No ports discovered for Nano Clone
Hi, its the first time i am using Arduino for University and for the past 2h i have tried to set up IDE 2.3.3 to use with an Arduino Nano Clone. I installed the necessary CH-340-Drivers and tried everything on the Arduino Troubleshooting Website, and now i am just lost.
The LEDs on the Arduino are on and the cable works, but i have not found the board in the device manager (Windows11).
Any Ideas how i could fix this?
Thank you in advance for every answer.
You should have one LED on (the power LED) and if this a new board you should have the L-LED flashing (1 second on, 1 second off). Other LEDs (rx an tx) should not be steady on.
you are right, i was imprecise. its like you described, the power LED is steady and the L-LED is flashing
Try different cables; you might be using a charge-only cable instead of a data/sync cables. The former often come with Bluetooth speakers or power banks.
use CH132 driver.Check com&lpt in device manager
