no matching function for call to 'LiquidCrystal::blink(int)'
#include <LiquidCrystal.h>
LiquidCrystal lcd(1, 2, 10, 11, 12, 13);
lcd.begin(16,2);
void loop(){
lcd.print(“Arduino”);
delay(3000);
lcd.setCursor(2,1);
lcd.print(“LCD Turtorial”);
delay(3000);
lcd.clear();
lcd.blink();
lcd.blink(4000);
lcd.setCursor(7,1);
delay(3000);
lcd.noBlink():
lcd.cursor();
delay(4000);
lcd.noCursor();
lcd.clear();
I’m having trouble with the libraries of the displays. What I’m trying to to is get a potentiometer to work with a LCD (16x2). What I want to do is turn on and off the LCD with the potentiometer. But it giving me an error called, no matching function for call to ‘LiquidCrystal::blink(int)’ and I did look up this exact question on google and still don’t understand why I did cause this error.
lcd.blink(4000);
The blink function() takes no arguments.
there is no "turn on and off the LCD".
blink will blink the cursor.
You can either clear() the display - no characters will be shown
or if you have connected the backlight to a gpio + transistor - you can turn on/off the backlight - but the characters on the LCD will still be there.
edit:
never thought, that there is really something like
// Turn the display on/off (quickly)
void LiquidCrystal::noDisplay() {
  _displaycontrol &= ~LCD_DISPLAYON;
  command(LCD_DISPLAYCONTROL | _displaycontrol);
void LiquidCrystal::display() {
  _displaycontrol |= LCD_DISPLAYON;
There are the display() and noDisplay() functions that turn the display of characters on and off.
groundFungus:
And in other lcd libraries like the hd44780 library, there is also off() and on() which not only turns the LCD pixels off/on, as is done with noDisplay() and display() but if you have h/w backlight control using an Arduino pin, and configure the library to use it, the off()/on() will also turn off/on the backlight as well.
--- bill
