAY, 120,
          CMD::NORON  , CMD_INIT_DELAY, 0,
          0xB6        , 2, 0x0A,0x82,
          CMD::PORCTRL, 5, 0x0c, 0x0c, 0x00, 0x33, 0x33,
          CMD::GCTRL  , 1, 0x35,
          CMD::VCOMS  , 1, 0x28,  // JLX240 display datasheet
          CMD::LCMCTRL, 1, 0x0C,
          CMD::VDVVRHEN,2, 0x01, 0xFF,
          CMD::VRHS   , 1, 0x10,      // voltage VRHS
          CMD::VDVSET , 1, 0x20,
          CMD::FRCTR2 , 1, 0x0f,
          CMD::PWCTRL1, 2, 0xa4, 0xa1,
          //--------------------------------ST7789V gamma setting---------------------------------------//
          CMD::PVGAMCTRL,14, 0xd0,0x00,0x02,0x07,
                             0x0a,0x28,0x32,0x44,
                             0x42,0x06,0x0e,0x12,
                             0x14,0x17,
          CMD::NVGAMCTRL,14, 0xd0,0x00,0x02,0x07,
                             0x0a,0x28,0x31,0x54,
                             0x47,0x0e,0x1c,0x17,
                             0x1b,0x1e,
          CMD::SLPOUT, CMD_INIT_DELAY, 130,
          CMD::IDMOFF, 0,
          CMD::DISPON, 0,
          0xFF,0xFF, // end
      switch (listno) {
      case 0: return list0;
      default: return nullptr;
#endif
I think the first program in post #4 , you need to add more types to the struct?
No idea about the second program.
Hope this helps.
