Hi guys, i am having problem connecting my Arduino to my computer.
there is no port in tools.
here is a screenshot what i get when i try to connect it.
No picture to be seen.
Maybe some of these tips will help.
Always provide as much detail as possible to your issue it may be important.
If applicable provide your SKETCH inside CODE TAGS ( </> ) or a CREATE share link.
If applicable provide a schematic even if hand drawn.
How to insert a picture into your post
If applicable provide a proper LINK to the hardware / sensors etc. you are using.
COMMON ISSUES -
Check you have a COMMON GROUND where required.
Where possible use USB 2.0 ports or a USB 2.0 POWERED HUB to rule out USB 3.0 issues.
Try other computers where possible.
Try other USB leads where possible.
You may not have the correct driver installed. CH340/341 or CP2102
There may be a problem with the board check your wiring first.
Remove any items connected to pins 0 and 1.
COMPUTER RELATED -
close any other serial programs before opening the IDE.
Ensure you turn off any additional security / antivirus just to test.
There may be a problem with the PC try RESTARTING it.
You may be selecting the wrong COM port.
Avoid cloud/network based installations where possible OR ensure your Network/Cloud software is RUNNING.
Clear your browsers CACHE.
Close the IDE before using any other serial programs.
Preferably install IDE's as ADMINISTRATOR or your OS equivalent
Arduino specific boards -
NANO (Old Types) some require you to use the OLD BOOTLOADER option.
NANO (New Types) See the specific sections lower in the forum.
Performing the above actions may help resolve your problem without further help.
Bob.
Yesterday I had a max7219 on my desk move to the monitor stand and then the port disappeared. I think it was shorting and thus the computer shut down the port. make sure you don't have anything like that.
