Sorry Guys, after 3 days of trying I have to call for help.
Story.
Some time ago I started a design project that I had to shelve for a while. Recently I decided to do some more work on it. Before I shelved it the project worked fine, now it doesn't. I have upgraded my computers and the Arduino IDE since that time.
The project originally consisted of a keypad, Feather MO (SAMD21), RA8875 tft driver board and a tft display.
When I returned to the project it would not boot the display. Assuming the worst I replaced the Feather with a Zero and changed the RA8875 for a new part. Still no success. Further investigation shows that the Zero is not recognizing the RA8875 for some reason.
Here is the simple test code that I am using, it is based on the Adafruit RA8875 library example "textmode".
#include <SPI.h>
#include <Adafruit_GFX.h>
#include <Adafruit_RA8875.h>
// Library only supports hardware SPI at this time
// Connect SCLK to Zero header pin 3
// Connect MISO to Zero header pin 1
// Connect MOSI to Zero header pin 4
#define RA8875_INT 3
#define RA8875_CS 10
#define RA8875_RESET 9
Adafruit_RA8875 tft = Adafruit_RA8875(RA8875_CS, RA8875_RESET);
uint16_t tx, ty;
Serial.println("RA8875 start");
/* Initialise the display using 'RA8875_480x272' or 'RA8875_800x480' */
if (!tft.begin(RA8875_800x480)) {
Serial.println("RA8875 Not Found!");
while (1);
pinMode(RA8875_CS, OUTPUT);
tft.displayOn(true);
tft.GPIOX(true); // Enable TFT - display enable tied to GPIOX
delay(200);
tft.PWM1config(true, RA8875_PWM_CLK_DIV1024); // PWM output for backlight
tft.PWM1out(255);
tft.fillScreen(RA8875_GREEN);
I put the "pinMode" line into the code as a result of reading some Arduino documentation.
The immediate problem is that the program fails to find the RA8875. Serial monitor says "RA8875 Start" immediately followed by "RA8875 not found". I have replaced both the Zeros and the RA8875 during troubleshooting. This may be a misleading warning because when I 'scope the SPI signals I see no SPI clock. All other signals seem to be changing except the SPI clock and the INT signal.
Anyone see any obvious errors before I dig more deeply?
Thanks.
