No More Quick Edit
Quick edit has stopped working (for me). If it works or does not work for you please post.
The problem appears to stem from a bug in a security check.
It works for me. What are the symptoms you are experiencing?
No action when Save is clicked. The button click, from my perspective, is ignored. It happens when editing another's post.
Added by UKHeliBob using Quick Edit
a normal edit would go to captcha. quick edit doesn't save
Seems to work for me - see post #2
Moderator edit: nothing to see here
Yup. Works now. Must have been captcha. Thanks all!
I still get hit and miss with Quick Edit, save does not do anything (I'm on a Mac)
(my 'workaround' to not loose my work = select all, copy text, cancel changes, go to "Modify", select text, paste, save --> get the captcha but at least you get the hard work you had put in when editing in the first place...)
