No matter which expression I use, primary-expression before ; comes up
I'm working on a code that will allow stepper motors to be used with my Futaba Transmitter. Right up to this line below, and no matter what i do, which expression i use I get an expected primary-expression error.
C:\Users\pawly\OneDrive\Personal\Arduino\Tx_Rx_Stepper\Tx_Rx_Stepper.ino: In function 'void setup()':
C:\Users\pawly\OneDrive\Personal\Arduino\Tx_Rx_Stepper\Tx_Rx_Stepper.ino:35:42: error: expected primary-expression before ';' token
 for (int o Dir4,o MS18,pinMode;o++ Output;);
Assistance is appreciated, thank you.
I'm afraid that isn't anything close to valid C syntax, it's just words and symbols strung together.
Hi van_der_decken, this is my defining,
//Define Pins
#define RCPin 2
#define Dir 4
#define STEP 5
#define MS3 6
#define MS2 7
#define MS1 8
#define PulseTimer
#define digitalPinToInterrupt
#define attachInterrupt
#define o
#define Output
does this make it better?
You really need to follow some tutorials.
None of what you’ve posted makes any sense.
You only have to write normal simple code:
const int RCPin = 2;
const int DirPin = 4;
const int StepPin = 5;
const int MS1Pin = 8;
const int MS2Pin = 7;
const int MS3Pin = 6;
  pinMode(RCPin,INPUT);
  pinMode(DirPin, OUTPUT);
  pinMode(StepPin, OUTPUT);
  pinMode(MS1Pin, OUTPUT);
  pinMode(MS2Pin, OUTPUT);
  pinMode(MS3Pin, OUTPUT);
I will only echo what @lastchancename wrote: there are many excellent tutorials on the web which will teach you the basics of programming in C, and many that deal with the Arduino as well. I urge you to make use of one of them.
Very helpful Koepel, thank you. So, if I am using 2 steppers I should put
pinMode(RCPin,INPUT1)
pinMode(RCPin,INPUT2)
[quote="Koepel, post:6, topic:1232052"]
[/quote]
OP, please read the tutorials, and follow some of the examples in the IDE
Making up your own syntax is going to be a very long journey.
Word. But how cool would it be to be able to say
and have that one line of code do whatever that's supposed to be doing?
a7
The question is…
What do you think it should be doing ?
You’re the only one !
Well, substituting in these wacky defines:
it translates to this nonsense:
for (int Dir4, MS18, pinMode; ++ ;);
No wonder the compiler complained.
