Hello,
I am attempting to adjust some code in Arduino IDE 2.1.1, and it calls for:
QueueArray.h
SoftwareSerial.h
it gives me the error that there is no such file or directory for the QueueArray.h and the SoftwareSerial gives:
Compilation error: call of overloaded 'BasicUART(SoftwareSerial)' is ambiguous
I have these libraries installed:
Adafruit Neopixel
Adafruit Soundboard Library
Audio Zero
EspSoftwareSerial
I2C
Queue
TaskQueue
What am I missing to not make this work? Please help me. And thank you in advance.
#include <SoftwareSerial.h>
#include <QueueArray.h>
#include <Wire.h> // Include the I2C library (required)
// for the sound board
#include "Adafruit_Soundboard.h"
// for led triggers
#define HIGH 0x1
#define LOW 0x0
// pins for 3 red leds
int LedA = A0;
int LedB = A1;
int LedC = A2;
// neopixel pins / setup
#define NEO_PIXELS 2
Adafruit_NeoPixel NeoPixels = Adafruit_NeoPixel(31, NEO_PIXELS, NEO_GRB + NEO_KHZ800);
// Index numbers for the LEDs in the neopixels. since i used 2 jewels for the center, one ring for the end, and a single for the indicator,
//i set them as below. if you use a different number or type of pixels, change these numbers accordingly. the indicator light is first in the chain
//so it is number 0
int centerStart = 1;
int centerEnd = 14;
int ringStart = 15;
int ringEnd = 30;
// inputs for switches and buttons
const int SONGBTN = 5;
const int POWERSW = 6;
const int BLUEBTN = 7;
const int ORANGEBTN = 8;
const int CANCELBTN = 9;
// soundboard pins and setup
#define SFX_RST 10
#define SFX_RX 11
#define SFX_TX 12
const int ACT = 13; // this allows us to know if the audio is playing
SoftwareSerial ss = SoftwareSerial(SFX_TX, SFX_RX);
Adafruit_Soundboard sfx = Adafruit_Soundboard( &ss, NULL, SFX_RST);
// Possible states
bool Firing = false; // firing animation is going
bool Portal = false; // is there an open portal
bool Power = false; // power on or off
bool Song = false; //playing the song
// audio track names on soundboard
char powerup[] = "T00 WAV";
char hum[] = "T01 WAV";
char bluefire[] = "T02 WAV";
char orangefire[] = "T03 WAV";
char cancelportal[] = "T04 WAV";
char powerdown[] = "T05 WAV";
char alivesong[] = "T06 OGG";
// Arduino setup function
// softwareserial at 9600 baud for the audio board
ss.begin(9600);
// set act modes for the fx board
pinMode(ACT, INPUT);
pinMode(LedA, OUTPUT);
pinMode(LedB, OUTPUT);
pinMode(LedC, OUTPUT);
// configure neo pixels
NeoPixels.begin();
NeoPixels.setBrightness(255);
NeoPixels.show(); // Initialize all pixels to 'off'
// set the modes for the switches/buttons
pinMode(SONGBTN, INPUT);
digitalWrite(SONGBTN, HIGH);
pinMode(POWERSW, INPUT);
digitalWrite(POWERSW, HIGH);
pinMode(BLUEBTN, INPUT);
digitalWrite(BLUEBTN, HIGH);
pinMode(ORANGEBTN, INPUT);
digitalWrite(ORANGEBTN, HIGH);
pinMode(CANCELBTN, INPUT);
digitalWrite(CANCELBTN, HIGH);
/* ************* Audio Board Helper Functions ************* */
// helper function to play a track by name on the audio board
void playAudio( char* trackname, int playing ) {
// stop track if one is going
if (playing == 0) {
sfx.stop();
// now go play
if (sfx.playTrack(trackname)) {
sfx.unpause();
/* ************* Main Loop ************* */
// find out of the audio board is playing audio
int playing = digitalRead(ACT);
// get the current switch states
int SongBtn = digitalRead(SONGBTN);
// if you press song button play song
if (SongBtn == 0) {
if (Song == false) {
playAudio(alivesong, playing);
Song = true;
Song = false;
int PowerSw = digitalRead(POWERSW);
int BlueBtn = digitalRead(BLUEBTN);
int OrangeBtn = digitalRead(ORANGEBTN);
int CancelBtn = digitalRead(CANCELBTN);
// while the startup switch is set on
if (PowerSw == 0) {
// play the hum sound when on and idle
if (playing == 1 && Power == true) {
playAudio(hum, playing);
// if we are not powered up we should play the power up sound and begin the loop
if (PowerSw == 0 && Power == false) {
Power = true;
analogWrite(LedA, 175); //turn led on
analogWrite(LedB, 175); // turn led on
analogWrite(LedC, 175); // turn led on
playAudio(powerup, playing);
// if we are powered up and turn the power switch off then power down
if (PowerSw == 1 && Power == true) {
Power = false;
playAudio(powerdown, playing);
analogWrite(LedA, 0); //turn Led off
analogWrite(LedB, 0); // turn led off
analogWrite(LedC, 0); // turn led off
setLightsState(2); //set blue or orange light to off
// Fire Blue
if (BlueBtn == 0 && Power == true && Firing == false) {
Firing = true;
Portal = true;
playAudio(bluefire, playing);
setLightsState(1); //set light to blue
if (CancelBtn == 1 && BlueBtn == 1 && OrangeBtn == 1 && Firing == true)
Firing = false;
// Fire Orange
if (OrangeBtn == 0 && Power == true && Firing == false) {
Firing = true;
Portal = true;
playAudio(orangefire, playing);
setLightsState(0); //set lights to orange
Firing = false;
// Cancel Portal
if (CancelBtn == 0 && Power == true && Firing == false && Portal == true) {
Firing = true;
Portal = false;
playAudio(cancelportal, playing);
setLightsState(2); //set light to off
Firing = false;
/* ************* Lights States************* */
void setLightsState(int state)
switch ( state )
case 0: // orange fire
for (int d = 25, b = 25; (d > 0) && (b < 50); d--, b++) //starts at 50 percent, center light dims then brightens, end light brightens then dims
for (int j = centerStart; j <= centerEnd; j++)
NeoPixels.setPixelColor(j, NeoPixels.Color(d * 5, d, 0)); //i get orange to dim properly by setting green to a number and setting red to 5 times what green is
for (int k = ringStart; k <= ringEnd; k++)
NeoPixels.setPixelColor(k, NeoPixels.Color(b * 5, b, 0));
NeoPixels.show();
delay(0);
for (int d = 0, b = 50; (d < 25) && (b > 25); d++, b--) {
for (int j = centerStart; j <= centerEnd; j++) {
for (int k = ringStart; k <= ringEnd; k++) {
NeoPixels.setPixelColor(0, NeoPixels.Color(255, 50, 0));
NeoPixels.show();
delay(20);
case 1: // blue fire
for (int d = 128, b = 128; (d > 0) && (b < 255); d--, b++)// same as orange above, except you just have to set blue between half and full
NeoPixels.setPixelColor(j, NeoPixels.Color(0, 0, d));
NeoPixels.setPixelColor(k, NeoPixels.Color(0, 0, b));
NeoPixels.setPixelColor(0, 0, 0, 255);
NeoPixels.show();
delay(0);
for (int d = 0, b = 255; (d < 128) && (b > 128); d++, b--) {
NeoPixels.setPixelColor(0, NeoPixels.Color(0, 0, 255));
NeoPixels.show();
delay(4);
case 2: // set led off
for (int j = 0; j < NeoPixels.numPixels(); j++) {
NeoPixels.setPixelColor(j, 0);
NeoPixels.show();
