No matching function for call to 'MAX30105::begin(TwoWire&)'
I have a problem that I run a correct code and it works but when I want to monitor data with blynk iot I have to add some lines to my code after that I get this error which is for last correct skatch. what I have to do?
correct code is :
#include <Adafruit_GFX.h>  //OLED libraries
#include <Adafruit_SSD1306.h>
#include <Wire.h>
#include "MAX30105.h"   //MAX3010x library
#include "heartRate.h"  //Heart rate calculating algorithm
MAX30105 particleSensor;
const byte RATE_SIZE = 4;  //Increase this for more averaging. 4 is good.
byte rates[RATE_SIZE];     //Array of heart rates
byte rateSpot = 0;
long lastBeat = 0;  //Time at which the last beat occurred
float beatsPerMinute;
int beatAvg;
#define SCREEN_WIDTH 128  // OLED display width, in pixels
#define SCREEN_HEIGHT 64  // OLED display height, in pixels
#define OLED_RESET -1     // Reset pin # (or -1 if sharing Arduino reset pin)
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);  //Declaring the display name (display)
static const unsigned char PROGMEM logo2_bmp[] = {
  0x03,
  0xC0,
  0xF0,
  0x06,
  0x71,
  0x8C,
  0x0C,
  0x1B,
  0x06,
  0x18,
  0x0E,
  0x02,
  0x10,
  0x0C,
  0x03,
  0x10,  //Logo2 and Logo3 are two bmp pictures that display on the OLED if called
  0x04,
  0x01,
  0x10,
  0x04,
  0x01,
  0x10,
  0x40,
  0x01,
  0x10,
  0x40,
  0x01,
  0x10,
  0xC0,
  0x03,
  0x08,
  0x88,
  0x02,
  0x08,
  0xB8,
  0x04,
  0xFF,
  0x37,
  0x08,
  0x01,
  0x30,
  0x18,
  0x01,
  0x90,
  0x30,
  0x00,
  0xC0,
  0x60,
  0x00,
  0x60,
  0xC0,
  0x00,
  0x31,
  0x80,
  0x00,
  0x1B,
  0x00,
  0x00,
  0x0E,
  0x00,
  0x00,
  0x04,
  0x00,
static const unsigned char PROGMEM logo3_bmp[] = { 0x01, 0xF0, 0x0F, 0x80, 0x06, 0x1C, 0x38, 0x60, 0x18, 0x06, 0x60, 0x18, 0x10, 0x01, 0x80, 0x08,
                                                   0x20, 0x01, 0x80, 0x04, 0x40, 0x00, 0x00, 0x02, 0x40, 0x00, 0x00, 0x02, 0xC0, 0x00, 0x08, 0x03,
                                                   0x80, 0x00, 0x08, 0x01, 0x80, 0x00, 0x18, 0x01, 0x80, 0x00, 0x1C, 0x01, 0x80, 0x00, 0x14, 0x00,
                                                   0x80, 0x00, 0x14, 0x00, 0x80, 0x00, 0x14, 0x00, 0x40, 0x10, 0x12, 0x00, 0x40, 0x10, 0x12, 0x00,
                                                   0x7E, 0x1F, 0x23, 0xFE, 0x03, 0x31, 0xA0, 0x04, 0x01, 0xA0, 0xA0, 0x0C, 0x00, 0xA0, 0xA0, 0x08,
                                                   0x00, 0x60, 0xE0, 0x10, 0x00, 0x20, 0x60, 0x20, 0x06, 0x00, 0x40, 0x60, 0x03, 0x00, 0x40, 0xC0,
                                                   0x01, 0x80, 0x01, 0x80, 0x00, 0xC0, 0x03, 0x00, 0x00, 0x60, 0x06, 0x00, 0x00, 0x30, 0x0C, 0x00,
                                                   0x00, 0x08, 0x10, 0x00, 0x00, 0x06, 0x60, 0x00, 0x00, 0x03, 0xC0, 0x00, 0x00, 0x01, 0x80, 0x00 };
  display.begin(SSD1306_SWITCHCAPVCC, 0x3C);  //Start the OLED display
  display.display();
  delay(3000);
  // Initialize sensor
  particleSensor.begin(Wire);                 //Use default I2C port, 400kHz speed
  particleSensor.setup();                     //Configure sensor with default settings
  particleSensor.setPulseAmplitudeRed(0x0A);  //Turn Red LED to low to indicate sensor is running
  long irValue = particleSensor.getIR();                 //Reading the IR value it will permit us to know if there's a finger on the sensor or not
                                                         //Also detecting a heartbeat
  if (irValue > 7000) {                                  //If a finger is detected
    display.clearDisplay();                              //Clear the display
    display.drawBitmap(5, 5, logo2_bmp, 24, 21, WHITE);  //Draw the first bmp picture (little heart)
    display.setTextSize(2);                              //Near it display the average BPM you can display the BPM if you want
    display.setTextColor(WHITE);
    display.setCursor(50, 0);
    display.println("BPM");
    display.setCursor(50, 18);
    display.println(beatAvg);
    display.display();
    if (checkForBeat(irValue) == true)  //If a heart beat is detected
      display.drawBitmap(0, 0, logo3_bmp, 32, 32, WHITE);  //Draw the second picture (bigger heart)
      display.setTextSize(2);                              //And still displays the average BPM
      display.display();
      tone(3, 1000);  //And tone the buzzer for a 100ms you can reduce it it will be better
      delay(100);
      noTone(3);  //Deactivate the buzzer to have the effect of a "bip"
      //We sensed a beat!
      long delta = millis() - lastBeat;  //Measure duration between two beats
      lastBeat = millis();
      beatsPerMinute = 60 / (delta / 1000.0);  //Calculating the BPM
      if (beatsPerMinute < 255 && beatsPerMinute > 20)  //To calculate the average we strore some values (4) then do some math to calculate the average
        rates[rateSpot++] = (byte)beatsPerMinute;  //Store this reading in the array
        rateSpot %= RATE_SIZE;                     //Wrap variable
        //Take average of readings
        beatAvg = 0;
        for (byte x = 0; x < RATE_SIZE; x++)
          beatAvg += rates[x];
        beatAvg /= RATE_SIZE;
  if (irValue < 7000) {  //If no finger is detected it inform the user and put the average BPM to 0 or it will be stored for the next measure
    beatAvg = 0;
    display.setTextSize(1);
    display.setCursor(30, 5);
    display.println("Please Place ");
    display.setCursor(30, 15);
    display.println("your finger ");
    display.display();
    noTone(3);
and with blynk lines :
#include <Wire.h>
#include <Blynk.h>
#include <ESP8266WiFi.h>
#include <BlynkSimpleEsp8266.h>
#define BLYNK_PRINT Serial
byte rateSpot = 0;
int beatAvg;
#define BLYNK_TEMPLATE_ID           "TMPL4b9lt08tF"
#define BLYNK_TEMPLATE_NAME         "ox iot"
#define BLYNK_AUTH_TOKEN            "iQYxukuRjQhjVOEgNKDyISNMB74Xe2IZ"
char auth[] = "iQYxukuRjQhjVOEgNKDyISNMB74Xe2IZ";             // Authentication Token Sent by Blynk
char ssid[] = "TP-LINK_FDD2";        //WiFi SSID
char pass[] = "123456789";        //WiFi Password
{ 0x03, 0xC0, 0xF0, 0x06, 0x71, 0x8C, 0x0C, 0x1B, 0x06, 0x18, 0x0E, 0x02, 0x10, 0x0C, 0x03, 0x10,              //Logo2 and Logo3 are two bmp pictures that display on the OLED if called
0x04, 0x01, 0x10, 0x04, 0x01, 0x10, 0x40, 0x01, 0x10, 0x40, 0x01, 0x10, 0xC0, 0x03, 0x08, 0x88,
0x02, 0x08, 0xB8, 0x04, 0xFF, 0x37, 0x08, 0x01, 0x30, 0x18, 0x01, 0x90, 0x30, 0x00, 0xC0, 0x60,
0x00, 0x60, 0xC0, 0x00, 0x31, 0x80, 0x00, 0x1B, 0x00, 0x00, 0x0E, 0x00, 0x00, 0x04, 0x00,  };
  Blynk.run();
  display.display();
  delay(3000);
 long BPM = particleSensor.getIR();    //Reading the IR value it will permit us to know if there's a finger on the sensor or not
if(BPM > 7000){                                           //If a finger is detected
    display.setCursor(50,0);
    display.setCursor(50,18);
    display.display();
  if (checkForBeat(BPM) == true)                        //If a heart beat is detected
    display.display();
    tone(3,1000);                                        //And tone the buzzer for a 100ms you can reduce it it will be better
    delay(100);
    //We sensed a beat!
      beatAvg = 0;
      for (byte x = 0 ; x < RATE_SIZE ; x++)
  if (BPM < 7000){       //If no finger is detected it inform the user and put the average BPM to 0 or it will be stored for the next measure
     beatAvg=0;
     display.setCursor(30,5);
     display.setCursor(30,15);
     display.display();
     noTone(3);
  Blynk.virtualWrite(V1, BPM);
  //Blynk.virtualWrite(V2, SpO2);
The example sketch from 30105.h github shows this in their example, note (empty argument):
particleSensor.begin()
thanks! I'll try it :pray: :pray:
