Hello Arduino forum,
I want Serial debug capability after the MKR1000 wakes from standbyMode, but I cannot successfully demonstrate this. Serial debug is possible before going into standbyMode. Serial debug does not appear after waking from standbyMode.
To test this, I modified Arturo Guadalupi’s “Sleep RTC Alarm for Arduino Zero” example on www.arduino.cc and available as an example sketch. In my modifications, I added Serial statements and use the builtin LED for help.
Arturo adds the following note in the comment header:
- NOTE:*
- If you use this sketch with a MKR1000 you will see no output on the serial monitor.*
- This happens because the USB clock is stopped so it the USB connection is stopped too.*
_ To see again the USB port you have to double tap on the reset button!_
Well, a double tap on the reset button won’t help me. I was hoping to ‘work around’ that by issuing various commands, such as Serial.flush(), Serial.begin(), Serial.end(). None of my modifications have worked, yet.
Refer to my code below. But here is brief pseudocode:
- MKR1000 all Serial text to the COM port as expected. No issues.
- It is here where you attach the interupt, set the alarm and enter standbyMode. No issues.
void alarmMatch () - ‘ISR’ works as expected. No issues.
void loop() - global variable holds alarm expiration state T/F.
- if the alarm expired…
- Issue Serial.begin (again) and include while loop.
- I send text to the Serial port. Serial.println(blah blah blah) : ERROR I never see it.
- I issue Serial.flush() command : nothing happens
- I wait 8s…
- Then I enable the built-in LED. I observe this. This means all the preceding statements execute.
Does anyone have any suggestions?
Considering Arturo’s message, does anyone know how to re-enable the USB clock without double-tap of reset line?
I would greatly appreciate any assistance from the community.
Some additional information:
- Arduino 1.8.0 Client on Window PC
- MKR1000 with Firmware v19.5.2
- WiFi Library v0.14.3
MKR1000-RTC-Serial-Test-20170727
Note: I modified the example code reference below to test
support for the Serial command after an rtc.standby().
The original comment header resumes, below...
Demonstrates the use an alarm to wake up an Arduino zero from Standby mode
This example code is in the public domain
http://arduino.cc/en/Tutorial/SleepRTCAlarm
created by Arturo Guadalupi
17 Nov 2015
modified
01 Mar 2016
NOTE:
**To see again the USB port you have to double tap on the reset button!**
#include <RTCZero.h>
/* Create an rtc object */
RTCZero rtc;
/* Change these values to set the current initial time */
const byte seconds = 0;
const byte minutes = 00;
const byte hours = 17;
/* Change these values to set the current initial date */
const byte day = 17;
const byte month = 11;
const byte year = 15;
boolean alarmExpired = false;
#define __SERIAL_PRESENT__
pinMode(LED_BUILTIN, OUTPUT);
digitalWrite(LED_BUILTIN, LOW);
#ifdef __SERIAL_PRESENT__
while (!Serial) {
Serial.println("--------------------------------------------");
Serial.println("MKR1000-RTC-Serial-Test-20170727");
Serial.println("Initializing the MKR1000 RTC...");
#endif
rtc.begin();
rtc.setTime(hours, minutes, seconds);
rtc.setDate(day, month, year);
Serial.println("Setting and enabling the MKR1000 RTC Alarm...");
#endif
rtc.setAlarmTime(17, 00, 10);
rtc.enableAlarm(rtc.MATCH_HHMMSS);
Serial.println("Attaching the interrupt...");
#endif
rtc.attachInterrupt(alarmMatch);
Serial.println("Entering MKR1000 Standby Mode...");
Serial.flush();
Serial.end();
#endif
rtc.standbyMode();
if (alarmExpired == true) {
while (!Serial) {
// ERROR: I do not see this text in the Serial Monitor.
// ERROR: I do not see any text after rtc.standbyMode()...
Serial.println("The MKR1000 RTC Alarm Expired...");
Serial.flush();
delay(8000);
digitalWrite(LED_BUILTIN, HIGH);
#endif
// digitalWrite(LED_BUILTIN, HIGH);
rtc.standbyMode(); // Sleep until next alarm match
void alarmMatch()
alarmExpired = true;
