I have an Arduino MKR GSM 1400 with a Hologram IoT Sim-Card. Unfortunately I could only connect to 2G-Networks so far because I live in a rural Area. I'm using the following antennas and add a battery to the Arduino additionally to a USB-Connection.
My code looks pretty much like a example-Code from Arduino or Hologram:
Web client
This sketch connects to a website through a MKR GSM 1400 board. Specifically,
this example downloads the URL "http://www.example.org/" and
prints it to the Serial monitor.
Circuit:
* MKR GSM 1400 board
* Antenna
* SIM card with a data plan
created 8 Mar 2012
by Tom Igoe
// libraries
#include <MKRGSM.h>
#include "arduino_secrets.h"
// Please enter your sensitive data in the Secret tab or arduino_secrets.h
// PIN Number
const char PINNUMBER[] = " ";
// APN data
const char GPRS_APN[] = "hologram";
const char GPRS_LOGIN[] = " ";
const char GPRS_PASSWORD[] = " ";
// initialize the library instance
GSMClient client;111111111111111111111
GPRS gprs;
GSM gsmAccess(true);
// URL, path and port (for example: example.org)
char server[] = "http://www.example.org";
char path[] = "/";
int port = 80; // port 80 is the default for HTTP
// initialize serial communications and wait for port to open:
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
Serial.println("Starting Arduino web client.");
// connection state
bool connected = false;
// After starting the modem with GSM.begin()
// attach the shield to the GPRS network with the APN, login and password
while (!connected) {
Serial.println("Begin gsm Access");
Serial.println(gsmAccess.begin(0,true,false)); //Uncomment for testing
if ((gsmAccess.begin() == GSM_READY) &&
(gprs.attachGPRS(GPRS_APN, GPRS_LOGIN, GPRS_PASSWORD) == GPRS_READY)) {
connected = true;
Serial.println("GSM Access Success");
else {
Serial.println("Not connected");
Serial.println("connecting...");
// if you get a connection, report back via serial:
if (client.connect(server, port)) {
Serial.println("connected");
// Make a HTTP request:
client.print("GET ");
client.print(path);
client.println(" HTTP/1.1");
client.print("Host: ");
client.println(server);
client.println("Connection: close");
client.println();
// if you didn't get a connection to the server:
Serial.println("connection failed");
Serial.println("loop start");
// if there are incoming bytes available
// from the server, read them and print them:
if (client.available()) {
char c = client.read();
Serial.print(c);
// if the server's disconnected, stop the client:
if (!client.available() && !client.connected()) {
Serial.println("disconnecting.");
client.stop();
// do nothing forevermore:
for (;;)
By using this code I get the following output (including AT-Commands):
Begin gsm Access
⸮AT
OK
AT+IPR=921600
OK
AT
OK
AT+UPSV=3
OK
0
⸮AT
OK
AT+IPR=921600
OK
AT
OK
AT+UPSV=3
OK
AT+CPIN?
ERROR
AT+CPIN?
+CPIN: READY
OK
AT+CMGF=1
OK
AT+UDCONF=1,1
OK
AT+CTZU=1
OK
AT+UDTMFD=1,2
OK
AT+CREG?
+CREG: 0,0
OK
AT+CREG?
+CREG: 0,0
OK
AT+CREG?
+CREG: 0,0
OK
AT+CREG?
+CREG: 0,0
OK
AT+CREG?
+CREG: 0,0
OK
AT+CREG?
+CREG: 0,0
OK
AT+CREG?
+CREG: 0,0
OK
+UMWI: 0,1
+UMWI: 0,2
+UMWI: 0,3
+UMWI: 0,4
AT+CREG?
+CREG: 0,0
OK
AT+CREG?
+CREG: 0,0
OK
AT+CREG?
+CREG: 0,0
OK
AT+CREG?
+CREG: 0,0
OK
AT+CREG?
+CREG: 0,0
OK
AT+CREG?
+CREG: 0,0
OK
AT+CREG?
+CREG: 0,0
OK
AT+CREG?
+CREG: 0,0
OK
AT+CREG?
+CREG: 0,0
OK
AT+CREG?
+CREG: 0,0
OK
AT+CREG?
+CREG: 0,0
OK
AT+CREG?
+CREG: 0,0
OK
AT+CREG?
+CREG: 0,0
OK
AT+CREG?
+CREG: 0,0
OK
AT+CREG?
+CREG: 0,0
OK
AT+CREG?
+CREG: 0,0
OK
AT+CREG?
+CREG: 0,0
OK
AT+CREG?
+CREG: 0,0
OK
AT+CREG?
+CREG: 0,0
OK
AT+CREG?
+CREG: 0,0
OK
AT+CREG?
+CREG: 0,0
OK
AT+CREG?
+CREG: 0,0
OK
AT+CREG?
+CREG: 0,0
OK
AT+CREG?
+CREG: 0,0
OK
AT+CREG?
+CREG: 0,0
OK
AT+CREG?
+CREG: 0,0
OK
AT+CREG?
+CREG: 0,0
OK
AT+CREG?
+CREG: 0,0
OK
AT+CREG?
+CREG: 0,0
OK
AT+CREG?
+CREG: 0,0
OK
AT+CREG?
+CREG: 0,0
OK
AT+CREG?
+CREG: 0,0
OK
AT+CREG?
+CREG: 0,0
OK
AT+CREG?
+CREG: 0,0
OK
AT+CREG?
+CREG: 0,0
OK
AT+CREG?
+CREG: 0,0
OK
AT+CREG?
+CREG: 0,0
OK
AT+CREG?
+CREG: 0,0
OK
AT+CREG?
+CREG: 0,0
OK
AT+CREG?
+CREG: 0,0
OK
AT+CREG?
+CREG: 0,0
OK
AT+CREG?
+CREG: 0,0
OK
AT+CREG?
+CREG: 0,0
OK
AT+CREG?
+CREG: 0,0
OK
AT+CREG?
+CREG: 0,0
OK
AT+CREG?
+CREG: 0,0
OK
AT+CREG?
+CREG: 0,0
OK
AT+CREG?
+CREG: 0,0
OK
AT+CREG?
+CREG: 0,0
OK
AT+CREG?
+CREG: 0,0
OK
AT+CREG?
+CREG: 0,0
OK
AT+CREG?
+CREG: 0,0
OK
AT+CREG?
+CREG: 0,5
OK
AT+UCALLSTAT=1
OK
AT+CGATT=1
OK
AT+UPSD=0,1,"hologram"
OK
AT+UPSD=0,6,3
OK
AT+UPSD=0,2," "
OK
AT+UPSD=0,3," "
OK
AT+UPSD=0,7,"0.0.0.0"
OK
AT+UPSDA=0,3
OK
AT+UPSND=0,8
+UPSND: 0,8,1
OK
GSM Access Success
connecting...
AT+USOCR=6
+USOCR: 0
OK
AT+USOCO=0,"http://www.example.org",80
ERROR
+UUSOCL: 0
AT+USOCL=0
ERROR
connection failed
loop start
disconnecting.
Even though it looks like no connection was made, when looking to the Hologram dashboard it has recognized a connection-attempt, here's a part of Holograms JSON-output:
"success":true,
"data":[
"session_id":606420301,
"devicename":"Pilot (---)",
"deviceid":347664,
"sim":"---",
"starttime":"2019-07-28 10:09:04",
"endtime":"2019-07-28 11:09:42",
"bytes":190,
"imei":"---",
"radio_access_technology":"2G",
"network_name":"T-Mobile Austria GmbH",
"tags":[
Do you have any idea on how I should change my code to reliably get data over 2G? Should I increase my timeout maybe? How would I do this?
