ghulse
April 12, 2024, 3:35pm
1
I've been trying to load a sketch to a ESP32 2.8inch TFT Touch Screen Display Module (otherwise known as Cheap Yellow Display). The device is connected via USB.
I keep getting directory errors when I Verify the code. Not sure what's happening. Any help would be appreciated.
FQBN: esp32:esp32:esp32s2usb
Using board 'esp32s2usb' from platform in folder: /Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15
Using core 'esp32' from platform in folder: /Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15
/usr/bin/env bash -c "[ ! -f \"/Users/ghulse/Documents/Arduino/servo_with_pir\"/partitions.csv ] || cp -f \"/Users/ghulse/Documents/Arduino/servo_with_pir\"/partitions.csv \"/private/var/folders/nc/h1l3t0n14n335tsh3y9nrz300000gn/T/arduino/sketches/D667DF0661F72997D2307FB41C597132\"/partitions.csv"
/usr/bin/env bash -c "[ -f \"/private/var/folders/nc/h1l3t0n14n335tsh3y9nrz300000gn/T/arduino/sketches/D667DF0661F72997D2307FB41C597132\"/partitions.csv ] || [ ! -f \"/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/variants/esp32s2usb\"/partitions.csv ] || cp \"/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/variants/esp32s2usb\"/partitions.csv \"/private/var/folders/nc/h1l3t0n14n335tsh3y9nrz300000gn/T/arduino/sketches/D667DF0661F72997D2307FB41C597132\"/partitions.csv"
/usr/bin/env bash -c "[ -f \"/private/var/folders/nc/h1l3t0n14n335tsh3y9nrz300000gn/T/arduino/sketches/D667DF0661F72997D2307FB41C597132\"/partitions.csv ] || cp \"/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15\"/tools/partitions/default.csv \"/private/var/folders/nc/h1l3t0n14n335tsh3y9nrz300000gn/T/arduino/sketches/D667DF0661F72997D2307FB41C597132\"/partitions.csv"
/usr/bin/env bash -c "[ -f \"/Users/ghulse/Documents/Arduino/servo_with_pir\"/bootloader.bin ] && cp -f \"/Users/ghulse/Documents/Arduino/servo_with_pir\"/bootloader.bin \"/private/var/folders/nc/h1l3t0n14n335tsh3y9nrz300000gn/T/arduino/sketches/D667DF0661F72997D2307FB41C597132\"/servo_with_pir.ino.bootloader.bin || ( [ -f \"/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/variants/esp32s2usb\"/bootloader.bin ] && cp \"/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/variants/esp32s2usb\"/bootloader.bin \"/private/var/folders/nc/h1l3t0n14n335tsh3y9nrz300000gn/T/arduino/sketches/D667DF0661F72997D2307FB41C597132\"/servo_with_pir.ino.bootloader.bin || \"/Users/ghulse/Library/Arduino15/packages/esp32/tools/esptool_py/4.5.1\"/esptool --chip esp32s2 elf2image --flash_mode dio --flash_freq 80m --flash_size 4MB -o \"/private/var/folders/nc/h1l3t0n14n335tsh3y9nrz300000gn/T/arduino/sketches/D667DF0661F72997D2307FB41C597132\"/servo_with_pir.ino.bootloader.bin \"/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2\"/bin/bootloader_qio_80m.elf )"
esptool.py v4.5.1
Creating esp32s2 image...
Merged 1 ELF section
Successfully created esp32s2 image.
/usr/bin/env bash -c "[ ! -f \"/Users/ghulse/Documents/Arduino/servo_with_pir\"/build_opt.h ] || cp -f \"/Users/ghulse/Documents/Arduino/servo_with_pir\"/build_opt.h \"/private/var/folders/nc/h1l3t0n14n335tsh3y9nrz300000gn/T/arduino/sketches/D667DF0661F72997D2307FB41C597132\"/build_opt.h"
/usr/bin/env bash -c "[ -f \"/private/var/folders/nc/h1l3t0n14n335tsh3y9nrz300000gn/T/arduino/sketches/D667DF0661F72997D2307FB41C597132\"/build_opt.h ] || : > \"/private/var/folders/nc/h1l3t0n14n335tsh3y9nrz300000gn/T/arduino/sketches/D667DF0661F72997D2307FB41C597132\"/build_opt.h"
/usr/bin/env bash -c ": > /private/var/folders/nc/h1l3t0n14n335tsh3y9nrz300000gn/T/arduino/sketches/D667DF0661F72997D2307FB41C597132/file_opts"
Detecting libraries used...
/Users/ghulse/Library/Arduino15/packages/esp32/tools/xtensa-esp32s2-elf-gcc/esp-2021r2-patch5-8.4.0/bin/xtensa-esp32s2-elf-g++ -DHAVE_CONFIG_H -DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h" -DUNITY_INCLUDE_CONFIG_H -DWITH_POSIX -D_GNU_SOURCE -DIDF_VER="v4.4.7-dirty" -DESP_PLATFORM -D_POSIX_READER_WRITER_LOCKS -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/newlib/platform_include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/freertos/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/freertos/include/esp_additions/freertos -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/freertos/port/xtensa/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/freertos/include/esp_additions -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/esp_hw_support/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/esp_hw_support/include/soc -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/esp_hw_support/include/soc/esp32s2 -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/esp_hw_support/port/esp32s2 -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/esp_hw_support/port/esp32s2/private_include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/heap/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/log/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/lwip/include/apps -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/lwip/include/apps/sntp -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/lwip/lwip/src/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/lwip/port/esp32/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/lwip/port/esp32/include/arch -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/soc/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/soc/esp32s2 -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/soc/esp32s2/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/hal/esp32s2/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/hal/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/hal/platform_port/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/esp_rom/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/esp_rom/include/esp32s2 -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/esp_rom/esp32s2 -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/esp_common/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/esp_system/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/esp_system/port/soc -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/esp_system/port/public_compat -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/xtensa/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/xtensa/esp32s2/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/driver/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/driver/esp32s2/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/esp_pm/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/esp_ringbuf/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/efuse/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/efuse/esp32s2/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/vfs/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/esp_wifi/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/esp_event/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/esp_netif/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/esp_eth/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/tcpip_adapter/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/esp_phy/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/esp_phy/esp32s2/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/esp_ipc/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/app_trace/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/esp_timer/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/mbedtls/port/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/mbedtls/mbedtls/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/mbedtls/esp_crt_bundle/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/app_update/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/spi_flash/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/bootloader_support/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/nvs_flash/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/pthread/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/esp_gdbstub/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/esp_gdbstub/xtensa -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/esp_gdbstub/esp32s2 -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/espcoredump/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/espcoredump/include/port/xtensa -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/wpa_supplicant/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/wpa_supplicant/port/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/wpa_supplicant/esp_supplicant/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/ieee802154/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/console -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/asio/asio/asio/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/asio/port/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/cbor/port/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/unity/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/unity/unity/src -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/cmock/CMock/src -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/coap/port/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/coap/libcoap/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/nghttp/port/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/nghttp/nghttp2/lib/includes -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/esp-tls -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/esp-tls/esp-tls-crypto -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/esp_adc_cal/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/esp_hid/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/tcp_transport/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/esp_http_client/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/esp_http_server/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/esp_https_ota/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/esp_https_server/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/esp_lcd/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/esp_lcd/interface -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/protobuf-c/protobuf-c -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/protocomm/include/common -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/protocomm/include/security -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/protocomm/include/transports -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/mdns/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/esp_local_ctrl/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/sdmmc/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/esp_serial_slave_link/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/esp_websocket_client/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/expat/expat/expat/lib -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/expat/port/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/wear_levelling/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/fatfs/diskio -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/fatfs/vfs -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/fatfs/src -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/freemodbus/freemodbus/common/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/idf_test/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/idf_test/include/esp32s2 -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/jsmn/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/json/cJSON -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/libsodium/libsodium/src/libsodium/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/libsodium/port_include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/mqtt/esp-mqtt/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/openssl/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/perfmon/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/spiffs/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/usb/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/touch_element/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/ulp/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/wifi_provisioning/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/rmaker_common/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/esp_diagnostics/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/rtc_store/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/esp_insights/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/json_parser/upstream/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/json_parser/upstream -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/json_generator/upstream -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/esp_schedule/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/espressif__esp_secure_cert_mgr/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/esp_rainmaker/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/gpio_button/button/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/qrcode/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/ws2812_led -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/freertos/include/freertos -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/arduino_tinyusb/tinyusb/src -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/arduino_tinyusb/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/esp_littlefs/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/esp-dl/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/esp-dl/include/tool -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/esp-dl/include/typedef -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/esp-dl/include/image -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/esp-dl/include/math -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/esp-dl/include/nn -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/esp-dl/include/layer -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/esp-dl/include/detect -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/esp-dl/include/model_zoo -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/esp32-camera/driver/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/esp32-camera/conversions/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/espressif__esp-dsp/modules/dotprod/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/espressif__esp-dsp/modules/support/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/espressif__esp-dsp/modules/support/mem/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/espressif__esp-dsp/modules/windows/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/espressif__esp-dsp/modules/windows/hann/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/espressif__esp-dsp/modules/windows/blackman/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/espressif__esp-dsp/modules/windows/blackman_harris/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/espressif__esp-dsp/modules/windows/blackman_nuttall/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/espressif__esp-dsp/modules/windows/nuttall/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/espressif__esp-dsp/modules/windows/flat_top/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/espressif__esp-dsp/modules/iir/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/espressif__esp-dsp/modules/fir/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/espressif__esp-dsp/modules/math/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/espressif__esp-dsp/modules/math/add/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/espressif__esp-dsp/modules/math/sub/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/espressif__esp-dsp/modules/math/mul/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/espressif__esp-dsp/modules/math/addc/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/espressif__esp-dsp/modules/math/mulc/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/espressif__esp-dsp/modules/math/sqrt/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/espressif__esp-dsp/modules/matrix/mul/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/espressif__esp-dsp/modules/matrix/add/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/espressif__esp-dsp/modules/matrix/addc/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/espressif__esp-dsp/modules/matrix/mulc/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/espressif__esp-dsp/modules/matrix/sub/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/espressif__esp-dsp/modules/matrix/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/espressif__esp-dsp/modules/fft/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/espressif__esp-dsp/modules/dct/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/espressif__esp-dsp/modules/conv/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/espressif__esp-dsp/modules/common/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/espressif__esp-dsp/modules/matrix/mul/test/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/espressif__esp-dsp/modules/kalman/ekf/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/espressif__esp-dsp/modules/kalman/ekf_imu13states/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/include/fb_gfx/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32s2/qio_qspi/include -mlongcalls -ffunction-sections -fdata-sections -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -ggdb -freorder-blocks -Wwrite-strings -fstack-protector -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -fno-jump-tables -fno-tree-switch-conversion -std=gnu++11 -fexceptions -fno-rtti -c -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32S2_USB -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32S2_USB" -DARDUINO_VARIANT="esp32s2usb" -DARDUINO_PARTITION_default -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_USB_MODE=0 -DARDUINO_USB_CDC_ON_BOOT=1 -DARDUINO_USB_MSC_ON_BOOT=1 -DARDUINO_USB_DFU_ON_BOOT=1 @/private/var/folders/nc/h1l3t0n14n335tsh3y9nrz300000gn/T/arduino/sketches/D667DF0661F72997D2307FB41C597132/build_opt.h @/private/var/folders/nc/h1l3t0n14n335tsh3y9nrz300000gn/T/arduino/sketches/D667DF0661F72997D2307FB41C597132/file_opts -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/cores/esp32 -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/variants/esp32s2usb /private/var/folders/nc/h1l3t0n14n335tsh3y9nrz300000gn/T/arduino/sketches/D667DF0661F72997D2307FB41C597132/sketch/servo_with_pir.ino.cpp -o /dev/null
Alternatives for TFT_eSPI.h: []
ResolveLibrary(TFT_eSPI.h)
-> candidates: []
/Users/ghulse/Documents/Arduino/servo_with_pir/servo_with_pir.ino:26:10: fatal error: TFT_eSPI.h: No such file or directory
#include <TFT_eSPI.h>
compilation terminated.
exit status 1
Compilation error: TFT_eSPI.h: No such file or directory
Have you got this library installed ?
It is available from the IDE Library Manager
Did you install the TFT_eSPI library?
ghulse
April 12, 2024, 5:03pm
4
I do now. Thanks.
I'm still not able to communicate with the board. Not sure which board I'm supposed to select?
This board says esp-wroom-32 on the back. I selected Upesy ESP32 Wroom board in IDE. This is my error now.
FQBN: esp32:esp32:uPesy_wroom
Using board 'uPesy_wroom' from platform in folder: /Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15
/usr/bin/env bash -c "[ -f \"/private/var/folders/nc/h1l3t0n14n335tsh3y9nrz300000gn/T/arduino/sketches/D667DF0661F72997D2307FB41C597132\"/partitions.csv ] || [ ! -f \"/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/variants/uPesy_esp32_wroom_devkit\"/partitions.csv ] || cp \"/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/variants/uPesy_esp32_wroom_devkit\"/partitions.csv \"/private/var/folders/nc/h1l3t0n14n335tsh3y9nrz300000gn/T/arduino/sketches/D667DF0661F72997D2307FB41C597132\"/partitions.csv"
/usr/bin/env bash -c "[ -f \"/Users/ghulse/Documents/Arduino/servo_with_pir\"/bootloader.bin ] && cp -f \"/Users/ghulse/Documents/Arduino/servo_with_pir\"/bootloader.bin \"/private/var/folders/nc/h1l3t0n14n335tsh3y9nrz300000gn/T/arduino/sketches/D667DF0661F72997D2307FB41C597132\"/servo_with_pir.ino.bootloader.bin || ( [ -f \"/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/variants/uPesy_esp32_wroom_devkit\"/bootloader.bin ] && cp \"/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/variants/uPesy_esp32_wroom_devkit\"/bootloader.bin \"/private/var/folders/nc/h1l3t0n14n335tsh3y9nrz300000gn/T/arduino/sketches/D667DF0661F72997D2307FB41C597132\"/servo_with_pir.ino.bootloader.bin || \"/Users/ghulse/Library/Arduino15/packages/esp32/tools/esptool_py/4.5.1\"/esptool --chip esp32 elf2image --flash_mode dio --flash_freq 80m --flash_size 4MB -o \"/private/var/folders/nc/h1l3t0n14n335tsh3y9nrz300000gn/T/arduino/sketches/D667DF0661F72997D2307FB41C597132\"/servo_with_pir.ino.bootloader.bin \"/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32\"/bin/bootloader_qio_80m.elf )"
esptool.py v4.5.1
Creating esp32 image...
Successfully created esp32 image.
/Users/ghulse/Library/Arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/esp-2021r2-patch5-8.4.0/bin/xtensa-esp32-elf-g++ -DHAVE_CONFIG_H -DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h" -DUNITY_INCLUDE_CONFIG_H -DWITH_POSIX -D_GNU_SOURCE -DIDF_VER="v4.4.7-dirty" -DESP_PLATFORM -D_POSIX_READER_WRITER_LOCKS -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/newlib/platform_include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/freertos/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/freertos/include/esp_additions/freertos -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/freertos/port/xtensa/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/freertos/include/esp_additions -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_hw_support/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_hw_support/include/soc -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_hw_support/include/soc/esp32 -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_hw_support/port/esp32 -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_hw_support/port/esp32/private_include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/heap/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/log/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/lwip/include/apps -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/lwip/include/apps/sntp -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/lwip/lwip/src/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/lwip/port/esp32/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/lwip/port/esp32/include/arch -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/soc/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/soc/esp32 -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/soc/esp32/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/hal/esp32/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/hal/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/hal/platform_port/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_rom/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_rom/include/esp32 -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_rom/esp32 -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_common/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_system/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_system/port/soc -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_system/port/public_compat -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp32/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/xtensa/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/xtensa/esp32/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/driver/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/driver/esp32/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_pm/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_ringbuf/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/efuse/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/efuse/esp32/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/vfs/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_wifi/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_event/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_netif/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_eth/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/tcpip_adapter/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_phy/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_phy/esp32/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_ipc/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/app_trace/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_timer/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/mbedtls/port/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/mbedtls/mbedtls/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/mbedtls/esp_crt_bundle/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/app_update/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/spi_flash/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/bootloader_support/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/nvs_flash/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/pthread/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_gdbstub/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_gdbstub/xtensa -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_gdbstub/esp32 -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/espcoredump/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/espcoredump/include/port/xtensa -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/wpa_supplicant/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/wpa_supplicant/port/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/wpa_supplicant/esp_supplicant/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/ieee802154/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/console -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/asio/asio/asio/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/asio/port/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/bt/common/osi/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/bt/include/esp32/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/bt/common/api/include/api -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/bt/common/btc/profile/esp/blufi/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/bt/common/btc/profile/esp/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/bt/host/bluedroid/api/include/api -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/tinycrypt/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/storage -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/bt/esp_ble_mesh/btc/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/common/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/client/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/server/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/bt/esp_ble_mesh/api/core/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/bt/esp_ble_mesh/api/models/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/bt/esp_ble_mesh/api -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/cbor/port/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/unity/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/unity/unity/src -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/cmock/CMock/src -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/coap/port/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/coap/libcoap/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/nghttp/port/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/nghttp/nghttp2/lib/includes -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp-tls -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp-tls/esp-tls-crypto -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_adc_cal/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_hid/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/tcp_transport/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_http_client/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_http_server/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_https_ota/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_https_server/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_lcd/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_lcd/interface -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/protobuf-c/protobuf-c -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/protocomm/include/common -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/protocomm/include/security -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/protocomm/include/transports -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/mdns/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_local_ctrl/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/sdmmc/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_serial_slave_link/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_websocket_client/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/expat/expat/expat/lib -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/expat/port/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/wear_levelling/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/fatfs/diskio -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/fatfs/vfs -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/fatfs/src -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/freemodbus/freemodbus/common/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/idf_test/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/idf_test/include/esp32 -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/jsmn/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/json/cJSON -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/libsodium/libsodium/src/libsodium/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/libsodium/port_include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/mqtt/esp-mqtt/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/openssl/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/perfmon/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/spiffs/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/ulp/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/wifi_provisioning/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/rmaker_common/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_diagnostics/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/rtc_store/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_insights/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/json_parser/upstream/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/json_parser/upstream -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/json_generator/upstream -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_schedule/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/espressif__esp_secure_cert_mgr/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_rainmaker/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/gpio_button/button/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/qrcode/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/ws2812_led -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_littlefs/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp-dl/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp-dl/include/tool -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp-dl/include/typedef -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp-dl/include/image -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp-dl/include/math -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp-dl/include/nn -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp-dl/include/layer -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp-dl/include/detect -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp-dl/include/model_zoo -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp32-camera/driver/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp32-camera/conversions/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/dotprod/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/support/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/support/mem/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/hann/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman_harris/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman_nuttall/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/nuttall/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/flat_top/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/iir/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/fir/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/add/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/sub/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/mul/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/addc/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/mulc/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/sqrt/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/matrix/mul/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/matrix/add/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/matrix/addc/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/matrix/mulc/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/matrix/sub/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/matrix/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/fft/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/dct/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/conv/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/common/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/matrix/mul/test/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/kalman/ekf/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/kalman/ekf_imu13states/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/fb_gfx/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/qio_qspi/include -mlongcalls -Wno-frame-address -ffunction-sections -fdata-sections -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -ggdb -freorder-blocks -Wwrite-strings -fstack-protector -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -fno-jump-tables -fno-tree-switch-conversion -std=gnu++11 -fexceptions -fno-rtti -c -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_uPesy_WROOM -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="uPesy_WROOM" -DARDUINO_VARIANT="uPesy_esp32_wroom_devkit" -DARDUINO_PARTITION_default -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_USB_CDC_ON_BOOT=0 @/private/var/folders/nc/h1l3t0n14n335tsh3y9nrz300000gn/T/arduino/sketches/D667DF0661F72997D2307FB41C597132/build_opt.h @/private/var/folders/nc/h1l3t0n14n335tsh3y9nrz300000gn/T/arduino/sketches/D667DF0661F72997D2307FB41C597132/file_opts -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/cores/esp32 -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/variants/uPesy_esp32_wroom_devkit /private/var/folders/nc/h1l3t0n14n335tsh3y9nrz300000gn/T/arduino/sketches/D667DF0661F72997D2307FB41C597132/sketch/servo_with_pir.ino.cpp -o /dev/null
Generating function prototypes...
/Users/ghulse/Library/Arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/esp-2021r2-patch5-8.4.0/bin/xtensa-esp32-elf-g++ -DHAVE_CONFIG_H -DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h" -DUNITY_INCLUDE_CONFIG_H -DWITH_POSIX -D_GNU_SOURCE -DIDF_VER="v4.4.7-dirty" -DESP_PLATFORM -D_POSIX_READER_WRITER_LOCKS -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/newlib/platform_include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/freertos/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/freertos/include/esp_additions/freertos -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/freertos/port/xtensa/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/freertos/include/esp_additions -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_hw_support/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_hw_support/include/soc -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_hw_support/include/soc/esp32 -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_hw_support/port/esp32 -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_hw_support/port/esp32/private_include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/heap/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/log/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/lwip/include/apps -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/lwip/include/apps/sntp -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/lwip/lwip/src/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/lwip/port/esp32/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/lwip/port/esp32/include/arch -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/soc/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/soc/esp32 -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/soc/esp32/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/hal/esp32/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/hal/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/hal/platform_port/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_rom/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_rom/include/esp32 -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_rom/esp32 -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_common/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_system/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_system/port/soc -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_system/port/public_compat -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp32/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/xtensa/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/xtensa/esp32/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/driver/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/driver/esp32/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_pm/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_ringbuf/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/efuse/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/efuse/esp32/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/vfs/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_wifi/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_event/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_netif/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_eth/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/tcpip_adapter/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_phy/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_phy/esp32/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_ipc/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/app_trace/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_timer/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/mbedtls/port/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/mbedtls/mbedtls/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/mbedtls/esp_crt_bundle/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/app_update/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/spi_flash/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/bootloader_support/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/nvs_flash/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/pthread/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_gdbstub/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_gdbstub/xtensa -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_gdbstub/esp32 -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/espcoredump/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/espcoredump/include/port/xtensa -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/wpa_supplicant/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/wpa_supplicant/port/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/wpa_supplicant/esp_supplicant/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/ieee802154/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/console -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/asio/asio/asio/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/asio/port/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/bt/common/osi/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/bt/include/esp32/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/bt/common/api/include/api -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/bt/common/btc/profile/esp/blufi/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/bt/common/btc/profile/esp/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/bt/host/bluedroid/api/include/api -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/tinycrypt/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/storage -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/bt/esp_ble_mesh/btc/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/common/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/client/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/server/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/bt/esp_ble_mesh/api/core/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/bt/esp_ble_mesh/api/models/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/bt/esp_ble_mesh/api -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/cbor/port/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/unity/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/unity/unity/src -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/cmock/CMock/src -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/coap/port/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/coap/libcoap/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/nghttp/port/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/nghttp/nghttp2/lib/includes -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp-tls -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp-tls/esp-tls-crypto -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_adc_cal/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_hid/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/tcp_transport/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_http_client/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_http_server/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_https_ota/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_https_server/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_lcd/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_lcd/interface -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/protobuf-c/protobuf-c -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/protocomm/include/common -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/protocomm/include/security -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/protocomm/include/transports -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/mdns/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_local_ctrl/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/sdmmc/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_serial_slave_link/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_websocket_client/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/expat/expat/expat/lib -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/expat/port/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/wear_levelling/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/fatfs/diskio -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/fatfs/vfs -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/fatfs/src -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/freemodbus/freemodbus/common/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/idf_test/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/idf_test/include/esp32 -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/jsmn/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/json/cJSON -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/libsodium/libsodium/src/libsodium/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/libsodium/port_include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/mqtt/esp-mqtt/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/openssl/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/perfmon/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/spiffs/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/ulp/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/wifi_provisioning/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/rmaker_common/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_diagnostics/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/rtc_store/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_insights/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/json_parser/upstream/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/json_parser/upstream -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/json_generator/upstream -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_schedule/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/espressif__esp_secure_cert_mgr/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_rainmaker/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/gpio_button/button/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/qrcode/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/ws2812_led -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_littlefs/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp-dl/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp-dl/include/tool -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp-dl/include/typedef -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp-dl/include/image -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp-dl/include/math -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp-dl/include/nn -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp-dl/include/layer -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp-dl/include/detect -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp-dl/include/model_zoo -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp32-camera/driver/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp32-camera/conversions/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/dotprod/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/support/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/support/mem/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/hann/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman_harris/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman_nuttall/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/nuttall/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/flat_top/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/iir/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/fir/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/add/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/sub/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/mul/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/addc/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/mulc/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/sqrt/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/matrix/mul/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/matrix/add/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/matrix/addc/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/matrix/mulc/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/matrix/sub/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/matrix/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/fft/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/dct/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/conv/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/common/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/matrix/mul/test/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/kalman/ekf/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/kalman/ekf_imu13states/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/fb_gfx/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/qio_qspi/include -mlongcalls -Wno-frame-address -ffunction-sections -fdata-sections -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -ggdb -freorder-blocks -Wwrite-strings -fstack-protector -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -fno-jump-tables -fno-tree-switch-conversion -std=gnu++11 -fexceptions -fno-rtti -c -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_uPesy_WROOM -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="uPesy_WROOM" -DARDUINO_VARIANT="uPesy_esp32_wroom_devkit" -DARDUINO_PARTITION_default -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_USB_CDC_ON_BOOT=0 @/private/var/folders/nc/h1l3t0n14n335tsh3y9nrz300000gn/T/arduino/sketches/D667DF0661F72997D2307FB41C597132/build_opt.h @/private/var/folders/nc/h1l3t0n14n335tsh3y9nrz300000gn/T/arduino/sketches/D667DF0661F72997D2307FB41C597132/file_opts -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/cores/esp32 -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/variants/uPesy_esp32_wroom_devkit /private/var/folders/nc/h1l3t0n14n335tsh3y9nrz300000gn/T/arduino/sketches/D667DF0661F72997D2307FB41C597132/sketch/servo_with_pir.ino.cpp -o /private/var/folders/nc/h1l3t0n14n335tsh3y9nrz300000gn/T/4170842465/sketch_merged.cpp
/Users/ghulse/Library/Arduino15/packages/builtin/tools/ctags/5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives /private/var/folders/nc/h1l3t0n14n335tsh3y9nrz300000gn/T/4170842465/sketch_merged.cpp
Compiling sketch...
/Users/ghulse/Library/Arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/esp-2021r2-patch5-8.4.0/bin/xtensa-esp32-elf-g++ -DHAVE_CONFIG_H "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DUNITY_INCLUDE_CONFIG_H -DWITH_POSIX -D_GNU_SOURCE "-DIDF_VER=\"v4.4.7-dirty\"" -DESP_PLATFORM -D_POSIX_READER_WRITER_LOCKS -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/newlib/platform_include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/freertos/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/freertos/include/esp_additions/freertos -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/freertos/port/xtensa/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/freertos/include/esp_additions -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_hw_support/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_hw_support/include/soc -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_hw_support/include/soc/esp32 -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_hw_support/port/esp32 -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_hw_support/port/esp32/private_include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/heap/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/log/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/lwip/include/apps -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/lwip/include/apps/sntp -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/lwip/lwip/src/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/lwip/port/esp32/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/lwip/port/esp32/include/arch -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/soc/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/soc/esp32 -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/soc/esp32/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/hal/esp32/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/hal/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/hal/platform_port/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_rom/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_rom/include/esp32 -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_rom/esp32 -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_common/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_system/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_system/port/soc -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_system/port/public_compat -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp32/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/xtensa/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/xtensa/esp32/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/driver/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/driver/esp32/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_pm/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_ringbuf/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/efuse/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/efuse/esp32/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/vfs/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_wifi/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_event/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_netif/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_eth/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/tcpip_adapter/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_phy/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_phy/esp32/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_ipc/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/app_trace/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_timer/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/mbedtls/port/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/mbedtls/mbedtls/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/mbedtls/esp_crt_bundle/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/app_update/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/spi_flash/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/bootloader_support/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/nvs_flash/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/pthread/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_gdbstub/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_gdbstub/xtensa -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_gdbstub/esp32 -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/espcoredump/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/espcoredump/include/port/xtensa -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/wpa_supplicant/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/wpa_supplicant/port/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/wpa_supplicant/esp_supplicant/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/ieee802154/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/console -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/asio/asio/asio/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/asio/port/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/bt/common/osi/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/bt/include/esp32/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/bt/common/api/include/api -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/bt/common/btc/profile/esp/blufi/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/bt/common/btc/profile/esp/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/bt/host/bluedroid/api/include/api -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/tinycrypt/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/storage -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/bt/esp_ble_mesh/btc/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/common/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/client/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/server/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/bt/esp_ble_mesh/api/core/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/bt/esp_ble_mesh/api/models/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/bt/esp_ble_mesh/api -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/cbor/port/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/unity/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/unity/unity/src -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/cmock/CMock/src -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/coap/port/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/coap/libcoap/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/nghttp/port/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/nghttp/nghttp2/lib/includes -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp-tls -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp-tls/esp-tls-crypto -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_adc_cal/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_hid/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/tcp_transport/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_http_client/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_http_server/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_https_ota/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_https_server/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_lcd/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_lcd/interface -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/protobuf-c/protobuf-c -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/protocomm/include/common -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/protocomm/include/security -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/protocomm/include/transports -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/mdns/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_local_ctrl/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/sdmmc/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_serial_slave_link/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_websocket_client/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/expat/expat/expat/lib -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/expat/port/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/wear_levelling/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/fatfs/diskio -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/fatfs/vfs -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/fatfs/src -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/freemodbus/freemodbus/common/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/idf_test/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/idf_test/include/esp32 -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/jsmn/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/json/cJSON -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/libsodium/libsodium/src/libsodium/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/libsodium/port_include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/mqtt/esp-mqtt/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/openssl/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/perfmon/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/spiffs/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/ulp/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/wifi_provisioning/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/rmaker_common/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_diagnostics/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/rtc_store/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_insights/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/json_parser/upstream/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/json_parser/upstream -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/json_generator/upstream -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_schedule/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/espressif__esp_secure_cert_mgr/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_rainmaker/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/gpio_button/button/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/qrcode/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/ws2812_led -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp_littlefs/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp-dl/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp-dl/include/tool -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp-dl/include/typedef -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp-dl/include/image -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp-dl/include/math -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp-dl/include/nn -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp-dl/include/layer -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp-dl/include/detect -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp-dl/include/model_zoo -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp32-camera/driver/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/esp32-camera/conversions/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/dotprod/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/support/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/support/mem/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/hann/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman_harris/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman_nuttall/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/nuttall/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/flat_top/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/iir/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/fir/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/add/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/sub/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/mul/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/addc/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/mulc/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/sqrt/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/matrix/mul/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/matrix/add/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/matrix/addc/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/matrix/mulc/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/matrix/sub/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/matrix/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/fft/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/dct/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/conv/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/common/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/matrix/mul/test/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/kalman/ekf/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/espressif__esp-dsp/modules/kalman/ekf_imu13states/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/include/fb_gfx/include -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/qio_qspi/include -mlongcalls -Wno-frame-address -ffunction-sections -fdata-sections -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -ggdb -freorder-blocks -Wwrite-strings -fstack-protector -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -fno-jump-tables -fno-tree-switch-conversion -std=gnu++11 -fexceptions -fno-rtti -MMD -c -w -Os -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_uPesy_WROOM -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"uPesy_WROOM\"" "-DARDUINO_VARIANT=\"uPesy_esp32_wroom_devkit\"" -DARDUINO_PARTITION_default -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_USB_CDC_ON_BOOT=0 @/private/var/folders/nc/h1l3t0n14n335tsh3y9nrz300000gn/T/arduino/sketches/D667DF0661F72997D2307FB41C597132/build_opt.h @/private/var/folders/nc/h1l3t0n14n335tsh3y9nrz300000gn/T/arduino/sketches/D667DF0661F72997D2307FB41C597132/file_opts -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/cores/esp32 -I/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/variants/uPesy_esp32_wroom_devkit /private/var/folders/nc/h1l3t0n14n335tsh3y9nrz300000gn/T/arduino/sketches/D667DF0661F72997D2307FB41C597132/sketch/servo_with_pir.ino.cpp -o /private/var/folders/nc/h1l3t0n14n335tsh3y9nrz300000gn/T/arduino/sketches/D667DF0661F72997D2307FB41C597132/sketch/servo_with_pir.ino.cpp.o
Compiling libraries...
Compiling core...
/usr/bin/env bash -c "echo -DARDUINO_CORE_BUILD > /private/var/folders/nc/h1l3t0n14n335tsh3y9nrz300000gn/T/arduino/sketches/D667DF0661F72997D2307FB41C597132/file_opts"
Using precompiled core: /private/var/folders/nc/h1l3t0n14n335tsh3y9nrz300000gn/T/arduino/cores/a683a09c94af6bcccbb1aea98f500f33/core.a
/usr/bin/env bash -c ": > /private/var/folders/nc/h1l3t0n14n335tsh3y9nrz300000gn/T/arduino/sketches/D667DF0661F72997D2307FB41C597132/file_opts"
Linking everything together...
/Users/ghulse/Library/Arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/esp-2021r2-patch5-8.4.0/bin/xtensa-esp32-elf-g++ -Wl,--Map=/private/var/folders/nc/h1l3t0n14n335tsh3y9nrz300000gn/T/arduino/sketches/D667DF0661F72997D2307FB41C597132/servo_with_pir.ino.map -L/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/lib -L/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/ld -L/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/sdk/esp32/qio_qspi -T esp32.rom.redefined.ld -T memory.ld -T sections.ld -T esp32.rom.ld -T esp32.rom.api.ld -T esp32.rom.libgcc.ld -T esp32.rom.newlib-data.ld -T esp32.rom.syscalls.ld -T esp32.peripherals.ld -mlongcalls -Wno-frame-address -Wl,--cref -Wl,--gc-sections -fno-rtti -fno-lto -Wl,--wrap=esp_log_write -Wl,--wrap=esp_log_writev -Wl,--wrap=log_printf -u ld_include_hli_vectors_bt -u _Z5setupv -u _Z4loopv -u esp_app_desc -u pthread_include_pthread_impl -u pthread_include_pthread_cond_var_impl -u pthread_include_pthread_local_storage_impl -u pthread_include_pthread_rwlock_impl -u include_esp_phy_override -u ld_include_highint_hdl -u start_app -u start_app_other_cores -u __ubsan_include -Wl,--wrap=longjmp -u __assert_func -u vfs_include_syscalls_impl -Wl,--undefined=uxTopUsedPriority -u app_main -u newlib_include_heap_impl -u newlib_include_syscalls_impl -u newlib_include_pthread_impl -u newlib_include_assert_impl -u __cxa_guard_dummy -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_USB_CDC_ON_BOOT=0 -Wl,--start-group /private/var/folders/nc/h1l3t0n14n335tsh3y9nrz300000gn/T/arduino/sketches/D667DF0661F72997D2307FB41C597132/sketch/servo_with_pir.ino.cpp.o /private/var/folders/nc/h1l3t0n14n335tsh3y9nrz300000gn/T/arduino/cores/a683a09c94af6bcccbb1aea98f500f33/core.a -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lxtensa -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lasio -lbt -lcbor -lunity -lcmock -lcoap -lnghttp -lesp-tls -lesp_adc_cal -lesp_hid -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lesp_https_server -lesp_lcd -lprotobuf-c -lprotocomm -lmdns -lesp_local_ctrl -lsdmmc -lesp_serial_slave_link -lesp_websocket_client -lexpat -lwear_levelling -lfatfs -lfreemodbus -ljsmn -ljson -llibsodium -lmqtt -lopenssl -lperfmon -lspiffs -lulp -lwifi_provisioning -lrmaker_common -lesp_diagnostics -lrtc_store -lesp_insights -ljson_parser -ljson_generator -lesp_schedule -lespressif__esp_secure_cert_mgr -lesp_rainmaker -lgpio_button -lqrcode -lws2812_led -lesp32-camera -lesp_littlefs -lespressif__esp-dsp -lfb_gfx -lasio -lcmock -lunity -lcoap -lesp_lcd -lesp_websocket_client -lexpat -lfreemodbus -ljsmn -llibsodium -lperfmon -lesp_adc_cal -lesp_hid -lfatfs -lwear_levelling -lopenssl -lspiffs -lesp_insights -lcbor -lesp_diagnostics -lrtc_store -lesp_rainmaker -lesp_local_ctrl -lesp_https_server -lwifi_provisioning -lprotocomm -lbt -lbtdm_app -lprotobuf-c -lmdns -ljson -ljson_parser -ljson_generator -lesp_schedule -lespressif__esp_secure_cert_mgr -lqrcode -lrmaker_common -lmqtt -lcat_face_detect -lhuman_face_detect -lcolor_detect -lmfn -ldl -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lxtensa -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lnghttp -lesp-tls -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lsdmmc -lesp_serial_slave_link -lulp -lmbedtls_2 -lmbedcrypto -lmbedx509 -lcoexist -lcore -lespnow -lmesh -lnet80211 -lpp -lsmartconfig -lwapi -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lxtensa -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lnghttp -lesp-tls -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lsdmmc -lesp_serial_slave_link -lulp -lmbedtls_2 -lmbedcrypto -lmbedx509 -lcoexist -lcore -lespnow -lmesh -lnet80211 -lpp -lsmartconfig -lwapi -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lxtensa -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lnghttp -lesp-tls -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lsdmmc -lesp_serial_slave_link -lulp -lmbedtls_2 -lmbedcrypto -lmbedx509 -lcoexist -lcore -lespnow -lmesh -lnet80211 -lpp -lsmartconfig -lwapi -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lxtensa -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lnghttp -lesp-tls -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lsdmmc -lesp_serial_slave_link -lulp -lmbedtls_2 -lmbedcrypto -lmbedx509 -lcoexist -lcore -lespnow -lmesh -lnet80211 -lpp -lsmartconfig -lwapi -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lxtensa -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lnghttp -lesp-tls -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lsdmmc -lesp_serial_slave_link -lulp -lmbedtls_2 -lmbedcrypto -lmbedx509 -lcoexist -lcore -lespnow -lmesh -lnet80211 -lpp -lsmartconfig -lwapi -lphy -lrtc -lesp_phy -lphy -lrtc -lesp_phy -lphy -lrtc -lxt_hal -lc -lm -lnewlib -lstdc++ -lpthread -lgcc -lcxx -Wl,--end-group -Wl,-EL -o /private/var/folders/nc/h1l3t0n14n335tsh3y9nrz300000gn/T/arduino/sketches/D667DF0661F72997D2307FB41C597132/servo_with_pir.ino.elf
/Users/ghulse/Library/Arduino15/packages/esp32/tools/esptool_py/4.5.1/esptool --chip esp32 elf2image --flash_mode dio --flash_freq 80m --flash_size 4MB --elf-sha256-offset 0xb0 -o /private/var/folders/nc/h1l3t0n14n335tsh3y9nrz300000gn/T/arduino/sketches/D667DF0661F72997D2307FB41C597132/servo_with_pir.ino.bin /private/var/folders/nc/h1l3t0n14n335tsh3y9nrz300000gn/T/arduino/sketches/D667DF0661F72997D2307FB41C597132/servo_with_pir.ino.elf
esptool.py v4.5.1
Creating esp32 image...
Merged 2 ELF sections
Successfully created esp32 image.
python3 /Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15/tools/gen_esp32part.py -q /private/var/folders/nc/h1l3t0n14n335tsh3y9nrz300000gn/T/arduino/sketches/D667DF0661F72997D2307FB41C597132/partitions.csv /private/var/folders/nc/h1l3t0n14n335tsh3y9nrz300000gn/T/arduino/sketches/D667DF0661F72997D2307FB41C597132/servo_with_pir.ino.partitions.bin
/usr/bin/env bash -c "[ ! -d \"/private/var/folders/nc/h1l3t0n14n335tsh3y9nrz300000gn/T/arduino/sketches/D667DF0661F72997D2307FB41C597132\"/libraries/Insights ] || python3 \"/Users/ghulse/Library/Arduino15/packages/esp32/hardware/esp32/2.0.15\"/tools/gen_insights_package.py /private/var/folders/nc/h1l3t0n14n335tsh3y9nrz300000gn/T/arduino/sketches/D667DF0661F72997D2307FB41C597132 servo_with_pir.ino \"/Users/ghulse/Documents/Arduino/servo_with_pir\""
/Users/ghulse/Library/Arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/esp-2021r2-patch5-8.4.0/bin/xtensa-esp32-elf-size -A /private/var/folders/nc/h1l3t0n14n335tsh3y9nrz300000gn/T/arduino/sketches/D667DF0661F72997D2307FB41C597132/servo_with_pir.ino.elf
Sketch uses 263753 bytes (20%) of program storage space. Maximum is 1310720 bytes.
Global variables use 21400 bytes (6%) of dynamic memory, leaving 306280 bytes for local variables. Maximum is 327680 bytes.
esptool.py v4.5.1
Serial port /dev/cu.usbserial-4230
Connecting.....
Chip is ESP32-D0WD-V3 (revision v3.1)
Features: WiFi, BT, Dual Core, 240MHz, VRef calibration in efuse, Coding Scheme None
Crystal is 40MHz
MAC: 30:c9:22:31:e1:18
Uploading stub...
Running stub...
Stub running...
Changing baud rate to 921600
Changed.
A fatal error occurred: Unable to verify flash chip connection (Invalid head of packet (0xE0): Possible serial noise or corruption.).
Failed uploading: uploading error: exit status 2
Mine works with ESP32 Dev Module as the board
ghulse
April 12, 2024, 5:19pm
6
When I connect this board to my Mac, should I see it appear on desktop? Should I hit the reset button on the board? Not sure of the steps.
Sorry. I know little or nothing about Macs. Are you expecting it to appear as a USB drive ?
When I plug the board, or any other "Arduino", into my Windows PC a COM port is created and can be seen in Device Manager. Presumably something similar happens on the Mac
Once the COM port has been created then it is available to use in the IDE.
ghulse
April 12, 2024, 9:24pm
8
The Adafruit devices that I've used before appear on the Mac desktop, hence my question. Though i have an Arduino Uno, it's been a while since I've used it.
I switched to Port-310 and finally got signs of life in the Arduino serial monitor. Then I had to switch baud rate to 115200 to upload the Hello World sketch. But then after uploading the sketch it says "Hard resetting via RTS pin" And nothing more happens.
Did you note this in the example hello_world sketch ?
// Make sure to copy the UserSetup.h file into the library as
// per the Github Instructions. The pins are defined in there.
ghulse
April 13, 2024, 12:05am
10
Hey,
Thanks again. Yes, I did do this. Still no go.
I was able to webflash the Spotify DIY project to the device and that actually worked. So I guess the problem is with the Arduino IDE. At least I know the thing really works. Thanks for all your suggestions.
NOTE: Actually, I held the reset button while connecting the ESP32 to my Mac, then uploaded the sketch and it works! Hello World!!
Thanks again for your help.
I am glad that you got it working
Just FYI; that is normal behaviour.
system
Closed
October 11, 2024, 8:10am
13
