I have this ESP32 and I'm connecting a lidar to it. My lidar has its i2c pins connected to IO27 and IO26 on the ESP32. Nothing is being printed out onto the arduino serial monitor when I run that bare code. What is wrong with the code? I am using a custom esp32 board and I think that might be interfering with the output
Code:
#include <Wire.h>
#include <SparkFun_VL53L5CX_Library.h> //http://librarymanager/All#SparkFun_VL53L5CX
SparkFun_VL53L5CX myImager;
VL53L5CX_ResultsData measurementData; // Result data class structure, 1356 byes of RAM
int imageResolution = 0; //Used to pretty print output
int imageWidth = 0; //Used to pretty print output
Serial.println("SparkFun VL53L5CX Imager Example");
//Note: The following line will fail to compile if your platform does not have multiple Wire ports
Wire1.begin(27, 26); //(SDA, SCL) on ESP32. This resets I2C bus to 100kHz
Wire1.setClock(400000); //Sensor has max I2C freq of 400kHz
Serial.println("Initializing sensor board at address 0x3C on Wire port Wire1. This can take up to 10s. Please wait.");
if (myImager.begin(0x29, Wire1) == false) //Device address (0x29 is default), Wire port
Serial.println(F("Sensor not found - check your wiring. Freezing"));
while (1) ;
myImager.setResolution(8 * 8); //Enable all 64 pads
imageResolution = myImager.getResolution(); //Query sensor for current resolution - either 4x4 or 8x8
imageWidth = sqrt(imageResolution); //Calculate printing width
myImager.startRanging();
//Poll sensor for new data
if (myImager.isDataReady() == true)
if (myImager.getRangingData(&measurementData)) //Read distance data into array
//The ST library returns the data transposed from zone mapping shown in datasheet
//Pretty-print data with increasing y, decreasing x to reflect reality
for (int y = 0 ; y <= imageWidth * (imageWidth - 1) ; y += imageWidth)
for (int x = imageWidth - 1 ; x >= 0 ; x--)
Serial.print("\t");
Serial.print(measurementData.distance_mm[x + y]);
delay(5); //Small delay between polling
