good day! can you help me what is wrong with my code because when i try to print out the value of Datastring via serial there is no output
#include <EEPROM.h>
#include <Keypad.h>
#include <MQUnifiedsensor.h>
#include <virtuabotixRTC.h>
#include <dht.h>
#include <SPI.h>
#include <SD.h>
//system variables
unsigned long previousMillis = 0;
String DataString;
String _date, _time;
bool armed = false;
byte rowPins[4] = {38, 39, 40, 41}; //connect to the row pinouts of the keypad
byte colPins[4] = {42, 43, 44, 45}; //connect to the column pinouts of the keypad
char PIN[4];
char initialPIN[4];
char newPIN[4];
char inputKey = 0;
int keyCounter = 0;
int keyCheckCounter = 0;
char keys[4][4] = {
{'1', '2', '3', 'A'},
{'4', '5', '6', 'B'},
{'7', '8', '9', 'C'},
{'*', '0', '#', 'D'}
//Sensor Variables
int FireSensorData;
int SW420Data;
double temp;
double humi;
//class instances
Keypad keypad = Keypad(makeKeymap(keys), rowPins, colPins, 4, 4);
LiquidCrystal_I2C lcd(0x27, 16, 2); // I2C address 0x27, 16 column and 2 rows
MQUnifiedsensor CarbonMonoxide("Arduino Mega", 5, 10, A13,"MQ-6");
MQUnifiedsensor LiquifiedPetroleumGas("Arduino Mega", 5, 10, A14,"MQ-6");
virtuabotixRTC RealTimeClock(6,7,8); //SCLK, DAT, RST Pins
dht DHT22Sensor;
File MicroSDModule;
void HaltAlarm();
void TriggerAlarm();
//String getRTC();
//String getPPM_CO;
//String getPPM_LPG;
//String getFireSensor();
void setup() { // put your setup code here, to run once
Serial3.begin(115200);
Serial2.begin(115200);
RealTimeClock.setDS1302Time(00, 30, 02, 24, 12, 18, 2023);
setWiring();
HaltAlarm();
initialize();
initCO();
inputKey = keypad.getKey(); // get a key (if pressed)
if (inputKey == '#') {
resetPIN();
if (keyCounter >= 4) {
delay(200);
for (int counter = 0; counter < 4; counter++) {
initialPIN[counter] = EEPROM.read(counter);
if (!(strncmp(PIN, initialPIN, 4))) {
lcd.clear();
lcd.print("System disarming...");
delay(2000);
if(armed == true)
armed = false;
TriggerAlarm();
lcd.setCursor(0, 1);
lcd.print("System disarmed.");
delay(10000);
lcd.clear();
lcd.print("Arming system.... ");
delay(10000);
armed = true;
lcd.clear();
lcd.print("System is armed.");
lcd.print("Sensor Activated.");
delay(2000);
lcd.clear();
lcd.print("Enter PIN:");
keyCounter = 0;
keyCheckCounter = keyCheckCounter + 1;
lcd.clear();
lcd.print("Wrong PIN input.");
lcd.print("Please Try Again.");
if (keyCheckCounter >= 3) {
lcd.clear();
lcd.print("Retry in ");
for (int i = 10; i > 0; i--) {
lcd.setCursor(9, 0);
lcd.print((i / 10) % 10);
lcd.print(i % 10);
lcd.clear();
lcd.print("Enter PIN: ");
keyCounter = 0;
if (inputKey == '*') {
if (keyCounter > 0)
PIN[keyCounter--];
lcd.setCursor(keyCounter+11, 0);
if (keyCounter > 0)
lcd.print("* ");
lcd.print(" ");
delay(100);
if (inputKey) {
PIN[keyCounter++] = inputKey;
lcd.print("* ");
delay(100);
if(inputKey == 'A'){
lcd.clear();
lcd.print("Calling Ambulance..");
//call("ATD+ +639704911690");
//NotificationLog("Called One Hospital Command");
lcd.clear();
lcd.print("Calling ended..");
delay(2000);
lcd.clear();
if(inputKey == 'B'){
lcd.clear();
lcd.print("Calling Police Station 1..");
//call("ATD+ +639184644371");
//NotificationLog("Called PNP");
lcd.clear();
delay(2000);
lcd.clear();
if(inputKey == 'C'){
lcd.clear();
lcd.print("Calling Fire Station..");
//call("ATD+ +639230839429");
//NotificationLog("Called BFP");
lcd.clear();
delay(2000);
lcd.clear();
if(inputKey == 'D'){
lcd.clear();
lcd.print("Calling Papa..");
//call("ATD+ +639981986397");
//NotificationLog("Called Contact Person");
lcd.clear();
delay(2000);
lcd.clear();
unsigned long _millis = millis();
if(_millis - previousMillis >= 1000){
DataString = getRTC();
DataString = DataString + getDHT22Sensor();
DataString = DataString + getPPM_CO();
DataString = DataString + getPPM_LPG();
DataString = DataString + getReedSwitch();
DataString = DataString + getPIRSensor();
DataString = DataString + getFireSensor();
DataString = DataString + getSW420Sensor();
DataString = DataString + getWaterLevelSensor();
Serial.println(DataString);
SensorLog(DataString);
previousMillis = _millis;
Serial2.println(DataString);
void resetPIN() {
int counter = 0;
lcd.clear();
lcd.print("Current PIN: ");
lcd.setCursor(13,0);
delay(100);
while (counter < 4) {
char x = keypad.getKey();
if (x) {
delay(200);
newPIN[counter++] = x;
lcd.print(x);
x = 0;
if ((strncmp(newPIN, initialPIN, 4))) {
lcd.clear();
lcd.print("Wrong PIN");
lcd.print("Try Again");
else {
counter = 0;
lcd.clear();
lcd.print("New PIN: ");
if (x) {
delay(200);
initialPIN[counter] = x;
lcd.print(x);
EEPROM.write(counter, x);
counter++;
lcd.clear();
lcd.print("PIN Changed..");
lcd.clear();
inputKey = 0;
void initialize(){
lcd.begin();// initialize the lcd
lcd.home();
lcd.print("HOME SECURITY SYSTEM");
delay(2000); // Waiting for a while
lcd.clear();
lcd.print(" Press # to ");
lcd.print("Change PIN");
lcd.clear();
lcd.print("Enter PIN: "); //What's written on the lcd you can change
if (EEPROM.read(100) == 0) {}
else {
EEPROM.write(counter, counter + 49);
EEPROM.write(100, 0);
for (int counter = 0; counter < 4; counter++) { //read code from EEPROM
void setWiring(){
//Passive Infrared (PIR) Sensor
pinMode(4, INPUT);
pinMode(5, INPUT);
//SW420 Vibration Sensor
pinMode(22, INPUT);
// Fire Sensor
pinMode(7, INPUT);
//Reed Switch Pins
pinMode(30, INPUT_PULLUP); // INPUT_PULLUP = input pin that uses a built-in 10 Kilo-Ohms resistor from microcontroller
pinMode(31, INPUT_PULLUP);
pinMode(32, INPUT_PULLUP);
//MQ-6 Air Quality Sensors
pinMode(A13, INPUT);
pinMode(A14, INPUT);
//Water Level Sensor
pinMode(36, OUTPUT);
//DHT22 Temperature and Humidity Sensor
pinMode(37, INPUT);
//4x4 Keypad Module
pinMode(38, INPUT);
pinMode(39, INPUT);
pinMode(40, INPUT);
pinMode(41, INPUT);
pinMode(42, INPUT);
pinMode(43, INPUT);
pinMode(44, INPUT);
pinMode(45, INPUT);
//4 Channnel Low Trigger Relay Module
pinMode(46, OUTPUT);
pinMode(47, OUTPUT);
pinMode(48, OUTPUT);
pinMode(49, OUTPUT);
//MicroSD Module
pinMode(53, INPUT);
//Set Relay Module to Off
digitalWrite(46, HIGH);
digitalWrite(47, HIGH);
digitalWrite(48, HIGH);
digitalWrite(49, HIGH);
void initCO(){
CarbonMonoxide.setRegressionMethod(1);
CarbonMonoxide.setA(1000000000000000);
CarbonMonoxide.setB(-13.5);
CarbonMonoxide.init();
float calculatedR0 = 0;
for(int i = 1; i<=10; i ++){
CarbonMonoxide.update(); // Update data, the arduino will read the voltage from the analog pin
calculatedR0 += CarbonMonoxide.calibrate(10);
CarbonMonoxide.setR0(calculatedR0/10);
if(isinf(calculatedR0)) {
//sendSMS("Warning(A0): CO Conection issue, R0 is infinite (Open circuit detected) please check your wiring and supply");
while(1);
if(calculatedR0 == 0){
//sendSMS("Warning(A0): CO Conection issue found, R0 is zero (Analog pin shorts to ground) please check your wiring and supply");
while(1);
void initLPG(){
LiquifiedPetroleumGas.setRegressionMethod(1);
LiquifiedPetroleumGas.setA(1009.2);
LiquifiedPetroleumGas.setB(-2.35);
LiquifiedPetroleumGas.init();
LiquifiedPetroleumGas.update(); // Update data, the arduino will read the voltage from the analog pin
calculatedR0 += LiquifiedPetroleumGas.calibrate(10);
LiquifiedPetroleumGas.setR0(calculatedR0/10);
//sendSMS("Warning(A0): LPG Conection issue, R0 is infinite (Open circuit detected) please check your wiring and supply");
while(1);
//sendSMS("Warning(A0): LPG Conection issue found, R0 is zero (Analog pin shorts to ground) please check your wiring and supply");
while(1);
//sensor functions
String getRTC(){
String rtc;
RealTimeClock.updateTime();
rtc = String(RealTimeClock.month);
rtc = rtc + '/';
rtc= rtc + String(RealTimeClock.dayofmonth);
rtc = rtc + '/';
rtc = rtc + String(RealTimeClock.year);
rtc = rtc + ",";
rtc= rtc + String(RealTimeClock.hours);
rtc = rtc + ':';
rtc = rtc + String(RealTimeClock.minutes);
rtc = rtc + ':';
rtc = rtc + String(RealTimeClock.seconds);
return rtc;
String getPPM_CO(){
String COStrData;
float COData = CarbonMonoxide.readSensor();
COStrData = String(COData);
if(COData >= 50){
//sendSMS("Deadly concentration of Carbon Monoxide detected. Please contact your local authorities.");
TriggerAlarm();
COStrData = COStrData + ", Triggered,";
COStrData = COStrData + ", Armed,";
return COStrData;
String getPPM_LPG(){
String LPGStrData;
float LPGData = LiquifiedPetroleumGas.readSensor();
LPGStrData = String(LPGData);
if(LPGData >= 1000){
//sendSMS("Dangerous concentration of Liquified Petroleum Gas detected. Please contact your local authorities.");
TriggerAlarm();
LPGStrData = LPGStrData + ", Triggered,";
LPGStrData = LPGStrData + ", Armed,";
return LPGStrData;
String getFireSensor(){
String FireSensorStrData;
FireSensorData = digitalRead(33);
FireSensorStrData = String(FireSensorData);
if(FireSensorData == LOW){
//sendSMS("Fire detected at your house. Please contact your local Fire Station.");
TriggerAlarm();
FireSensorStrData = FireSensorStrData + ", Triggered,";
FireSensorStrData = FireSensorStrData + ", Armed,";
return FireSensorStrData;
String getSW420Sensor(){
String SW420StrData;
SW420Data = digitalRead(22);
SW420StrData = String(SW420Data);
if(SW420Data == HIGH){
//sendSMS("Earthquake detected. Locate a safe area and call local DRRM office.");
TriggerAlarm();
SW420StrData = SW420StrData + ", Triggered,";
SW420StrData = SW420StrData + ", Armed,";
return SW420StrData;
String getDHT22Sensor(){
String DHTStrData;
double DHT22SensorData = DHT22Sensor.read(37);
temp = DHT22Sensor.temperature;
humi = DHT22Sensor.humidity;
DHTStrData = DHTStrData + String(temp) + ',' + String(humi) + ',';
if(temp >= 70.0){
//sendSMS("Extreme tempearture detected. Locate a safe area and call local DRRM office.");
TriggerAlarm();
DHTStrData = DHTStrData + ", Triggered,";
DHTStrData = DHTStrData + ", Armed,";
return DHTStrData;
String getReedSwitch(){
String ReedStrData;
int reed1 = digitalRead(30);
int reed2 = digitalRead(31);
int reed3 = digitalRead(32);
ReedStrData = String(reed1);
if (reed1 == LOW){
ReedStrData = ReedStrData + ", Main Door, Triggered,";
TriggerAlarm();
ReedStrData = ReedStrData + ", Main Door, Armed,";
ReedStrData = ReedStrData + String(reed2);
if (reed2 == LOW){
ReedStrData = ReedStrData + ", Back Door, Triggered,";
TriggerAlarm();
ReedStrData = ReedStrData + ", Back Door, Armed,";
ReedStrData = ReedStrData + String(reed3);
if (reed3 == LOW){
ReedStrData = ReedStrData + ", Window, Triggered,";
TriggerAlarm();
ReedStrData = ReedStrData + ", Window, Armed,";
return ReedStrData;
String getWaterLevelSensor(){
String WaterLevelStrData;
digitalWrite(36, HIGH);
int WaterLevelData = analogRead(A13);
digitalWrite(36, LOW);
WaterLevelStrData = String(WaterLevelData);
if (WaterLevelData < 0 || WaterLevelData > 600){
//sendSMS("Water Level Sensor is compromised. Please contact the service provider immediately.");
WaterLevelStrData = WaterLevelStrData +", Error,";
else if(WaterLevelData >= 100 && WaterLevelData >= 450){
//sendSMS("Water detected. Please do precautionary measures immediately.");
WaterLevelStrData = WaterLevelStrData + ", Armed,";
else if(WaterLevelData > 450 && WaterLevelData <= 600){
//sendSMS("Water Level rising. Call your nearest DRRM Office immediately.");
TriggerAlarm();
WaterLevelStrData = WaterLevelStrData + ", Triggered,";
return WaterLevelStrData;
String getPIRSensor() {
String PIRStrData;
int PIR1 = digitalRead(4);
int PIR2 = digitalRead(5);
PIRStrData =String(PIR1);
if (PIR1 == HIGH){
PIRStrData = PIRStrData + ", Area 1, Triggered,";
TriggerAlarm();
PIRStrData = PIRStrData + ", Area 1, Armed,";
PIRStrData = PIRStrData + String(PIR2);
if (PIR2 == HIGH){
PIRStrData = PIRStrData + ", Area 2, Triggered,";
TriggerAlarm();
PIRStrData = PIRStrData + ", Area 2, Armed,";
void SensorLog(String DataString){
MicroSDModule = SD.open("DataLogFile.txt", FILE_WRITE);
if(!MicroSDModule){
Serial.print("Error Opening File. Restart the System");
//sendSMS("Error Opening the File. Restart the System");
lcd.clear();
lcd.print("Error file Opening..");
lcd.setCursor(0,1);
lcd.print("Restart the system..");
while(true){;}
return;
else{
MicroSDModule.println(DataString);
MicroSDModule.close();
//void NotificationLog(String Notif){
// String datetime = _date + ' ' +_time + ' ';
// MicroSDModule = SD.open("NotifLog.txt", FILE_WRITE);
// if(!MicroSDModule){
// Serial.print("Error Opening File. Restart the System");
// //sendSMS("Error Opening the File. Restart the System");
// lcd.clear();
// lcd.print("Error logfile Opening..");
// lcd.setCursor(0,1);
// lcd.print("Restart the system..");
// while(true){;}
// return;
// else{
// MicroSDModule.print(datetime);
// MicroSDModule.println(Notif);
// MicroSDModule.close();
void TriggerAlarm(){
if(armed){
digitalWrite(46, LOW);
digitalWrite(47, LOW);
digitalWrite(48, LOW);
digitalWrite(49, LOW);
HaltAlarm();
void HaltAlarm() {
//SIM900 Module
//void call(String phone){
// String num = phone;
// Serial3.print(num);
// if(Serial3.available()){
// Serial.print((unsigned char)Serial3.read());
// delay(2000);
// Serial3.println("ATH");
//void sendSMS(String message) {
// String text = message + "\r";
// Serial3.print("\r");
// delay(500);
// Serial3.print("AT+CMGF=1\r");
// delay(500);
// Serial3.print("AT+CMGS=\"+639981986397");
// delay(1000);
// Serial3.print(text); //"Some Text + \r" format
// delay(1000);
// Serial3.write(0x1A);
