No Serial data ESP32 CAM
I am getting the following error using ESP32CAM. Kindly tell me what might be the reason for this???
Arduino: 1.8.19 (Windows 10), Board: "ESP32 Wrover Module, Default 4MB with spiffs (1.2MB APP/1.5MB SPIFFS), QIO, 80MHz, 921600, None, Disabled"
> E:\arduino-1.8.19\arduino-builder -dump-prefs -logger=machine -hardware E:\arduino-1.8.19\hardware -hardware C:\Users\DELL\AppData\Local\Arduino15\packages -tools E:\arduino-1.8.19\tools-builder -tools E:\arduino-1.8.19\hardware\tools\avr -tools C:\Users\DELL\AppData\Local\Arduino15\packages -built-in-libraries E:\arduino-1.8.19\libraries -libraries F:\libraries -fqbn=esp32:esp32:esp32wrover:PartitionScheme=default,FlashMode=qio,FlashFreq=80,UploadSpeed=921600,DebugLevel=none,EraseFlash=none -vid-pid=0403_6001 -ide-version=10819 -build-path C:\Users\DELL\AppData\Local\Temp\arduino_build_301038 -warnings=none -build-cache C:\Users\DELL\AppData\Local\Temp\arduino_cache_657351 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.xtensa-esp32s2-elf-gcc.path=C:\Users\DELL\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s2-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.xtensa-esp32s2-elf-gcc-gcc8_4_0-esp-2021r2-patch3.path=C:\Users\DELL\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s2-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.riscv32-esp-elf-gcc.path=C:\Users\DELL\AppData\Local\Arduino15\packages\esp32\tools\riscv32-esp-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.riscv32-esp-elf-gcc-gcc8_4_0-esp-2021r2-patch3.path=C:\Users\DELL\AppData\Local\Arduino15\packages\esp32\tools\riscv32-esp-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.xtensa-esp32s3-elf-gcc.path=C:\Users\DELL\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s3-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.xtensa-esp32s3-elf-gcc-gcc8_4_0-esp-2021r2-patch3.path=C:\Users\DELL\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s3-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.mkspiffs.path=C:\Users\DELL\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.mkspiffs-0.2.3.path=C:\Users\DELL\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.esptool_py.path=C:\Users\DELL\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\4.2.1 -prefs=runtime.tools.esptool_py-4.2.1.path=C:\Users\DELL\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\4.2.1 -prefs=runtime.tools.xtensa-esp32-elf-gcc.path=C:\Users\DELL\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.xtensa-esp32-elf-gcc-gcc8_4_0-esp-2021r2-patch3.path=C:\Users\DELL\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.mklittlefs.path=C:\Users\DELL\AppData\Local\Arduino15\packages\esp32\tools\mklittlefs\3.0.0-gnu12-dc7f933 -prefs=runtime.tools.mklittlefs-3.0.0-gnu12-dc7f933.path=C:\Users\DELL\AppData\Local\Arduino15\packages\esp32\tools\mklittlefs\3.0.0-gnu12-dc7f933 -verbose C:\Users\DELL\AppData\Local\Temp\untitled1343571470.tmp\sketch_sep30a\sketch_sep30a.ino
> E:\arduino-1.8.19\arduino-builder -compile -logger=machine -hardware E:\arduino-1.8.19\hardware -hardware C:\Users\DELL\AppData\Local\Arduino15\packages -tools E:\arduino-1.8.19\tools-builder -tools E:\arduino-1.8.19\hardware\tools\avr -tools C:\Users\DELL\AppData\Local\Arduino15\packages -built-in-libraries E:\arduino-1.8.19\libraries -libraries F:\libraries -fqbn=esp32:esp32:esp32wrover:PartitionScheme=default,FlashMode=qio,FlashFreq=80,UploadSpeed=921600,DebugLevel=none,EraseFlash=none -vid-pid=0403_6001 -ide-version=10819 -build-path C:\Users\DELL\AppData\Local\Temp\arduino_build_301038 -warnings=none -build-cache C:\Users\DELL\AppData\Local\Temp\arduino_cache_657351 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.xtensa-esp32s2-elf-gcc.path=C:\Users\DELL\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s2-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.xtensa-esp32s2-elf-gcc-gcc8_4_0-esp-2021r2-patch3.path=C:\Users\DELL\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s2-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.riscv32-esp-elf-gcc.path=C:\Users\DELL\AppData\Local\Arduino15\packages\esp32\tools\riscv32-esp-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.riscv32-esp-elf-gcc-gcc8_4_0-esp-2021r2-patch3.path=C:\Users\DELL\AppData\Local\Arduino15\packages\esp32\tools\riscv32-esp-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.xtensa-esp32s3-elf-gcc.path=C:\Users\DELL\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s3-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.xtensa-esp32s3-elf-gcc-gcc8_4_0-esp-2021r2-patch3.path=C:\Users\DELL\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s3-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.mkspiffs.path=C:\Users\DELL\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.mkspiffs-0.2.3.path=C:\Users\DELL\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.esptool_py.path=C:\Users\DELL\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\4.2.1 -prefs=runtime.tools.esptool_py-4.2.1.path=C:\Users\DELL\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\4.2.1 -prefs=runtime.tools.xtensa-esp32-elf-gcc.path=C:\Users\DELL\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.xtensa-esp32-elf-gcc-gcc8_4_0-esp-2021r2-patch3.path=C:\Users\DELL\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.mklittlefs.path=C:\Users\DELL\AppData\Local\Arduino15\packages\esp32\tools\mklittlefs\3.0.0-gnu12-dc7f933 -prefs=runtime.tools.mklittlefs-3.0.0-gnu12-dc7f933.path=C:\Users\DELL\AppData\Local\Arduino15\packages\esp32\tools\mklittlefs\3.0.0-gnu12-dc7f933 -verbose C:\Users\DELL\AppData\Local\Temp\untitled1343571470.tmp\sketch_sep30a\sketch_sep30a.ino
> Using board 'esp32wrover' from platform in folder: C:\Users\DELL\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5
> Using core 'esp32' from platform in folder: C:\Users\DELL\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5
> cmd /c if exist "C:\\Users\\DELL\\AppData\\Local\\Temp\\untitled1343571470.tmp\\sketch_sep30a\\partitions.csv" COPY /y "C:\\Users\\DELL\\AppData\\Local\\Temp\\untitled1343571470.tmp\\sketch_sep30a\\partitions.csv" "C:\\Users\\DELL\\AppData\\Local\\Temp\\arduino_build_301038\\partitions.csv"
> cmd /c if not exist "C:\\Users\\DELL\\AppData\\Local\\Temp\\arduino_build_301038\\partitions.csv" if exist "C:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5\\variants\\esp32\\partitions.csv" COPY "C:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5\\variants\\esp32\\partitions.csv" "C:\\Users\\DELL\\AppData\\Local\\Temp\\arduino_build_301038\\partitions.csv"
> cmd /c if not exist "C:\\Users\\DELL\\AppData\\Local\\Temp\\arduino_build_301038\\partitions.csv" COPY "C:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5\\tools\\partitions\\default.csv" "C:\\Users\\DELL\\AppData\\Local\\Temp\\arduino_build_301038\\partitions.csv"
> cmd /c IF EXIST "C:\\Users\\DELL\\AppData\\Local\\Temp\\untitled1343571470.tmp\\sketch_sep30a\\bootloader.bin" ( COPY /y "C:\\Users\\DELL\\AppData\\Local\\Temp\\untitled1343571470.tmp\\sketch_sep30a\\bootloader.bin" "C:\\Users\\DELL\\AppData\\Local\\Temp\\arduino_build_301038\\sketch_sep30a.ino.bootloader.bin" ) ELSE ( IF EXIST "C:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5\\variants\\esp32\\bootloader.bin" ( COPY "C:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5\\variants\\esp32\\bootloader.bin" "C:\\Users\\DELL\\AppData\\Local\\Temp\\arduino_build_301038\\sketch_sep30a.ino.bootloader.bin" ) ELSE ( "C:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esptool_py\\4.2.1/esptool.exe" --chip esp32 elf2image --flash_mode dio --flash_freq 80m --flash_size 4MB -o "C:\\Users\\DELL\\AppData\\Local\\Temp\\arduino_build_301038\\sketch_sep30a.ino.bootloader.bin" "C:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5\\tools\\sdk\\esp32\\bin\\bootloader_qio_80m.elf" ) )
esptool.py v4.2.1
Creating esp32 image...
Merged 1 ELF section
Successfully created esp32 image.
cmd /c if exist "C:\\Users\\DELL\\AppData\\Local\\Temp\\untitled1343571470.tmp\\sketch_sep30a\\build_opt.h" COPY /y "C:\\Users\\DELL\\AppData\\Local\\Temp\\untitled1343571470.tmp\\sketch_sep30a\\build_opt.h" "C:\\Users\\DELL\\AppData\\Local\\Temp\\arduino_build_301038\\build_opt.h"
cmd /c if not exist "C:\\Users\\DELL\\AppData\\Local\\Temp\\arduino_build_301038\\build_opt.h" type nul > "C:\\Users\\DELL\\AppData\\Local\\Temp\\arduino_build_301038\\build_opt.h"
Detecting libraries used...
"C:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\gcc8_4_0-esp-2021r2-patch3/bin/xtensa-esp32-elf-g++" -DHAVE_CONFIG_H "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DUNITY_INCLUDE_CONFIG_H -DWITH_POSIX -D_GNU_SOURCE "-DIDF_VER=\"v4.4.2\"" -DESP_PLATFORM -D_POSIX_READER_WRITER_LOCKS "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/newlib/platform_include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/freertos/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/freertos/include/esp_additions/freertos" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/freertos/port/xtensa/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/freertos/include/esp_additions" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_hw_support/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_hw_support/include/soc" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_hw_support/include/soc/esp32" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_hw_support/port/esp32" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_hw_support/port/esp32/private_include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/heap/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/log/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/lwip/include/apps" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/lwip/include/apps/sntp" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/lwip/lwip/src/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/lwip/port/esp32/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/lwip/port/esp32/include/arch" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/soc/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/soc/esp32" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/soc/esp32/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/hal/esp32/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/hal/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/hal/platform_port/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_rom/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_rom/include/esp32" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_rom/esp32" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_common/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_system/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_system/port/soc" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_system/port/public_compat" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp32/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/xtensa/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/xtensa/esp32/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/driver/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/driver/esp32/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_pm/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_ringbuf/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/efuse/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/efuse/esp32/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/vfs/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_wifi/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_event/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_netif/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_eth/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/tcpip_adapter/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_phy/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_phy/esp32/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_ipc/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/app_trace/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_timer/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/mbedtls/port/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/mbedtls/mbedtls/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/mbedtls/esp_crt_bundle/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/app_update/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/spi_flash/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bootloader_support/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/nvs_flash/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/pthread/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_gdbstub/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_gdbstub/xtensa" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_gdbstub/esp32" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/espcoredump/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/espcoredump/include/port/xtensa" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/wpa_supplicant/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/wpa_supplicant/port/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/wpa_supplicant/esp_supplicant/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/ieee802154/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/console" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/asio/asio/asio/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/asio/port/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/common/osi/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/include/esp32/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/common/api/include/api" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/common/btc/profile/esp/blufi/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/common/btc/profile/esp/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/host/bluedroid/api/include/api" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/tinycrypt/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/storage" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/btc/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/common/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/client/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/server/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/api/core/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/api/models/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/api" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/cbor/port/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/unity/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/unity/unity/src" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/cmock/CMock/src" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/coap/port/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/coap/libcoap/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/nghttp/port/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/nghttp/nghttp2/lib/includes" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-tls" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-tls/esp-tls-crypto" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_adc_cal/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_hid/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/tcp_transport/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_http_client/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_http_server/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_https_ota/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_https_server/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_lcd/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_lcd/interface" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/protobuf-c/protobuf-c" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/protocomm/include/common" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/protocomm/include/security" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/protocomm/include/transports" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/mdns/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_local_ctrl/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/sdmmc/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_serial_slave_link/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_websocket_client/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/expat/expat/expat/lib" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/expat/port/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/wear_levelling/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/fatfs/diskio" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/fatfs/vfs" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/fatfs/src" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/freemodbus/common/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/idf_test/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/idf_test/include/esp32" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/jsmn/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/json/cJSON" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/libsodium/libsodium/src/libsodium/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/libsodium/port_include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/mqtt/esp-mqtt/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/openssl/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/perfmon/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/spiffs/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/ulp/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/wifi_provisioning/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/rmaker_common/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/json_parser/upstream/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/json_parser/upstream" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/json_generator/upstream" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_schedule/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_rainmaker/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/gpio_button/button/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/qrcode/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/ws2812_led" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/dotprod/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/support/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/hann/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/blackman/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/blackman_harris/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/blackman_nuttall/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/nuttall/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/flat_top/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/iir/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/fir/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/add/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/sub/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/mul/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/addc/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/mulc/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/sqrt/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/matrix/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/fft/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/dct/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/conv/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/common/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/kalman/ekf/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/kalman/ekf_imu13states/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_littlefs/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dl/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dl/include/tool" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dl/include/typedef" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dl/include/image" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dl/include/math" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dl/include/nn" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dl/include/layer" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dl/include/detect" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dl/include/model_zoo" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-sr/src/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-sr/esp-tts/esp_tts_chinese/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-sr/include/esp32" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp32-camera/driver/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp32-camera/conversions/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/fb_gfx/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/qio_qspi/include" -mlongcalls -Wno-frame-address -ffunction-sections -fdata-sections -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -ggdb -Os -freorder-blocks -Wwrite-strings -fstack-protector -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -fno-jump-tables -fno-tree-switch-conversion -std=gnu++11 -fexceptions -fno-rtti -c -w -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10819 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_default -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue -mfix-esp32-psram-cache-strategy=memw -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\DELL\\AppData\\Local\\Temp\\arduino_build_301038/build_opt.h" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5\\cores\\esp32" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5\\variants\\esp32" "C:\\Users\\DELL\\AppData\\Local\\Temp\\arduino_build_301038\\sketch\\sketch_sep30a.ino.cpp" -o nul
Generating function prototypes...
"C:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\gcc8_4_0-esp-2021r2-patch3/bin/xtensa-esp32-elf-g++" -DHAVE_CONFIG_H "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DUNITY_INCLUDE_CONFIG_H -DWITH_POSIX -D_GNU_SOURCE "-DIDF_VER=\"v4.4.2\"" -DESP_PLATFORM -D_POSIX_READER_WRITER_LOCKS "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/newlib/platform_include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/freertos/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/freertos/include/esp_additions/freertos" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/freertos/port/xtensa/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/freertos/include/esp_additions" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_hw_support/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_hw_support/include/soc" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_hw_support/include/soc/esp32" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_hw_support/port/esp32" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_hw_support/port/esp32/private_include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/heap/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/log/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/lwip/include/apps" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/lwip/include/apps/sntp" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/lwip/lwip/src/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/lwip/port/esp32/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/lwip/port/esp32/include/arch" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/soc/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/soc/esp32" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/soc/esp32/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/hal/esp32/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/hal/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/hal/platform_port/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_rom/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_rom/include/esp32" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_rom/esp32" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_common/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_system/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_system/port/soc" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_system/port/public_compat" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp32/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/xtensa/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/xtensa/esp32/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/driver/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/driver/esp32/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_pm/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_ringbuf/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/efuse/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/efuse/esp32/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/vfs/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_wifi/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_event/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_netif/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_eth/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/tcpip_adapter/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_phy/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_phy/esp32/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_ipc/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/app_trace/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_timer/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/mbedtls/port/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/mbedtls/mbedtls/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/mbedtls/esp_crt_bundle/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/app_update/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/spi_flash/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bootloader_support/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/nvs_flash/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/pthread/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_gdbstub/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_gdbstub/xtensa" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_gdbstub/esp32" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/espcoredump/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/espcoredump/include/port/xtensa" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/wpa_supplicant/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/wpa_supplicant/port/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/wpa_supplicant/esp_supplicant/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/ieee802154/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/console" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/asio/asio/asio/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/asio/port/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/common/osi/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/include/esp32/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/common/api/include/api" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/common/btc/profile/esp/blufi/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/common/btc/profile/esp/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/host/bluedroid/api/include/api" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/tinycrypt/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/storage" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/btc/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/common/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/client/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/server/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/api/core/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/api/models/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/api" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/cbor/port/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/unity/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/unity/unity/src" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/cmock/CMock/src" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/coap/port/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/coap/libcoap/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/nghttp/port/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/nghttp/nghttp2/lib/includes" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-tls" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-tls/esp-tls-crypto" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_adc_cal/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_hid/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/tcp_transport/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_http_client/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_http_server/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_https_ota/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_https_server/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_lcd/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_lcd/interface" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/protobuf-c/protobuf-c" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/protocomm/include/common" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/protocomm/include/security" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/protocomm/include/transports" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/mdns/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_local_ctrl/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/sdmmc/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_serial_slave_link/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_websocket_client/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/expat/expat/expat/lib" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/expat/port/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/wear_levelling/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/fatfs/diskio" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/fatfs/vfs" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/fatfs/src" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/freemodbus/common/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/idf_test/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/idf_test/include/esp32" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/jsmn/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/json/cJSON" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/libsodium/libsodium/src/libsodium/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/libsodium/port_include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/mqtt/esp-mqtt/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/openssl/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/perfmon/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/spiffs/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/ulp/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/wifi_provisioning/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/rmaker_common/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/json_parser/upstream/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/json_parser/upstream" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/json_generator/upstream" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_schedule/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_rainmaker/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/gpio_button/button/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/qrcode/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/ws2812_led" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/dotprod/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/support/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/hann/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/blackman/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/blackman_harris/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/blackman_nuttall/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/nuttall/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/flat_top/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/iir/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/fir/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/add/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/sub/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/mul/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/addc/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/mulc/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/sqrt/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/matrix/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/fft/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/dct/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/conv/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/common/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/kalman/ekf/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/kalman/ekf_imu13states/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_littlefs/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dl/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dl/include/tool" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dl/include/typedef" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dl/include/image" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dl/include/math" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dl/include/nn" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dl/include/layer" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dl/include/detect" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dl/include/model_zoo" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-sr/src/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-sr/esp-tts/esp_tts_chinese/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-sr/include/esp32" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp32-camera/driver/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp32-camera/conversions/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/fb_gfx/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/qio_qspi/include" -mlongcalls -Wno-frame-address -ffunction-sections -fdata-sections -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -ggdb -Os -freorder-blocks -Wwrite-strings -fstack-protector -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -fno-jump-tables -fno-tree-switch-conversion -std=gnu++11 -fexceptions -fno-rtti -c -w -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10819 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_default -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue -mfix-esp32-psram-cache-strategy=memw -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\DELL\\AppData\\Local\\Temp\\arduino_build_301038/build_opt.h" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5\\cores\\esp32" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5\\variants\\esp32" "C:\\Users\\DELL\\AppData\\Local\\Temp\\arduino_build_301038\\sketch\\sketch_sep30a.ino.cpp" -o "C:\\Users\\DELL\\AppData\\Local\\Temp\\arduino_build_301038\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"E:\\arduino-1.8.19\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\DELL\\AppData\\Local\\Temp\\arduino_build_301038\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\gcc8_4_0-esp-2021r2-patch3/bin/xtensa-esp32-elf-g++" -DHAVE_CONFIG_H "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DUNITY_INCLUDE_CONFIG_H -DWITH_POSIX -D_GNU_SOURCE "-DIDF_VER=\"v4.4.2\"" -DESP_PLATFORM -D_POSIX_READER_WRITER_LOCKS "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/newlib/platform_include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/freertos/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/freertos/include/esp_additions/freertos" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/freertos/port/xtensa/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/freertos/include/esp_additions" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_hw_support/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_hw_support/include/soc" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_hw_support/include/soc/esp32" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_hw_support/port/esp32" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_hw_support/port/esp32/private_include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/heap/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/log/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/lwip/include/apps" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/lwip/include/apps/sntp" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/lwip/lwip/src/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/lwip/port/esp32/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/lwip/port/esp32/include/arch" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/soc/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/soc/esp32" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/soc/esp32/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/hal/esp32/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/hal/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/hal/platform_port/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_rom/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_rom/include/esp32" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_rom/esp32" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_common/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_system/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_system/port/soc" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_system/port/public_compat" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp32/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/xtensa/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/xtensa/esp32/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/driver/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/driver/esp32/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_pm/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_ringbuf/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/efuse/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/efuse/esp32/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/vfs/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_wifi/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_event/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_netif/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_eth/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/tcpip_adapter/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_phy/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_phy/esp32/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_ipc/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/app_trace/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_timer/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/mbedtls/port/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/mbedtls/mbedtls/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/mbedtls/esp_crt_bundle/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/app_update/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/spi_flash/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bootloader_support/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/nvs_flash/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/pthread/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_gdbstub/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_gdbstub/xtensa" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_gdbstub/esp32" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/espcoredump/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/espcoredump/include/port/xtensa" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/wpa_supplicant/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/wpa_supplicant/port/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/wpa_supplicant/esp_supplicant/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/ieee802154/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/console" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/asio/asio/asio/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/asio/port/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/common/osi/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/include/esp32/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/common/api/include/api" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/common/btc/profile/esp/blufi/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/common/btc/profile/esp/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/host/bluedroid/api/include/api" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/tinycrypt/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/storage" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/btc/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/common/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/client/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/server/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/api/core/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/api/models/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/bt/esp_ble_mesh/api" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/cbor/port/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/unity/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/unity/unity/src" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/cmock/CMock/src" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/coap/port/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/coap/libcoap/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/nghttp/port/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/nghttp/nghttp2/lib/includes" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-tls" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-tls/esp-tls-crypto" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_adc_cal/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_hid/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/tcp_transport/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_http_client/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_http_server/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_https_ota/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_https_server/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_lcd/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_lcd/interface" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/protobuf-c/protobuf-c" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/protocomm/include/common" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/protocomm/include/security" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/protocomm/include/transports" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/mdns/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_local_ctrl/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/sdmmc/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_serial_slave_link/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_websocket_client/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/expat/expat/expat/lib" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/expat/port/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/wear_levelling/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/fatfs/diskio" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/fatfs/vfs" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/fatfs/src" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/freemodbus/common/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/idf_test/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/idf_test/include/esp32" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/jsmn/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/json/cJSON" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/libsodium/libsodium/src/libsodium/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/libsodium/port_include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/mqtt/esp-mqtt/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/openssl/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/perfmon/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/spiffs/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/ulp/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/wifi_provisioning/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/rmaker_common/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/json_parser/upstream/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/json_parser/upstream" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/json_generator/upstream" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_schedule/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_rainmaker/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/gpio_button/button/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/qrcode/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/ws2812_led" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/dotprod/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/support/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/hann/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/blackman/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/blackman_harris/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/blackman_nuttall/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/nuttall/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/windows/flat_top/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/iir/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/fir/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/add/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/sub/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/mul/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/addc/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/mulc/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/math/sqrt/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/matrix/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/fft/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/dct/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/conv/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/common/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/kalman/ekf/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dsp/modules/kalman/ekf_imu13states/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp_littlefs/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dl/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dl/include/tool" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dl/include/typedef" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dl/include/image" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dl/include/math" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dl/include/nn" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dl/include/layer" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dl/include/detect" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-dl/include/model_zoo" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-sr/src/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-sr/esp-tts/esp_tts_chinese/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp-sr/include/esp32" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp32-camera/driver/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/esp32-camera/conversions/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/include/fb_gfx/include" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/qio_qspi/include" -mlongcalls -Wno-frame-address -ffunction-sections -fdata-sections -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -ggdb -Os -freorder-blocks -Wwrite-strings -fstack-protector -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -fno-jump-tables -fno-tree-switch-conversion -std=gnu++11 -fexceptions -fno-rtti -MMD -c -w -DF_CPU=240000000L -DARDUINO=10819 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_default -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue -mfix-esp32-psram-cache-strategy=memw -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\DELL\\AppData\\Local\\Temp\\arduino_build_301038/build_opt.h" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5\\cores\\esp32" "-IC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5\\variants\\esp32" "C:\\Users\\DELL\\AppData\\Local\\Temp\\arduino_build_301038\\sketch\\sketch_sep30a.ino.cpp" -o "C:\\Users\\DELL\\AppData\\Local\\Temp\\arduino_build_301038\\sketch\\sketch_sep30a.ino.cpp.o"
Compiling libraries...
Compiling core...
Using precompiled core: C:\Users\DELL\AppData\Local\Temp\arduino_cache_657351\core\core_b14f5ff1b329204d4a193dec0e29fa70.a
Linking everything together...
"C:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\gcc8_4_0-esp-2021r2-patch3/bin/xtensa-esp32-elf-g++" "-Wl,--Map=C:\\Users\\DELL\\AppData\\Local\\Temp\\arduino_build_301038/sketch_sep30a.ino.map" "-LC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/lib" "-LC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/ld" "-LC:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32/qio_qspi" -T esp32.rom.redefined.ld -T memory.ld -T sections.ld -T esp32.rom.ld -T esp32.rom.api.ld -T esp32.rom.libgcc.ld -T esp32.rom.newlib-data.ld -T esp32.rom.syscalls.ld -T esp32.peripherals.ld -mlongcalls -Wno-frame-address -Wl,--cref -Wl,--gc-sections -fno-rtti -fno-lto -u ld_include_hli_vectors_bt -u _Z5setupv -u _Z4loopv -u esp_app_desc -u pthread_include_pthread_impl -u pthread_include_pthread_cond_impl -u pthread_include_pthread_local_storage_impl -u pthread_include_pthread_rwlock_impl -u include_esp_phy_override -u ld_include_highint_hdl -u start_app -u start_app_other_cores -u __ubsan_include -Wl,--wrap=longjmp -u __assert_func -u vfs_include_syscalls_impl -Wl,--undefined=uxTopUsedPriority -u app_main -u newlib_include_heap_impl -u newlib_include_syscalls_impl -u newlib_include_pthread_impl -u newlib_include_assert_impl -u __cxa_guard_dummy -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue -mfix-esp32-psram-cache-strategy=memw -DARDUINO_USB_CDC_ON_BOOT=0 -Wl,--start-group "C:\\Users\\DELL\\AppData\\Local\\Temp\\arduino_build_301038\\sketch\\sketch_sep30a.ino.cpp.o" "C:\\Users\\DELL\\AppData\\Local\\Temp\\arduino_cache_657351\\core\\core_b14f5ff1b329204d4a193dec0e29fa70.a" -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lxtensa -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lasio -lbt -lcbor -lunity -lcmock -lcoap -lnghttp -lesp-tls -lesp_adc_cal -lesp_hid -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lesp_https_server -lesp_lcd -lprotobuf-c -lprotocomm -lmdns -lesp_local_ctrl -lsdmmc -lesp_serial_slave_link -lesp_websocket_client -lexpat -lwear_levelling -lfatfs -lfreemodbus -ljsmn -ljson -llibsodium -lmqtt -lopenssl -lperfmon -lspiffs -lulp -lwifi_provisioning -lrmaker_common -ljson_parser -ljson_generator -lesp_schedule -lesp_rainmaker -lgpio_button -lqrcode -lws2812_led -lesp-dsp -lesp-sr -lesp32-camera -lesp_littlefs -lfb_gfx -lasio -lcbor -lcmock -lunity -lcoap -lesp_lcd -lesp_websocket_client -lexpat -lfreemodbus -ljsmn -llibsodium -lperfmon -lesp_adc_cal -lesp_hid -lfatfs -lwear_levelling -lopenssl -lesp_rainmaker -lesp_local_ctrl -lesp_https_server -lwifi_provisioning -lprotocomm -lbt -lbtdm_app -lprotobuf-c -lmdns -lrmaker_common -lmqtt -ljson_parser -ljson_generator -lesp_schedule -lqrcode -lcat_face_detect -lhuman_face_detect -lcolor_detect -lmfn -ldl -lmultinet -lesp_audio_processor -lesp_audio_front_end -lwakenet -lesp-sr -lmultinet -lesp_audio_processor -lesp_audio_front_end -lwakenet -ljson -lspiffs -ldl_lib -lc_speech_features -lwakeword_model -lmultinet2_ch -lesp_tts_chinese -lvoice_set_xiaole -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lxtensa -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lnghttp -lesp-tls -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lsdmmc -lesp_serial_slave_link -lulp -lmbedtls_2 -lmbedcrypto -lmbedx509 -lcoexist -lcore -lespnow -lmesh -lnet80211 -lpp -lsmartconfig -lwapi -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lxtensa -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lnghttp -lesp-tls -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lsdmmc -lesp_serial_slave_link -lulp -lmbedtls_2 -lmbedcrypto -lmbedx509 -lcoexist -lcore -lespnow -lmesh -lnet80211 -lpp -lsmartconfig -lwapi -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lxtensa -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lnghttp -lesp-tls -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lsdmmc -lesp_serial_slave_link -lulp -lmbedtls_2 -lmbedcrypto -lmbedx509 -lcoexist -lcore -lespnow -lmesh -lnet80211 -lpp -lsmartconfig -lwapi -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lxtensa -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lnghttp -lesp-tls -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lsdmmc -lesp_serial_slave_link -lulp -lmbedtls_2 -lmbedcrypto -lmbedx509 -lcoexist -lcore -lespnow -lmesh -lnet80211 -lpp -lsmartconfig -lwapi -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lxtensa -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lnghttp -lesp-tls -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lsdmmc -lesp_serial_slave_link -lulp -lmbedtls_2 -lmbedcrypto -lmbedx509 -lcoexist -lcore -lespnow -lmesh -lnet80211 -lpp -lsmartconfig -lwapi -lphy -lrtc -lesp_phy -lphy -lrtc -lesp_phy -lphy -lrtc -lxt_hal -lm -lnewlib -lstdc++ -lpthread -lgcc -lcxx -lapp_trace -lgcov -lapp_trace -lgcov -lc -Wl,--end-group -Wl,-EL -o "C:\\Users\\DELL\\AppData\\Local\\Temp\\arduino_build_301038/sketch_sep30a.ino.elf"
"C:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esptool_py\\4.2.1/esptool.exe" --chip esp32 elf2image --flash_mode dio --flash_freq 80m --flash_size 4MB -o "C:\\Users\\DELL\\AppData\\Local\\Temp\\arduino_build_301038/sketch_sep30a.ino.bin" "C:\\Users\\DELL\\AppData\\Local\\Temp\\arduino_build_301038/sketch_sep30a.ino.elf"
esptool.py v4.2.1
Creating esp32 image...
Merged 2 ELF sections
Successfully created esp32 image.
"C:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/gen_esp32part.exe" -q "C:\\Users\\DELL\\AppData\\Local\\Temp\\arduino_build_301038/partitions.csv" "C:\\Users\\DELL\\AppData\\Local\\Temp\\arduino_build_301038/sketch_sep30a.ino.partitions.bin"
"C:\\Users\\DELL\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\gcc8_4_0-esp-2021r2-patch3/bin/xtensa-esp32-elf-size" -A "C:\\Users\\DELL\\AppData\\Local\\Temp\\arduino_build_301038/sketch_sep30a.ino.elf"
Sketch uses 227801 bytes (17%) of program storage space. Maximum is 1310720 bytes.
Global variables use 16128 bytes (4%) of dynamic memory, leaving 311552 bytes for local variables. Maximum is 327680 bytes.
esptool.py v4.2.1
Serial port COM3
Connecting......................................
**A fatal error occurred: Failed to connect to ESP32: No serial data received.**
**For troubleshooting steps visit: https://docs.espressif.com/projects/esptool/en/latest/troubleshooting.html**
**the selected serial port For troubleshooting steps visit: https://docs.espressif.com/projects/esptool/en/latest/troubleshooting.html**
** does not exist or your board is not connected**
When you see the ... did you press the button on the ESP32-CAM to begin the upload?
Show an image of how you got the ESP32-CAM connected.
Yes, I have pressed that... For how long do we need to connect it
Not knowing the meaning of "it", I do not know how long you need to connect 'it'.
Did you post the image of your project, yet?
This is the picture of the project. I first used the FTDI which didn't work therefore I used Arduino to connect the esp32CAM.
Sorry I meant to say that for how long do we need to press the button??
A moment.
So after you have uploaded the program, did you remove the programing jumper and reboots?
Oh, and I've not used an Uno to program a ESP32-CAM before. I'll not be of much help without the experience. Sorry to had wasted your time.
Good luck.
The program didn't upload and gave the error so I didn't remove the jumpers. Do I need to remove it before the dots come...
An ESP32CAM is a 3.3V device; and to my knowledge its pins are not 5V tolerant.
As I don't see a voltage divider in your image, be advised that you should not feed the Arduino's TX directly into the ESP32CAM's RX. There is a chance that you have damaged the ESP32CAM.
You can try connecting to the board with Arduino Serial Monitor and set the buad rate to 115200, then reset the board you must see some lines appear on the serial monitor. If it didn't appear there must be a problem with you wire connection or the board is burnt. But if some text appear the reason you can't program the board is because it is not flash mode, what you need to do is first connect the IO0 pin to ground then press reset and program the board
