no matching function for call to 'EthernetClient::connect(EthernetServer&, int)'
well am trying to send an email with an ethernet shield but this error message comes "no matching function for call to 'EthernetClient::connect(EthernetServer&, int)'" plz help
#include <dht.h>
#include <SPI.h>
#include <Ethernet.h>
dht DHT;
#define DHT11_PIN 3
bool a=0;
bool b=0;
bool c=0;
bool d=0;
bool e=0;
bool elec=0;
byte mac[] = { 0x90, 0xA2, 0xDA, 0x0D, 0x85, 0xD9 };   //physical mac address
byte ip[] = { 192, 168, 1, 185 };                   // ip in lan
byte subnet[] = { 255, 255, 255, 0 };              //subnet mask
byte gateway[] = { 192, 168, 1, 1 };              // default gateway
EthernetServer server(80);//server port
EthernetClient client;
#define HOST     "dc1.oct.local"
#define PORT     2525
int count = 0;
void setup(){
pinMode(3, INPUT);
  Ethernet.begin(mac, ip, gateway, subnet);
 delay(2000);
  Serial.println(F("Ready!"));}
void loop(){
  int chk = DHT.read11(DHT11_PIN);
  Serial.print("Temperature = ");
  Serial.println(DHT.temperature);
  Serial.print("Humidity = ");
  Serial.println(DHT.humidity);
  int hum = DHT.humidity ;
  int temp = DHT.temperature ;
  if(temp < 24)
  a=1;
if(temp > 26)
  b=1;
if (hum < 40)
  c=1;
if (hum > 60)
  d=1;
if (elec=0)
  e=1;
 if(temp < 24)
    sendEmail();
 else if(temp > 26)
    sendEmail();
 else if (hum < 40)
    sendEmail();
  else if (hum > 60)
    sendEmail();
  else if (elec=0)
    sendEmail();
byte sendEmail()
  byte thisByte = 0;
  byte respCode;
  if(client.connect(server,25) == 1) {
    Serial.println(("connected"));
    Serial.println("connection failed");
    return 0;
  if(!eRcv()) return 0;
  Serial.println("Sending helo");
// change to your public ip
  client.println("helo 1.2.3.4");
  Serial.println(F("Sending From");
// change to your email address (sender)
  client.println("MAIL From: <humidtemp20@gmail.com>");
// change to recipient address
  Serial.println("Sending To");
  client.println("RCPT To: <amirzouenkhi@gmail.com>");
  Serial.println("Sending DATA");
  client.println("DATA");
  Serial.println("Sending email");
  client.println("To: You <amirzouenkhi@gmail.com>");
// change to your address
  client.println("From: Me <humidtemp20@gmail.com>");
  client.println("Subject: Arduino email test\r\n");
  client.println("This is from my Arduino!");
  client.println(".");
  Serial.println("Sending QUIT");
  client.println("QUIT");
  client.stop();
  Serial.println("disconnected");
  return 1;
byte eRcv()
  byte respCode;
  byte thisByte;
  int loopCount = 0;
  while(!client.available()) {
    delay(1);
    loopCount++;
    // if nothing received for 10 seconds, timeout
    if(loopCount > 10000) {
      client.stop();
      Serial.println(F("\r\nTimeout"));
      return 0;
  respCode = client.peek();
  while(client.available())
    thisByte = client.read();
    Serial.write(thisByte);
  if(respCode >= '4')
    efail();
    return 0;
  return 1;
void efail()
  byte thisByte = 0;
  int loopCount = 0;
  client.println(F("QUIT"));
    delay(1);
    loopCount++;
      client.stop();
      return;
  client.stop();
  Serial.println(("disconnected"));
any help guys????
What is it supposed to do? If it is old email code, the functions in the libraries may have been changed or updated.
