no matching function for call to 'HTTPSRedirect::printRedir(String&, const char*
Hello guys,
Please i need your guide to resolve an error encountered while trying to upload a sketch to my esp8266. Its a sketch to send temperature (ds18b20) value to google sheet. Each time i tried i kept getting this error
“no matching function for call to ‘HTTPSRedirect::printRedir(String&, const char*&, const char*&)’”
This is the entire sketch below, please how do i resolve this? help me.
#include <HTTPSRedirect.h>
#include <ESP8266WiFi.h>
#include <OneWire.h>
#include <DallasTemperature.h>
#define ONE_WIRE_BUS 2 // Data wire is plugged into port 2 on the Arduino
OneWire oneWire(ONE_WIRE_BUS); // Setup a oneWire instance to communicate with any OneWire devices
DallasTemperature sensors(&oneWire); // Pass oneWire reference to Dallas Temperature.
const char* ssid = “Daddy4u”;
const char* password = “@Jpeg4u”;
// The ID below comes from Google Sheets. See how to get it here: http://embedded-lab.com/blog/post-data-google-sheets-using-esp8266
const char *GScriptId = “AKfycbz2uaxPooiszm0ErerNMfSRpVFuQ-6RJA4VfreYTICwvCeEt9xc”;
// Push data at this interval
const int deepSleep = 10000000;
const char* host = “script.google.com”;
const char* googleRedirHost = “script.googleusercontent.com”;
const int httpsPort = 443;
HTTPSRedirect client(httpsPort);
// Prepare the url (without the varying data)
String url = String("/macros/s/") + GScriptId + “/exec?”;
const char* fingerprint = “F0 5C 74 77 3F 6B 25 D7 3B 66 4D 43 2F 7E BC 5B E9 28 86 AD”;
sensors.begin();
Serial.println("Connecting to wifi: ");
Serial.println(ssid);
Serial.flush();
WiFi.begin(ssid, password);
Serial.print(".");
Serial.println(" IP address: ");
Serial.print(String("Connecting to "));
Serial.println(host);
bool flag = false;
for (int i=0; i<5; i++){
int retval = client.connect(host, httpsPort);
if (retval == 1) {
flag = true;
Serial.println(“Connection failed. Retrying…”);
// Connection Status, 1 = Connected, 0 is not.
Serial.println("Connection Status: " + String(client.connected()));
Serial.flush();
if (!flag){
Serial.print("Could not connect to server: ");
Serial.println(“Exiting…”);
Serial.flush();
return;
// Data will still be pushed even certification don’t match.
if (client.verify(fingerprint, host)) {
Serial.println(“Certificate match.”);
Serial.println(“Certificate mis-match”);
// This is the main method where data gets pushed to the Google sheet
void postData(String tag, float value){
if (!client.connected()){
Serial.println(“Connecting to client again…”);
String urlFinal = url + “tag=” + tag + “&value=” + String(value);
client.printRedir(urlFinal, host, googleRedirHost);
// Continue pushing data at a given interval
//Read the temperature from DS18B20
sensors.requestTemperatures();
float h = (sensors.getTempCByIndex(0));
float t = (DallasTemperature::toFahrenheit(h));
// Post this information to Google Sheet
postData(“Temperature”, h);
ESP.deepSleep(deepSleep); // Go back to sleep
//delay (deepSleep);
client.printRedir() does not take any arguments. You probably want the POST method to actually there.
See the example that came with the library: https://github.com/electronicsguy/ESP8266/blob/master/HTTPSRedirect/GoogleDocs.ino
blh64:
It does in This Version. OP, guess you should confirm which version needs to be installed.
Thanks for the info...
gfvalvo:
Good to know...
