no matching function for call to 'MCP_CAN::readMsgBuf(char*, unsigned char [8])'
I don't understand why it gives such an error in the code.
#include <SPI.h>
#include <mcp_can.h>
#define SPI_CS_PIN 9
#define LED 8
MCP_CAN CAN0(SPI_CS_PIN);
  pinMode(LED,OUTPUT);
  while (CAN_OK == CAN0.begin(MCP_ANY, CAN_500KBPS, MCP_8MHZ)) //can bus : baudrate = 500k
    Serial.println("CAN BUS Shield Baslatmasi Basarili!");
  Serial.println("CAN BUS Shield Baslatma Hatasi");
  Serial.println("CAN BUS Shield Tekrar Baslatiliyor…");
  delay(100);
  unsigned char len = 0;
  unsigned char buf[8]={0,0,0,0,0,0,0,0};
  if(CAN_MSGAVAIL == CAN0.checkReceive())
    CAN0.readMsgBuf(&len, buf);
    unsigned long canId = CAN0.getCanId();
    Serial.println("—————————–");
    Serial.print("Verici ID: 0x");
    Serial.println(canId, HEX);
    for(int i = 0; i<len; i++)
      Serial.print(buf[i]);
      Serial.print("\t");
      digitalWrite(LED, buf[0]);
      delay(100);
error messages
/tmp/332594481/sketch_may13a/sketch_may13a.ino: In function 'void loop()':
/tmp/332594481/sketch_may13a/sketch_may13a.ino:26:30: error: no matching function for call to 'MCP_CAN::readMsgBuf(char*, unsigned char [8])'
In file included from /tmp/332594481/sketch_may13a/sketch_may13a.ino:2:0:
/home/builder/opt/libraries/latest/mcp_can_1_5_0/mcp_can.h:119:11: note: candidate: byte MCP_CAN::readMsgBuf(long unsigned int*, byte*, byte*, byte*)
INT8U readMsgBuf(INT32U *id, INT8U *ext, INT8U *len, INT8U *buf); // Read message from receive buffer
/home/builder/opt/libraries/latest/mcp_can_1_5_0/mcp_can.h:119:11: note: candidate expects 4 arguments, 2 provided
/home/builder/opt/libraries/latest/mcp_can_1_5_0/mcp_can.h:120:11: note: candidate: byte MCP_CAN::readMsgBuf(long unsigned int*, byte*, byte*)
INT8U readMsgBuf(INT32U *id, INT8U *len, INT8U *buf); // Read message from receive buffer
/home/builder/opt/libraries/latest/mcp_can_1_5_0/mcp_can.h:120:11: note: candidate expects 3 arguments, 2 provided
/tmp/332594481/sketch_may13a/sketch_may13a.ino:27:32: error: 'class MCP_CAN' has no member named 'getCanId'; did you mean 'getGPI'?
getGPI
Error during build: exit status 1
The MCP_CAN class's readMsgBuf() function takes 3 or 4 parameters. From mcp_can.h:
The error message told you that.
