I was doing project 5 from the arduino starter kit and once everything was set up and the code was written and uploaded, the servo motor would twitch, but the arm would not move.
Here is my code:
#include<Servo.h>
Servo myServo;
int const potPin=A0;
int potVal;
int angle;
myServo.attach(9);
potVal=analogRead(potPin);
Serial.print("potVal: ");
Serial.print(potVal);
angle=map(potVal,0,1023,0,179);
Serial.print(",angle: ");
Serial.println(angle);
myServo.write(angle);
delay(30);
How do I get the motor to move to the appropriate angle?
//zoomkat 7-30-10 serial servo test
//type servo position 0 to 180 in serial monitor
// Powering a servo from the arduino usually *DOES NOT WORK*.
String readString;
#include <Servo.h>
Servo myservo; // create servo object to control a servo
myservo.attach(9);
Serial.println("servo-test"); // so I can keep track of what is loaded
while (Serial.available()) {
char c = Serial.read(); //gets one byte from serial buffer
readString += c; //makes the String readString
delay(2); //slow looping to allow buffer to fill with next character
if (readString.length() >0) {
Serial.println(readString); //so you can see the captured String
int n = readString.toInt(); //convert readString into a number
Serial.println(n); //so you can see the integer
myservo.write(n);
readString="";
