Hi everyone,
I am using my Arduino MKRWifi 1010 with serial interface on Cairsens sensor.
I used Cairsens Library : GitHub - Lahorde/cairsens_uart: CairPol Cairsens UART protocol
But It didn't work, Could you help me?
My code:
#include <cairsens.h>
#include <SPI.h>
#include <WiFiNINA.h>
#include <ArduinoRS485.h>
#include <ArduinoModbus.h>
char ssid[] = "********"; //
char pass[] = "******"; //
int keyIndex = 0;
//Stream arg;
const int ledPin = 7;
//#define arg;
CairsensUART cair; //creer un nouveau objet de classe CairsensUART
int status = WL_IDLE_STATUS;
WiFiServer wifiServer(502);
ModbusTCPServer modbusTCPServer;
Serial1.begin(9600);
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
Serial.println("Modbus TCP Server LED");
while (status != WL_CONNECTED) {
Serial.print("Attempting to connect to SSID: ");
Serial.println(ssid);
status = WiFi.begin(ssid, pass);
// wait 10 seconds for connection:
delay(10000);
// you're connected now, so print out the status:
printWifiStatus();
// start the server
wifiServer.begin();
// start the Modbus TCP server
if (!modbusTCPServer.begin()) {
Serial.println("Failed to start Modbus TCP Server!");
while (1);
// configure the LED
pinMode(ledPin, OUTPUT);
pinMode(13, INPUT);
digitalWrite(ledPin, LOW);
pinMode(5, INPUT);
pinMode(7, OUTPUT);
digitalWrite(7, LOW);
modbusTCPServer.configureCoils(0x00, 1);
WiFiClient client = wifiServer.available();
if (client) {
Serial.println("new client");
modbusTCPServer.accept(client);
while (client.connected()) {
modbusTCPServer.poll();
updateLED();
Serial.println("client disconnected");
void updateLED() {
// read the current value of the coil
int coilValue = modbusTCPServer.coilRead(0x00);
if (digitalRead(5) == LOW)
digitalWrite(7, HIGH);
if (coilValue) {
digitalWrite(ledPin, HIGH);
//Serial.println(analogRead(getNO2InstantVal(int& arg_u8_val)));
int a = analogRead(13);
//Serial.println(cair.getNO2InstantVal(a));
int b= Serial1.read();
Serial.println(cair.getNO2InstantVal(b));
void printWifiStatus() {
// print the SSID of the network you're attached to:
Serial.print("SSID: ");
Serial.println(WiFi.SSID());
// print your WiFi shield's IP address:
IPAddress ip = WiFi.localIP();
Serial.print("IP Address: ");
Serial.println(ip);
// print the received signal strength:
long rssi = WiFi.RSSI();
Serial.print("signal strength (RSSI):");
Serial.print(rssi);
Serial.println(" dBm");
And the errors:
Arduino: 1.8.12 (Windows Store 1.8.33.0) (Windows 10), Board: "Arduino MKR WiFi 1010"
step1:20:14: error: no matching function for call to 'CairsensUART::CairsensUART()'
In file included from D:\Anass_Sensor\step1\step1.ino:1:0:
C:\Users\Asus\OneDrive\Documents\Arduino\libraries\cairsens_uart/cairsens.h:123:5: note: candidate: CairsensUART::CairsensUART(Stream*)
CairsensUART(Stream* arg_p_uartStream);
C:\Users\Asus\OneDrive\Documents\Arduino\libraries\cairsens_uart/cairsens.h:123:5: note: candidate expects 1 argument, 0 provided
C:\Users\Asus\OneDrive\Documents\Arduino\libraries\cairsens_uart/cairsens.h:49:7: note: candidate: constexpr CairsensUART::CairsensUART(const CairsensUART&)
class CairsensUART
C:\Users\Asus\OneDrive\Documents\Arduino\libraries\cairsens_uart/cairsens.h:49:7: note: candidate expects 1 argument, 0 provided
C:\Users\Asus\OneDrive\Documents\Arduino\libraries\cairsens_uart/cairsens.h:49:7: note: candidate: constexpr CairsensUART::CairsensUART(CairsensUART&&)
D:\Anass_Sensor\step1\step1.ino: In function 'void updateLED()':
step1:169:39: error: cannot bind non-const lvalue reference of type 'uint8_t& {aka unsigned char&}' to an rvalue of type 'uint8_t {aka unsigned char}'
C:\Users\Asus\OneDrive\Documents\Arduino\libraries\cairsens_uart/cairsens.h:134:12: note: initializing argument 1 of 'CairsensUART::EError CairsensUART::getNO2InstantVal(uint8_t&)'
EError getNO2InstantVal(uint8_t& arg_u8_val);
exit status 1
Thanks in advance
